Eu falei no Leaf.
Relativamente ao resto, eu falei em custos de transporte e não iniciais...mas visto que o Zoe não é o Clio, essa comparação é complicada de se realizar.
Como o objetivo principal é a poupança, o aluguer mensal, destrói esse propósito completamente!
Já que mesmo parado está a consumir.
Vi hoje passar por mim esse azulinho do video com uma moçoila loira... não me pareceu mal mas o aluguer das baterias ainda é um problema (€€)
What is it?
The Renault Zoe is an all-electric city car, designed for everyday use, that can seat five in comfort.
The Zoe looks great, with clean, crisp, concept car lines that are futuristic but not outlandish. It features some subtle blue tinting of lights and badges and a calm, sleekly styled cabin with a large 'R-link' display screen. You can pre-heat or pre-cool the cabin while charging, too.
On that all-important topic, the official EU test regime credits the Zoe with a 130-mile range on a full charge. Renault itself reckons on a worst-case 60 miles in winter, 90 miles in summer.
What is it like?
The Zoe's pile of torque is instantly available at an ankle flex and delivered with one of three selectable, synthesised and curious hums so pedestrians can hear the Zoe coming. (The hum stops above 18mph, or you can kill it completely.)
That initial friskiness on getaway fades significantly as speed rises, and the the upper limit is set at 84mph to conserve the battery and prevent the motor over-revving. But there’s enough urge here for you not to crave more even in Eco mode, which stifles the scorching starts but feels fine on the open road while adding another 10 per cent or so to the range.
The Zoe corners with conviction and stays flat while resisting understeer. You can feel the weight, all 1468kg of it, but the centre of gravity is lower than the latest Clio’s, whose platform the Zoe shares. That’s because the 22kWh, 400V battery pack is spread under the floor, so the Zoe is a proper five-seater with a normal-size boot.
Initially the battery promised 81 miles, but a check after 22 gentle suburban miles showed 70 miles of remaining range. The range was down to 43 miles after a further 14 miles of rapid driving with full acceleration, but after ambling for another 14 miles there was still 42 miles of range left. Overall, the Zoe went further than its range-calculator initially thought it would.
Among its range-extending devices is a reversible air-con system that heats the Renault Zoe as well as cooling it without stealing much energy from the battery.
Energy recuperation from slowing or braking is strong, too, but the integration of virtual brakes with real ones isn’t entirely smooth and feathering to a gentle halt takes some skill. More jolts come when the wheels fall heavily into road surface breaks, but otherwise the ride is smooth and supple on the bespoke Michelin Energy Z-E tyres.
Should I buy one?
This is an electric car that you could actually consider buying, helped by the free fitment of a home charging unit, paid for by Renault (25 per cent) and the government (75 per cent).
In city traffic the Zoe makes even more sense. It waits patiently and silently at the lights, surrounded by clattery, time-served diesels that seem like relics.
When the lights switch to green, the Zoe streaks ahead of dawdling hatchbacks to snick into gaps. It's a brilliant urban car.
Autohoje - Renault sugere Zoe Cabriolet
A marca francesa publicou uma imagem na sua página oficial do Facebook, sugerindo uma nova variante do seu modelo 100% elétrico, com o intuito de aferir do potencial da mesma.
A Renault testou a reação dos seus seguidores da sua página oficial do Facebook sobre uma potencial versão descapotável do Zoe, ao publicar uma imagem gerada por computador concebida por um fã espanhol conjuntamente com o texto: “Renault Zoe Cabriolet: ideal para conduzir ao sabor do ar primaveril. Gostaria que este concept feito por um fã se tornasse realidade?”. E o facto é que este desafio tem dado origem a muitos comentários.
Com esta proposta, o fabricante francês mostra interesse no alargamento da oferta de modelos elétricos composta atualmente pelo Fluence ZE, Kangoo ZE, Twizy e Zoe convencional.
No other manufacturer has committed so wholeheartedly to the electric vehicle as Renault. A handful of companies have a full EV in their range – and more have them in the pipeline – but the ZOE is the fourth model to join Renault’s ZE (Zero Emissions) line-up.
However, the ZOE is the most ambitious arrival yet, as Renault claims it “heralds a new era of electric mobility for all”. These are big words, but a smart five-seat battery-powered supermini certainly has the potential to attract customers previously deterred by quirky EVs like the Twizy.
The ZOE is based on the latest Clio platform and built alongside its more conventional stablemate in Flins, France. It also shares its battery technology with the Nissan Leaf. But with 60 new technology patents, the newcomer from Renault promises to be the most advanced EV we’ve seen from the Renault-Nissan alliance.
Yet for the most part, the ZOE looks just like an ordinary supermini – only the lack of an exhaust pipe or fuel cap gives away its electric drivetrain. With an almost identical wheelbase and width to the Clio, it’s a traditionally sized supermini, too.
However, as a result of packaging its batteries under the rear seats, the ZOE is much taller than traditional rivals – it’s almost as high as many supermini-MPVs. Elsewhere, the high shoulder line and narrow windows help heating or cooling efficiency by minimising the glass area.
Much of the interior – including the central part of the dashboard – is carried over from the Clio, but rather than the conventional instrument, you get a digital display that shows remaining range and speed. All trims get Renault’s R-Link tablet screen, which includes sat-nav and Bluetooth functionality, as well as downloadable apps.
Overall, the cabin design is modern and straightforward, but Renault has tried to create a techy ‘Apple shop’ feel by adding lots of shiny white trim and light materials to give it a bit of spark.
Unfortunately, the light trim creates reflections in the windscreen. Added to nasty A-pillar blindspots, this makes visibility a bit of an issue, while the driving position is partly compromised by the high-mounted seat.
On the plus side, the conventional gear selector and handbrake are refreshingly easy to use compared to the fiddly drive selector in the Leaf, and getting on the move couldn’t be easier – you simply power up, select drive and off you go.
Once you’re driving, the ZOE’s steering has a slightly more natural feel than the Leaf’s, but with 290kg of lithium ion batteries to carry around, the handling is inert compared to that of conventional superminis.
Having said that, mounting the cells low down means body control isn’t too bad, and the ZOE feels less nose-heavy than the Nissan. Plus, the ride isn’t quite as brittle. Like all EVs, the grabby brakes take some getting used to, and with less power than the Nissan, the Renault isn’t as quick off the line. If you do fancy flooring the throttle, the instant response will still raise a smile, but, above 60mph the ZOE soon runs out of puff.
Thanks to Renault’s novel Chameleon charger system, which works with single or three-phase power, the ZOE’s battery can be 80 per cent charged in as little as 30 minutes – although a full charge can take up to nine hours. When full, the car has an official range of 130 miles, although Renault admits that in the real world you’re more likely to manage between 60 and 90 miles.
Crucially, unlike the Leaf you can’t charge from a conventional three-pin domestic plug, although Renault will fit a charging station at your home for free. And depending on your annual mileage and contract length, battery hire will cost between £70 and £113 a month.
The ZOE also comes with Renault’s 4+ free servicing, roadside assistance and warranty package, while the electric powertrain is covered for five years. If you’ve got a charging point near you and mainly drive short distances, the ZOE is a tempting proposition.
Veredicto: 3 estrelas
O ZOE é o carro eléctrico mais convincente que conduziram até à data. Tanto o preço, como o desenho do carro o tornam mais atractivo do que muitos dos seus rivais eléctricos, tendo o bónus de ser melhor de conduzir do que o primo Leaf. A falta de uma ficha tradicional para o pôr a carregar é um problema, todavia a oferta da Renault para montar carregadores em casa ajuda a compensar este problema - desde que haja espaço para ter um.
Renault will sell about 10,000 units of its Zoe subcompact electric car this year, 40,000 below its target, according to market analyst Inovev.The automaker would not confirm or deny that its aim this year for the Zoe was 50,000 global sales, a number that Inovev said was provided by multiple high-ranking Renault executives. Early this year the automaker announced that the Renault-Nissan alliance would not meet its goal of selling 1.5 million EVs globally by 2016. A Renault spokeswoman said that the alliance has not set any new targets yet.
Renault launched the battery-powered Zoe in Europe earlier this year. With a global volume of 6,600 units from January through September, the Zoe is the top-selling EV in Renault's lineup, which also includes the Fluence Z.E. sedan, Kangoo Z.E. small van and Twizy two-seat model.
Michel Costes, president and CEO at France-based Inovev, said that while Zoe sales will fall significantly short of Renault's initial projections, he believes consumer interest in the Zoe and other EVs such as the Nissan Leaf will grow once there are more public places available to plug in the car.
"We think that the Zoe and EVs in general will continue to become a popular alternative to combustion engine cars, especially in urban environments, as charging stations become more available. But that will happen slower than what Renault forecast," Costes told Automotive News Europe.
Consultancy IHS Automotive estimates that Renault will sell 23,434 Zoe units in 2014 and 25,843 units in 2015 and believes that it will take Renault until 2020 to reach 50,000 sales a year.
Along with the need to build up a public charging infrastructure at places such as parking garages and shopping centers, IHS technology specialist Alastair Hayfield said EV uptake also will be affected by factors such as legislation, fuel prices, and battery technology.
De momento os construtores ainda não conseguem fazer propostas economicamente viáveis para veículos eléctricos, embora esse limiar seja praticamente atingido em países com incentivos à sua aquisição (por exemplo 5.000€ em França).
A Toyota percebeu isso em boa hora e investiu na hibridização de toda a gama, enquanto algumas marcas quiseram encher as revistas de ilusões e dar o salto directo para o mundo dos eléctricos. A diferença de vendas actual mostra quem tinha razão.
Em todo o caso, como sempre acontece com as novidades tecnológicas, é uma questão de tempo até que os custos desçam e se tornem competitivos. E bem precisamos disso para respirar devidamente nas cidades.
