TurboGiroMz
Nao conigo. Por isso vou transcrever o mesmo para o forum:
No. Name of Datastream Value Unit
1 Engine Speed 1050 rpm
2 Injection pulse width 13.2 ms
3 Idle Control 165 step
4 Air flow 0.82 V
5 Intake Manifold Pressure 73 mmHg
6 Left air/fuel 0.00 V
7 Right air/fuel 0.00 V
8 Throttle opening 24 Degrees
9 Ingintion Advanced Angle 8 Degrees
10 Vehicle Speed 0 Km/h
11 Coolant Temp sensor 3 V
12 L O2 sensor status Lean
13 R O2 sensor status Lean
14 L open/closed loop Open
15 R open/closed loop Open
16 Knock Sensor NO
17 Start Switch OFF
18 Idle Switch OFF
19 A/C clutch OFF
20 P/N SW P-N-
21 Warm Start enrich YES
22 enrich after starting YES
Mais uma vez obrigado por todo apoio. Aguardo pelso vossos comentarios. Isto esta uma dor de cabceca....[8b]
4 Air flow 0.82 V
16 Knock Sensor NO
17 Start Switch OFF
18 Idle Switch OFF
19 A/C clutch OFF
20 P/N SW P-N-
