Volkswagen Up!
Estatisticamente os problemas e os estilos de condução anulam-se. O que se deve fazer é não considerar muito fiáveis consumos médios de um pequeno lote de condutores, mas quando são centenas a média geral é um excelente indicador. Os 2 carros a gasolina com menores consumos médios têm ambos esse problema, poucos exemplares registados (VW up e Nissan Pixo).
A evo também brinca com carrinhos
Driven: Volkswagen Up Black
Rating: 3.5 / 5
We drive VW's classy new city car in the UK. What's it like in top-spec Black trim?
By Stephen Dobie
April 2012
What is it?
The Volkswagen Up city car, tested here in its top spec ‘Up Black’ trim. With a host of equipment, pearl effect paint and very cool 16in alloys, it costs £11,180.
Technical highlights?
Unlike the ambitious Up concept car of 2007, which was rear-engined and rear-wheel drive, the production version powers its front wheels via a front-mounted 1-litre, three-cylinder engine. In base-spec Ups, it has a modest 59bhp, but in more lavishly equipped models like tested here, it has a more useable 74bhp.
Standard equipment on the Black includes a smart ‘Maps & More’ infotainment screen, with Bluetooth, satnav and an eco-biased trip computer. An optional Driver’s Assistance pack, a £225 option on the Black (£400 on base Ups) includes emergency braking assistance, to help haul you to a standstill in city traffic below 19mph.
What’s it like to drive?
It’s the most polished budget car on sale. Its three-pot soundtrack will conjure up the inevitable ‘half an air-cooled 911’ observations under load, but when cruising – even at typical motorway speeds – noise is impressively suppressed. The ride quality and the ease of all its controls – effortless steering, spot-on pedal weightings – make it a doddle to drive. You’ll have to work the little 1-litre hard to get anywhere fast (well, fast-ish) but keeping up with traffic is rarely an issue.
It impresses when pushed too, and grips gamely. The chassis is talented enough to show the engine up a little; 100bhp (or more) wouldn’t really trouble the Up, and the full potential of its competent setup would be unlocked. Firmly cross your fingers, then, that the turbocharged Up GT (driven here) gets the go-ahead. Volkswagen is still 50/50 on whether it’ll make it to showrooms.
How does it compare?
As a day-to-day prospect, the classy Up trounces many of its city car contenders. Only the new Fiat Panda and mechanically identical stablemates from SEAT and Skoda, the Mii and Citigo, can compete. But for more unrefined, wheel squealing fun, the your pick of the Citroen C1/Peugeot 107/Toyota Aygo trio is still a likeable alternative.
Anything else I need know?
Lovely as the well-trimmed Up Black is, £11K seems a lot for something so titchy. We’d recommend buying at one of the lower rungs of the Up ladder, though you’ll need at least £10,390 if you want the feistier 74bhp engine. And if you think the Black's colour scheme is to sombre, there's an identically priced and specced Up White edition. Guess the difference...
+ Looks great, good to drive, high refinement
- Better value in base-spec trim
Engine: In-line 3cyl, 999cc
Max power: 74bhp @ 6200rpm
Max torque: 70lb ft @ 3000-4300rpm
0 - 60mph: 13.2sec (claimed 0-62)
Top speed: 106mph
Price: £11,180
On Sale: Now
Confirma-se: motor de 1 litro, mas devendo debitar 109cv e 162Nm.
Volkswagen Up! GT confirmado para 2013
Os dados ainda não são oficiais, mas esse motor de 3 cilindros aponta para esses números.
Outra fonte aponta para a mesma cavalagem, mas 175Nm, aceleração 0-100 em 8,5s, velocidade de ponta de 195km/h, jantes de 17", pacote aerodinâmico e duas ponteiras de escape.
E também chegará o e-UP.
Versão elétrica a debitar 82cv e autonomia de 130km (bem razoável para o uso citadino).
Tal como o GT, o e-Up também chegará já em 2013.
AutoBlog | Volkswagen potvrdio serijski up! GT i e-up!
Não chega aos 125cv do Lupo.. é pena, merecia um pouco mais.
No entanto, deverá atenuar as diferenças para o Lupo graças ao peso inferior.
O Lupo pesava 975kg DIN (sem opções).
O Up pesa 850kg DIN.
Mesmo que este GT chegue a pesar mais 50kg que os Up que já temos, mesmo assim será bem mais leve que o Lupo, pelo que deverão ficar próximos no que toca a relação peso-potência
850?! Não fazia ideia que era tão leve! Se continuar com os 850 ficará com uma relação peso/potência semelhante. Sendo assim... retiro o que disse. (e ainda há espaço para o GT...i [;)])
Tal como o Lupo, também deve ter sido pesado sem opções.
Instalar AC deve aumentar perto de 20kg à criatura[:D]
Mas fui confirmar... falhei por poucos kg o peso da criatura. Versão de 75cv e caixa manual pesa 929kg EU, o que retirando os 75kg (68kg condutor+7kg bagagem) da norma EU, dá 854kg DIN
Acredito que o GT ande ali pelos 900kg, tendo em conta a sobrealimentação (acrescentar turbo, intercooler, etc...), e upgrades ao chassis.
Mesmo assim, já deverá ter performance espirituosa.
O chassis também tem sido elogiado pelos media mais dados à dinâmica, pelo que promete ser uma criaturazinha espevitada.
Esperemos que a Fiat atravesse-se com um Panda Twinair de 105cv para substituir o Panda 100hp, e temos o ramalhete montado[:D]
Alemanha: Volkswagen lança o Eco-Up!
Un nuevo integrante acaba de llegar a la familia del Up!. Bajo la denominación Eco-Up!, Volkswagen comienza la comercialización en los principales mercados europeos de la variante capaz de usar gasolina sin plomo y gas natural CNG indistintamente. Lo que desconocemos es su posible fecha de llegada a España.
El VW Eco-Up! recurre a la motorización de un litro de 75 CV para la adaptación. Usando el gas la potencia se reduce hasta los 68 CV y desarrolla un par máximo de 90 Nm. La velocidad máxima, de 164 km/h, también es algo inferior a la del modelo convencional. El consumo medio es de 2,9 kg/100 de gas (79 g/km de CO2), una cifra muy contenida que permite realizar esos 100 km por algo menos de 3 € (al menos en Alemania). Para almacenar el nuevo combustible, hay dos tanques con una capacidad total de 72 litros. El de gasolina se reduce hasta quedarse en sólo 10 litros de capacidad.
Los precios recomendados en Alemania son:
  • 1.0i 12v 68 CV Take Up! 12.950 €
  • 1.0i 12v 68 CV Move Up! 13.750 €
  • 1.0i 12v 68 CV High Up! 15.575 €
  • Carrocería de cinco puertas, 480 € adicionales
Volkswagen Eco Up! nomeado veículo ecológico do ano
O citadino híbrido alemão - tanto pode utilizar gás natural como gasolina - resultou de uma colaboração entre Volkswagen e Bosch. Esta última é também responsável pelos sistema de injecção utilizados neste Up! amigo do ambiente. Quanto às emissões poluentes, estas não ultrapassam as 79 g/km de CO2
Apesar da reduzida procura automóvel no mercado europeu, as construtoras do velho continente apostam como nunca em carros ecológicos. É certo que as vendas não acompanham os níveis de produção, sobretudo pela ausência de incentivos comunitários e governamentais à compra destes veículos, mas o reconhecimento do seu esforço continua a surgir em toda a parte.
O maior exemplo disso será a eleição do Volkswagen Eco Up! como automóvel ecológico deste ano, num concurso desenvolvido pelos alemães da VCD, uma organização ambiental que procura tornar visível o que de melhor as construtoras fazem pela mobilidade sustentável.
Quando ao citadino híbrido, este resulta de uma colaboração entre as marcas Volkswagen e Bosch, sendo o único veículo do mundo capaz de utilizar gás natural e gasolina enquanto combustíveis. Nesta joint venture germânica, a Bosch desenvolveu os injectores do Up! ecológico, mas também sistema de gestão do motor, sensor de temperatura de média pressão, controlo de airbag, unidade de limpeza e alternador.
O pequeno Eco Up! consome apenas 2,9 kg de gás natural por 100 km, o que se traduz em apenas 79 gramas de emissões de CO2 por quilómetro.
Poderá chegar também ao Mii e ao Citigo.
Volkswagen trabalha num motor 0.8 TDI para o Up! com dois cilindros
Parece que Volkswagen rectificará su estrategia para el segmento A y contemplará un motor diésel para los pequeños
Up!, además de los Mii y Citigo. Este nuevo bloque se encuentra en desarrollo y debería estar listo para ver la luz a lo largo del año que viene.
Pese a que los nuevos 1.0i de gasolina son bastante frugales, en ciertos países como Francia, Italia y España los clientes se interesan más por los diésel. De ahí que Volkswagen quiera seguir creciendo y para ello contará con un pequeño 0.8 TDI con sólo dos cilindros. Por ahora no hay demasiada información, aunque se dice sus consumos serán realmente bajos (rondando e incluso rebajando los 3,0 L/100).
El nuevo motor será compatible con todos los modelos de la "New Small Family", incluyendo la versión de producción del Taigun visto en Sao Paulo. Con este motor se estrenará una nueva entrega de bloques downsizing entre la que también se contempla la llegada del 1.0i de tres cilindros al Golf y otros modelos con la plataforma MQB, aunque eso sí, con más potencia y posiblemente sobrealimentación (recuerda que el 1.0 TSI del Taigun desarrolla 110 CV, así que no debería ser problema). Este bloque será la respuesta al Ecoboost de un litro instalado en los Focus.
Segundo a Autohoje o mini-SUV da VW com a plataforma NSF do Up! e companhia,concept Taigun (não encontrei tópico acerca dele), será construido em Palmela na Autoeuropa. A ser verdade é uma boa noticia para os trabalhadores da fábrica e empresas dependentes da Autoeuropa e também para nós portugueses e/ou amantes dos automóveis.
Volkswagen cria a variante SUV do seu mini: novo Cross Up!
We will have the opportunity to see the all-new Cross Up! in the flesh at next month's 83rd Geneva Motor Show , but Volkswagen wants the world to get an early glimpse of its rugged-looking city car that will go on sale across Europe, and possibly other regions as well, from late summer, with the release of the first official photos.Not that we didn't know what the crossover version of the Up! would look like as VW had previewed the car through a concept model at the 2011 Frankfurt motor show. The only change made over the study is the addition of protective black moldings with the name of the car on the lower part of the doors.
Power comes from the same 74hp (75PS) three-cylinder petrol engine connected to a five-speed manual gearbox driving the front wheels as the regular Up!, with the car gaining an SUV-themed exterior through the use of black body cladding for the bumper surrounds, side sills, and wheel arches, plus silver roof rails and bumper trims. A new set of 16-inch alloy wheels shod in tires size 185/50 completes the look.
VW makes no mention of any changes to the car's suspension or traction control system in its initial release.
The interior of the Cross Up! is spiffed up with unique seat trim available in red or dark grey with a matching dashboard finish, leather wrapped steering wheel, gear knob and handbrake, plus chrome trims for the vents and speedometer as well as the door sills.
In Germany, the new Cross Up! will have a starting price of €13,925 (equal to US$18,600 and £11,800 at today's currency rates).
