Ameaça séria???
Vejamos:
Serão mesmo comparáveis????
Ameaça-se alguem com maior cilindrada, mais cilindros, mais consumo, mais emissões e maior preço (R8 vs Carrera)?
Tiveram que construir um "super-carro" para tentar destronar um "super-desportivo" que se pode guiar no dia-a-dia, subir passeios, pisar buracos, levar o puto á escola... e mesmo assim andar muitissimo depressa quando o for "necessário".
[] Automobilista, antes de mais lê esta revista se puderes:
ou lê isto
http://www.autoexpress.co.uk/carreviews/grouptests/208580/audi_r8_v_rivals.html
1st Audi R8
2nd Porsche 911
3rd Aston Martin V8 Vantage
4th Jaguar XKR Coupe
VERDICT
Unfortunately for the Brits, neither can challenge the German dominance of this sector. The Jaguar XKR doesn’t move the game on far enough from the XK to become a top-level sporting machine – it’s simply too comfortable and quiet. The Aston Martin is more convincing. It’s expensive, but its exclusivity, air of controlled aggression and balanced chassis make it a tempting option.
Yet it’s not as well finished as the German pair – either in terms of cabin trim or suspension tuning. The Porsche is the polar opposite of the Jag – it’s firm and feisty, yet it remains the easiest to live with on a daily basis. But its plain cabin, costly pricing and sheer familiarity undermine the vivid driving experience, allowing the Audi R8 to nip through and claim victory. Brilliant to drive, stunning to look at and wonderful to own, Audi’s first supercar is a masterpiece. The only question that remains is why it took the firm so long to build it in the first place.
That’s true of the handling, too. The R8 is enormously capable and user-friendly, with scarcely believable amounts of grip. None of its rivals, not even the 911, could keep pace on tight, twisting roads. However, it doesn’t have quite the same involvement of the scalpel-sharp 911, and its responses are slightly numb in comparison.
This is a small price to pay for a car with such awesome body control and delightful steering, while the ride quality is little short of astonishing, thanks to the £1,350 Magnetic Ride dampers.
e tens aqui mais:
http://forum.autohoje.com/showthread.php?t=23342&page=9
etc...
Se calhar a tua cabeça está errada, fazes uma comparação simplória com números, é bem mais do que isso, contrarias tudo e todos os que conduziram, é um carro excelente no uso no dia-a-dia, com um interior de alta qualidade e espaçoso e ao mesmo tempo excelente em pista capaz de bater carros mais potentes, conjugar isto tudo é uma obra-prima como eles dizem.Tu pensas pela cabeça dos Jornalistas... eu penso pela minha!!!
Tu achas normal considerar uma grande vitoria quando se trata de um V8 4.2 atmo. contra um H6 3.8 atmo... eu não!!!
Mas tu nunca tiveste a oportunidade de conduzir nenhum...
Até parece que se está a falar de uma análise do JC [] ...vai dai foram todos comprados pela Audi...bandidos!
oh rapaz...nao percebes que a VAG controla todas as revistas Europeias?[]
Ameaça séria???
Vejamos:
Audi R8 4.2 Quattro - V8 4.163cc Central
Carrera 4S - H6 3.824cc Traseiro
911 Turbo - H6 3.600cc Traseiro
R8 - 420cv
Carrera - 355cv
Turbo - 480cv
R8 - 430Nm
Carrera - 400Nm
Turbo - 620Nm
R8 - 4x4 6 vel.
Carrera - 4x4 6 vel.
Turbo - 4x4 6 vel.
R8 - 1560Kg
Carrera - 1475Kg
Turbo - 1585Kg
R8 - 2L
Carrera - 2+2L
Turbo - 2+2L
R8 - 301 Km/h
Carrera - 288 Km/h
Turbo - 310 Km/h
R8 - 349gr/Km CO2
Carrera - 285gr/Km CO2
Turbo - 307gr/Km CO2
R8 - 4,5" 0-100 (medições)
Carrera - 4,6" 0-100
Turbo - 3,9 0-100 (fabrica)
R8 - 4,8" 60-100Km/h 8,6" 80-120Km/h
Carrera - 5,4" 60-100Km/h 8,6" 80-120Km/h
Turbo -
R8 - 34,5m 100-0
Carrera - 34,3m 100-0
Turbo -
R8 - 15,4L/100
Carrera - 13L/100
Turbo - 12,8L/100
e agora um pormenor... o preço
R8 - + 150.000€
Carrera - + 120.000€
Turbo - + 170.000€
Recentemente li na EVO um comentário de alguém que comparava estes dois carros em termos do que representam/representaram na sua época.
São os dois prodigiosamente bons concebidos com motor central e outras excelentes principios e ambos partilham do facto de pertencerem a marcas que no sector onde estes carros concorrem/ concorreram não têm grande força, ou seja estão-se a por em bicos dos pés
O que acham ?
olha que não é pelo motor ou performances numéricas que o r8 ganha.
conv´´em ler os textos.
ainda só li o da EVO e a questão anda sempre à volta do feeling e dinâmica.
Parece que a audi bateu a porsche no seu proprio campo.
mas o 911 não passou de bestial a besta... longe disso. Só que o r8 suplanta-o em alguns aspectos.
quanto à questão da utilização diária, essa é também uma das maiores vantagens do r8. Pelo que se tem lido
Aonde é que leste isso?!Com a quantidade de componentes que partilha com os A3, A4 e TT tinha que ser um carro utilizavel. O concorrente dele é o 911 Turbo e não o Carrera S. E ao 911 Turbo não faz mossa.
Quanto ao Porsche 911 Turbo, também pode fazer qualquer coisa ver teste da Car&Driver
e Popular Mechanics...
O motor V8 tem carter seco em relação ao do RS4, o volante e os supostos comandos é que torna o carro usável???!, isso tem a haver com suspensão, chassis, etc. e o Audi R8 neste momento é quem conjuga isso melhor .Volante do TT, motor que é do RS4, comandos A3 e A4.
No fundo o que se trata aqui, é ser contra Grupo VW..., o R8 não é construido com componentes de gamas inferiores, se leres até a direcção tem um "feeling" que nenhum outro Audi tem, os factos estão aí mas quando não se quer aceitar...Eu disse isso no sentido de tentar "provar" que um R8 que é construido com componentes de gamas inferiores nunca vai ser uma ameaça para Porsche e Ferrari.
O R8 agora é novidade. Qualquer coisa nele é uma vantagem.
A verdade é que ele não foi feito para se utilizavel. Foi feito para pistas e não para ser confortavel.
O Grupo VW vai é bater no fundo se sair o Gallardo com esse motor ou o R8 diesel.
