[h=1]Has Ferrari truly overpowered Mercedes?[/h]By
Vanja Hasanovic on Tue Sep 04, 2018 6:00 pm
F1 Grand Prix, GP Italy, Autodromo Nazionale di Monza
While a large number of reports claim Ferrari extracts more power than Mercedes from their Power Unit, reality proved things to be very different in Monza.
In 2017,
Ferrari showed solid improvement with their Power Unit (PU) from 2016 and this continued throughout 2018. However, Mercedes was in front since 2014 and they kept improving just as much. At the beginning of this season, Mercedes claimed power equality between them and
Ferrari, only to claim
Ferrari surpassed them a few races later. This was almost instantly and universally accepted by general F1 audience, media and other teams.
In late 2017, Mercedes announced their PU surpassed the magical mark of 1,000HP, while
Ferrari did so a few months later. It was reported that peak power difference between these two Power Units was 15-20HP in 2017, which would have very likely been the smallest difference since 2014. The fact Mercedes was first to reach 1,000 HP suggested to us that this difference remains.
Since early in the season, controversy surrounded the
Ferrari PU, leading to a FIA investigation which lasted a few races. The investigation included special FIA equipment aboard
Ferrari powered cars, which acquired additional data for FIA to asses if any breach in Technical Regulations has occurred. Controversy was sparked by Mercedes enquiry into
Ferrari PU (which is why the FIA investigated the red team) and their regular claims of sudden bursts of power from Ferrari-powered cars.
That
Ferrari was under the spotlight was a big difference from previous years. Especially concerning the PU advantage Mercedes held since current the start of V6 Turbo Hybrid era. Many tracks can be described as power-hungry, but none is more so than the famous Monza circuit, which hosted the Italian Grand Prix this weekend. The defeat of Mercedes in Spa lead to a number of claims that
Ferrari will have it an easy time in Italy, only strengthening the claim of
Ferrari power supremacy.
Ultimately, we asked ourselves – is this truly the case?
Monza is famous for the lowest downforce and drag configuration of F1 cars in every season and 2018 was no exception. Our
early analysis of Top 3 F1 cars in 2018 pointed to a number of areas
Ferrari improved to lower their car’s aerodynamic drag, whilst increasing overall downforce levels. Add their alleged power supremacy into the mix, and the Italian GP was expected as a walk in the park for
Ferrari. Things have unravelled very differently, though.
Since Thursday, early pictures of the cars in the paddock revealed a difference in rear wing levels between
Ferrari and Mercedes. As Friday in Monza was mostly a wash-out, a truly relevant comparison between the two cars could only be made be onwards from Saturday. The difference in wing levels was evident, as can be seen on Figure 1.
Figure 1 – comparison of 2018 Ferrari and Mercedes F1 cars in Monza, photo credit James Moy
Mercedes car featured a relatively large “scoop” rear wing design compared to
Ferrari’s simplistic flat rear wing. The advantage of such scoop design is a reduction of induced drag from rear wing tip vortices, while maintaining a larger angle of attack in the middle. This design is generally used on cars that have enough power to overcome the increased pressure drag (compared to low angle of attack and flat wing design). The difference in front wing design of these cars is a trait of
Ferrari since last year, as red cars usually feature a drop in the middle of their wings, highlighted in green on Figure 1. Both these features suggested
Ferrari went for a lower drag configuration than Mercedes and it was expected to see them quite a bit ahead in the speed traps.
Figure 2 – speed trap data from Saturday’s qualifying session, courtesy of FIA
On Figure 2 we can see Mercedes was, in fact, just slightly ahead of
Ferrari in the speed traps, while crossing Intermediate lines showed some small changes. Overall, this showed there was little to choose from between these cars in terms of top speed. Lap times showed this was in fact the case in corners as well, as red and silver cars exchanged fastest sectors regularly in Q3. Speed trap data from the race is skewed by DRS combined with tow from the car in front, which is why it shouldn’t be taken into account. Highlighted on Figure 3 is the difference in height of the scoop on Mercedes wing, along with the difference of front wing height in the middle.
Figure 3 – comparison of Ferrari and Mercedes cars during the race, photo credit James Moy
Aerodynamic drag is a function of dynamic pressure, reference surface area and drag coefficient. This coefficient, on the other hand, is a function of car geometry. The reference surface area is directly proportionate to the overall aerodynamic force. For drag, frontal area is the most important aspect – which was significantly smaller on
Ferrari in Sunday’s race.
The drag coefficient of wings is mostly a function of angle of attack, wing chamber and wing chord. While camber is hard to asses with relative certainty, angle of attack is easier to evaluate. Due to the scoop, the average angle of attack on Mercedes' rear wing was larger than that of
Ferrari's. This strongly suggests Mercedes rear wing had a bigger drag coefficient than
Ferrari’s counterpart.
On the other hand,
Ferrari car has a raised rear ride height, which increases the overall car frontal area. However,
Ferrari is also strikingly slimmer in the side pod area, has smaller (frontal) radiator intakes and features less vortex-inducing surfaces on the car compared to Mercedes. It is, therefore, safe to assume
Ferrari had less drag than Mercedes at Monza.
How can we analyse this and put some numbers forth?
Aerodynamic drag is the largest load cars have to deal with before reaching top speed. Compared to drag at top speed, rolling resistance of tyres is negligible. Hybrid power units of modern F1 cars now reach peak power of over 1,000 HP, or roughly 750 kW. Electric power, delivered to MGU-K is limited by rules to 120kW at 95% theoretical efficiency. This means teams probably use a bit more than 120kW if they are over this 95% efficiency (and reports would suggest so).
We can analyse power required to overcome aerodynamic drag by introducing a few assumptions:
- Pa (Power required to overcome drag) is around 600kW (peak power without MGU-K, taking drive train efficiency into account)
- v (maximum velocity) is 95 m/s (342 km/h, which is what speed traps suggest)
- Air density () is 1.2kg/m3, according to ISA
Power spent to overcome drag is
According to it,
Cd is
Increasing drag by 1% requires 1% more power
6kW is roughly 8 HP and if the peak power difference stayed the same from last year (roughly 15-20HP), this would suggest Mercedes had around 2% more drag on their car. With such a big difference in wing levels, 2% is a very plausible difference in overall drag levels between
Should we assume reports suggesting
Ferrari's PU is stronger than Mercedes' are wrong?
Not at all. As ever, wording is very important in F1, as teams do not wish to reveal any more information than is required when talking to the media. While Lewis Hamilton claimed multiple times
Ferrari's PU is more
powerful, the wording of Toto Wolff is far more subtle. According to him,
Ferrari's PU is
stronger.
This can mean a number of things, including peak power. Our recent analysis showed that this is not the case. Deeper insight into
Ferrari’s supremacy revealed they are using electric energy for a longer period than their opponents in the early acceleration phase – corner exits.
This was highlighted by Lewis Hamilton post-race analysis in Spa, where he suggested
Ferrari has better traction and acceleration coming out of corners, while their PU is also able to “pull” for longer than others and reach higher top speeds (it should be noted
Ferrari had a lot less angle of attack on their wings in Belgium, similar to Italy). With fewer slow corners at Monza compared to Spa, he expected a better race in Italy – which was exactly how the Italian GP unravelled for him.
