Alfa 4c
2014 Alfa Romeo 4C First Drive - Motor Trend
Do you even care? Honestly, if I told you the 2014 Alfa Romeo 4C drives like a 1983 Dodge Diplomat on bald tires, would it really make a difference? After all, Alfa told us that the 4C has “more to do with the heart than with the brain.”
I believe they mean that girls this gorgeous can be Miss Teen South Carolina dumb, because just look at her! I have teeth marks on my fist after a full day spent gawking at the car marking Alfa Romeo’s return to the U.S. after the brand packed up the espresso machines back in 1986. The 4C’s so hot that if the Fiat Group had decided to slap “Dino 246” on the rump next to a yellow shield filled with a prancing horse, car enthusiasts the world over would still be nodding their collective heads yes. She’s a total dreamboat, my friends, and I even dig the headlights. As for the rest of the car, keep reading.
Before I get to how the 4C drives, let me tell you what she is. The Fiat Group first started working on the concept in September of2010. Reaction to Alessandro Maccolini’s design at the 2011 Geneva show was so strong that just two years later I’m driving the production version. The first cars will arrive at European dealers in October.Manufactured by Maserati in Modena to be sold through Maserati dealers in the U.S., the new 4C is principally light, though not quite as light as Alfa is claiming. Italian carmakers have this horrible habit of weighing cars without certain fluids—oil, gas, coolant, transmission and brake. They also tend to leave out airbags. The result is a meaningless number they call “dry weight.” Alfa claims the U.S.-spec 4C will weigh 2083 pounds (the Euro version will weigh about 100 pounds less because of no side or knee airbags, no A/C, and a fixed, non-sliding passenger seat). I’m here to tell you that the 4C’s actual weight is going to be closer to 2500 pounds, if not more. Alfa’s number is pure fantasy, and besides, 2500 pounds is really light these days. That’s about what a Fiat 500 weighs.Why so light? Materials. The entire body is made from SMC (sheet-molded compounds, the new way to say fiberglass) and the use of steel has been kept to an absolute minimum. There’s also heavy use of carbon fiber, no pun intended. Alfa says that 25 percent of the vehicle consists of carbon fiber but that the ultra-strong, light composite material only accounts for 10 percent of the vehicle’s weight. The entire monocoque is said to weigh just 143 pounds. (For reference, the McLaren 12C’s carbon fiber-tub reportedly weighs 165 pounds.) Moreover, with an expected price of $54,000 when the 4C arrives in America in May, 2014, the lithe little Alfa is around $200K cheaper than any other car with a carbon-fiber center and aluminum subframes. Aside from the McLaren, other cars constructed this way include the Lamborghini Aventador, Pagani Huayra, and Bugatti Veyron.
Under the back glass sits a transverse, mid-mounted, thoroughly reworked all-aluminum version of the Giulietta’s 1.7-liter, turbocharged, direct injected inline-four that produces 240 hp and 258 lb-ft of torque. That may not sound like much, but with Mazda Miata-like weight and a quick-shifting, six-speed, dual-clutch transmission, she flies. From behind the wheel the 4C feels particularly potent. Eighty percent of the torque is available from 1800 rpm, and this car’s mid-range kick is surprisingly strong. Alfa claims 0-62 mph happens in 4.5 seconds and a trip around the Nürburgring is 8:04 minutes. Give us a few months and we’ll get you some actual numbers, plus a Randy Pobst-piloted Laguna Seca lap. The engine makes a lot of noise – the DI pump sounds like a sewing machine, there’s a constant whoosh from the turbo and/or blowoff valve, and another from the snaking intake pipe. You should see how they crammed it in back there. Plus, the dry dual-clutch makes a loud clack when you really start banging off the shifts. The combined result sounds like a mini-Veyron, a little steam-powered factory. Sure, a tiny twin-cammer that revs out to 8000 rpm would sound better, but the world has changed. As I discovered, opening the window clears most of it so that all you mostly hear is the exhaust note, which I’ll discuss in a bit.The best part of the 4C is the hyper-accurate steering. It’s neither hydraulically nor electronically assisted. There’s no power steering! Not only does this save weight, but there’s no better way to get more direct steering feel. Your muscles are turning the wheels, which naturally requires a bit of effort at parking-lot speeds. However, once you get up to a couple of miles per hour, the car’s easy enough to maneuver. Since there’s no variable rate nonsense, the steering is refreshingly linear. Yes, the car tramlines a bit (follows grooves in the asphalt), and as a result the helm feels busy. There’s no on-center point caused by the position-related deactivation of the power assist most cars have. But so what? Essentially every other car on sale has layers upon layers of insulation masking what the front wheels are rolling over. You can read manhole covers with the 4C. Moreover, the car just feels more alive, more nimble, more sporting. I love it.The Brembo brakes are also phenomenal. On the never-ending track I kept finding myself whoa’d down a full 100 meters earlier than I should have been. While relatively small (12 inches up front, 11.5 in back), with such a light vehicle you don’t need massive disks. Besides, smaller rotors reduce overall and unspring weight. In the interest of weight savings, Alfa even specified aluminum hats mounted inside cast-iron rotors.
Combine the natural, feedback-filled steering with a snappy, flexible powertrain, gluey brakes, and a low curb weight, and friends, you nearly have a winning recipe. All you’d need further at this point is a racy suspension, and boy howdy does the 4C deliver that. Double control arms and F1-style angled springs and dampers up front, coupled with a MacPherson strut-type rear, combine to make the most of the mid-engine coupe’s natural balance. The ride is rough but not brutal— sports car fans will dig it. I was surprised by how much support and bump absorption the thin, lightweight seats provided. They hold you in place real well, too. There’s a four-position stability and traction-control system that starts with Alfa Romeo’s now standard DNA selector (Dry, Normal, All-weather) and adds in a fourth mode activated by holding D for five seconds, called Race. As you may imagine, in Race every bacon-saving algorithm is switched off. However, as the 4C’s so neutral and balanced to begin with, you really have to do dumb things/overcook corners to get it to misbehave. Dynamic mode increases the throttle response and makes the shifts more aggressive. (Alfa claims 130 milliseconds to swap cogs.) On the street in Dynamic mode I never had the TC light flicker, and only once on the track. Only track rats will ever need Race, because the 4C is a car with Lotus Exige-style moves minus the torture chamber ergonomics.Speaking of ergonomics, it’s sparse inside. Appreciably so. While small, the 4C is far from cramped. Two full-size adults fit comfortably in the sporty buckets and there’s a Ferrari 458-esque amount of space between your right knee and anything. There’s also perhaps the best dead pedal in the business, a purposeful-looking solid aluminum lump. Couple that with a beefy, flat-bottomed steering wheel and you have an incredible perch from which to attempt your best and do your worst. Creature comforts are few and far between, but the A/C blows cold (it’ll be standard in U.S. cars), there are two cupholders, and there’s even a beeping parking sensor for when you go into reverse. You really need that last bit, as you can’t see a damn thing in the rearview mirror. There was also what appeared to be a radio of some sort, but the thought of turning it on never crossed my mind.
Of particular note inside is the central tub’s exposed carbon fiber. Unlike most cars, which want to show off their CF intensity by wrapping either the mirrors or the front splitter in carbon, in the 4C you’re seated in the actual business. It’s captivating, and frankly the first time I’ve liked exposed carbon on a car’s interior. Speaking of captivating, I wish you all could stand behind the 4C’s sport exhaust as it goes wide open. What a glorious devil’s trombone of a noisemaker. Alfa, I implore you, bring on the roadster, which would be easy to do because of that super-stiff carbon-fiber tub. McLaren claims that it experienced no loss of stiffness when cut off the 12C’s roof, and Alfa said the same would be true with the 4C. However, try as I might I couldn’t get them to admit that they’re working on a 4C Spider, though they’d be tone deaf not to. The hard part will be figuring out where to stick a folded top. The sport exhaust is an option, though it will be standard on the Launch Edition 4Cs. Either way, check that box.I liked playing on the Fiat Group’s historic Balocco proving grounds and the semi-rural, semi-curvaceous routes we drove west of Milan. But I kept dreaming that the 4C was back in California on stretches of canyon I have memorized. We spend a lot of our time talking about great driver’s cars, and Alfa Romeo has gone and built one. Which is both wonderful and crazy, as there wasn’t a real need for the first U.S.-bound Alfa Romeo in a generation to be any good. All it needed to do was show up looking like a cross between the Giulia Sprint Speciale and the Tipo 33, and Alfa would have no problem moving the 1000 units per year or so destined for our shores. Instead what they’ve gone and done is created a delightful all-singing, all-dancing fizzy Italian alternative to the clinical and dare I say sterile-by-way-of-comparison Porsche Cayman. That’s how good the 4C is. The only bad part is that we have 8 more months until the 2014 Best Driver’s Car competition. Hope I can hold out that long.
Crash: as unidades não é tão simples como isso, pois se a gente critica os Anglo Saxónicos pelas suas medidas, repara que nas jantes por exemplo, usamos as polegadas também.
E se formos ser rigorosos as Horas, o Tempo é dividido em 24-60-60 e só depois passa a centesimal [:)]
Os pesos quer em kg, quer em Libras, devem ser sim regulamentados, mas eu pessoalmente não concordo que se incluam as pessoas no peso.
Tudo menos as pessoas, porque podem ter pesos muito diferentes e irem em vário número dentro do carro, por isso deixaria de fora, precisamente para ser apenas preciso somar quem lá estiver dentro.
Mas penso que assumem condutor = 70 ou 75 kg né?
Quanto ao resto... bem, vivemos numa união até económica, mas com impostos completamente diferentes.
E o pior, há uma falsa liberdade.
Se podemos comprar um pacote de chiclas em Espanha, porque não um carro = Preços únicos para toda a União Europeia. Topas?
Ora bem, depois destas reviews todas, acho que já é seguro manifestar a minha opinião, apesar de achar, como outros, que o verdadeiro teste será contra os seus concorrentes.
Para já, acho que sim senhor. A Alfa está de parabéns, fez um excelente carro, perfeitamente adequado ao que, aparentemente, se propunha.
Discordo com essa história do "regresso da Alfa com o 4c". Isto porque desde há uns 20 ou 30 anos que leio esse tipo de coisas... A cada novo modelo é "o regresso da Alfa". Já chateia. A Alfa tem feito bons modelos, uns melhores outros piores e não representam o "regresso" a nada, são só o continuum de uma marca centenária. O "regresso" é só mais uma forma de vender papel.Quanto ao carro propriamente dito... Gosto. E muito. Não tenho dinheiro para ele. Por isso (por não ter dinheiro) vou agarrar-me àqueles que são os seus maiores defeitos (para mim)... Não tem caixa manual e faltam-lhe dois lugares traseiros. O motor também o trocaria por um V6 mas percebo a coisa e aceito o 1.8 turbo.
Espero que haja mais.
Não só quanto à filosofia específica do carro mas, principalmente, quanto à filosofia genérica do mesmo, ou seja, algo diferente, carregado de tecnologia, rápido e no topo do seu segmento... Em cada segmento e com preços correspondentes...
Gostava muito de ter um mas cheira-me que vou ter de esperar pelo novo Dueto para contemplar a hipótese de ter um novo Alfa na garagem.
Make no mistake: The Alfa 4C is not a luxury performance car. This is a loud, raucous pure sports two-seater. While a first glance may indicate the Porsche Cayman is a logical competitor, the reality is the Alfa is in a class by itself. It's more livable than a Lotus, but lacking the luxury feel that a Porsche buyer is accustomed to. More likely the 4C is going to appeal to a unique buyer, a track-day or autocross enthusiast getting a second or third car to supplement a more accommodating daily driver.
Read more: 2014 Alfa Romeo 4C test drive, review, specs, price and photo gallery - Autoweek
A bold uma opinião que foi avançada neste tópico e que foi alvo de duras críticas.
Confesso que as reviews têm saído mais positivas do que eu imaginava. A Alfa estava mesmo a precisar de um balão de oxigénio destes!
Agora espero que o serviço de venda e pós venda, bem como os próximos modelos, não deitem tudo a perder (tenho expectativas moderadas...)!
É verdade.
Mas como percebes pelo que se ia sabendo, não era difícil de acreditar que realmente não seria bem igual a nada que já havia.
Julgo que parte da resposta está na mais do que importante e decisiva aposta na célula central e fulcral em Carbono.
Sendo um carro "em Carbono" tinha muito para ser algo fora do comum e do que há de momento.
Por acaso eu estava precisamente a imaginar as reviews tal como têm aparecido.
Excepto a questão levantada por um tipo da Top Gear em que fez passar a ideia que o motor "parecia nem ter os 240cv" metendo pelo meio uma questão de altitude.
Ninguém mais teve essa opinião, pelo contrário.
O que eu talvez estivesse a contar é que o carro fosse mais "quebra costas" do que parece ser (até agora descrito pelas reviews).
Eu sou sincero, não esperava tanto.
Não é que os ingredientes não estejam lá, mas nem sempre os melhores ingredientes fazem o melhor bolo.
Eu estive sempre reticente - aliás como já disse - devido ao facto de ser um tipo de carro que a Alfa não faz há décadas.
Mais é gratificante ver que a Alfa Romeo tem o know how para saber vingar neste tipo de conceito.
O jornal The Telegraph dá pontuação máxima ao 4C: 5\5!
"Worth the wait. Stunning looks and scintillating performance make it a genuine supercar, matched with an everyday useability and a tempting price "
Alfa Romeo 4C review - Telegraph
"it will be remembered as one of the greatest sports cars of the age"
Mais uma vez é de perguntar que "raio de carro" a Top Gear ensaiou em "altitude"?
Nota: uns tempos atrás estavam sempre a passar por este tópico alguns "profetas" a pedir reviews independentes, credíveis, etc.
Já há meia dúzia, assim como vídeos.
Pergunto: já estarão satisfeitos? [:D]
Andam desaparecidos.
Eu tive a oportunidade de ver este carro ao vivo no fds e confesso que, em termos de estéctica, fiquei completamente babado. O carro é lindo. Em termos de tamanho, concordo completamente com quem diz que estará entre um Elyse e um Cayman. Do que vi do interior, achei igualmente fantástico, com o painel de instrumentos a faze lembrar os F1. Houvesse €€€ aquando do lançamento do cabrio e ainda fazia uma estupidez. Acho que o motor 1.8 assenta que nem uma luva. Parabéns à Alfa!!! Não sentia um entusiasmo destes pela marca desde que lançaram o SZ e o 8C. Lá em casa houve um 75 1.6 I.E. (107cv) e adorava o comportamento daquela tracção traseira. Produzindo carros mais leves, com melhores motores e tracção traseira, a Alfa acho que seria a única contender da BMW no comportamento...talvez o Giulia.
A indignação da malta aqui do Forum aparenta ter surtido efeito. A notícia já foi corrigida no peso e nos materiais. [:D]
“O Alfa Romeo 4C é um desportivo de motor central traseiro, um quatro cilindros turbo de 241 cv. Construído em materiais leves, como o alumínio e fibra de carbono, pesa apenas 895 kg (sem condutor) e mede praticamente quatro metros de comprimento“
In: Autohoje - Alfa Romeo 4C custa 65.000?
Vá lá.
Mas custou, foi por partes [:D]
Pelo menos corrigiram.
Desta vez, não há chapa Russa nem se corre o risco do motor se tornar "gastador".
E a parte laboral, não está fácil, mas não como nos 70's e está entregue a gente mais especializada.
Agora já pesa 895kg? Que raio de jornalista há na AH que pesa 355Kg?
