Kit_Bluetooth_FISCON
Volkswagen / Skoda Infotainment System
RNS-510 / RCD-510 / Columbus
With a FISCON Pro Bluetooth handsfree, the Volkswagen and Skoda infotainment system with touchscreen allows for these functions:
Vehicle IntegrationOperation from the Touchscreen of the Navigations System.Complete integration into the Navigation System with comparable Logic and Design.Displays Data on the FIS-Screen.Menu-driven operation.Establish, accept and end calls. Mute, regulate volume and numerous setup functions. Everything is operable with the existing buttons in the vehicle.Voice output through the vehicle speakers. With distinguished sound quality, no installation of additional speakers is necessary.Operation via the buttons on the multifunction steering wheel (where available).Usage of the ring-tone of the cellphone*1 on the vehicle speakers.Display texts available in the languages English, German, Spanish, French, Italian, Durch, Portuguese. A lot of other languages are partially supported.All original functions of the vehicle remain unaffected.*1If supported by the cellphone.
Phone FunctionsSynchronisation of the Phonebook with Names and Numbers.*1Access to call lists, including dialed and missed connections.*1Shows incomming calls with Names records of the Phonebook*1. Option to accept or decline a Call.Up to 5 cellphones can be connected.Digital sound processor with echo and noise depression.Adjustable microphone amplification (to 30db) to optimize voice quality.Alphabetic search of phonebook records.Display of the phone provider and the signal strenth (when supported by the cellphone). Mailbox recallable from Navigation System*1If data are supplied by the cellphone.
InfotainmentShows digital data of the car like speed, boost pressure*2, fuel quantity, oil temperature, battery voltage, water temperature.*3Read SMS and reply with pre-defined texts (when supported by the cellphone). A2DP audiostream via Bluetooth, for playing music stored in the cellphone on the vehicle sound system.*1AVRCP control of the music on the cellphone, using the buttons of the vehicle.*1*1A2DP or AVRCP must be supported by the cellphone.*2Only if the car provides boost pressure data. That data are available for all TDI engines. Not for Golf MK5 GTI.*3The advanced board computer is not available for cars with white FIS-display.
Hardware, Installation, MaintenancePlug&Play Adapter included.Uncomplicated installation. No cutting of wires necessary.Removes easily with no damage to the vehicle.Option for software updates.Standby power consumption is under 0,1mA (<1,2) Watt at 12V.
The integration into the navigation system is independent from the vehicle and is also feasible in vehicles where the navigation system is not integrated from factory. The display in the FIS screen and the operation with the buttons on the multifunction steering wheel or wiper lever are at present working in the following cars regardless of the radio or navigation system.
Displays Navigation System
Displays FIS Screen
Fonte: FISCON Bluetooth Handsfree
Price: $569.00
Existem 2 Versões Basic e Pro!
Alguém sabe alguém que venda isto (revendedor, nao encontro cá, devo ter procurado mal, ou senão alguém cá que monte e dê os toques no VAG)
P.S. Aquele painel, com os dados do oleo, litros de combustivel, temperatura do oleo e agua, e afins, não é possivel de o ter através de "uns toques" pelo VAGcom??
- Volkswagen Golf V
- Volkswagen Golf VI
- Volkswagen Jetta
- Volkswagen Scirocco
- Volkswagen Eos
- Volkswagen Touran
- Volkswagen Passat 3C
- Volkswagen Passat CC
- Volkswagen Tiguan
- Volkswagen Touareg GP (Facelift)
- Seat Leon 1P
- Skoda Octavia 1Z
- Skoda Superb II
Displays FIS Screen
Price: $569.00
