Tópico dos Pneus
Estou numa indecisão que gostava da vossa ajuda.
Já tinha referido na medida 205-55-16 os hankook k125 por 60€ cada.
Agora surgiu a hipótese dos Michelin primacy hp (os k faziam km á bruta) por 75€ cada com oferta de 10€ em combustível por cada pneu!
Gostava de testar os k125 mas com os primacy hp já sei o k esperar.
Quais escolheriam?
Quais escolheriam?
Para essa medida de pneus pode colocar o melhor do teste que foram os 1st: Hankook Ventus Prime 3 K125 http://www.tyrereviews.co.uk/Article/2016-AutoBild-Summer-Tyre-Test.htm
Total: 53 / Dry: 9 / Wet: 7 / Comfort: 7 / Rolling Resistance: 6 / Noise: 7 / Wear: 8 / Cost: 9
Positive: Very good on dry and wet roads, good value for money, accurate and quick steering response, very short braking distances on dry and wet roads, low wear
Negative: Average resistance to aquaplaning
Overall: Exemplary
Repara neste teste como os nexen hd plus sao superiores a esses BFGoodrich http://www.tyrereviews.co.uk/Article/2016-ACE-Mid-Range-Summer-Tyre-Test.htm
Outro em que entram esses Nexen
2016 ADAC Tyre Test - 185/65 R15
Much like the 225/45 R17 test ADAC published at the same time, the ADAC 185/65 R15 tyre test looks at sixteen premium and mid range tyres, but this time has selected tyres intended to be fitted to smaller town and city cars. The biggest surprise of the test was this time delivered by Vredestein, with the Sportrac 5 dominating the test, and beating the wet weather master Continental Premium Contact 5 in the wet tests. The Vredestein must have gone through a life cycle update, as in 2015 the best result it could manage was fifth overall, and over placed near the bottom of the tests it took part in.
The Dunlop and Goodyear combination of closely matched premium touring tyres once again traded blows in the tests to finish nearly identically overall in third and fourth places, while Hankook rounded out the top five with another balanced performance.
Nokian once again had a good result in sixth place, and Kumho finally had a decent test result, finishing seventh with no real negative qualities of the Eco Wing ES01.
Infinity will be proud they managed to beat Michelin, with the premium French brand pushing the balance between wet grip and wear too far towards wear for the ADAC testers, and Bridgestone struggled to balance wet and dry grip, scoring too highly in the dry, like Michelin losing points in the heavily weighted wet testing.
Full details below, if you have any questions or comments please feel free to leave them at the end of the page.
Results
Best tyre for dry roadsNexen N Blue HD Plus
Bridgestone Turanza T001
Best tyre for wet roadsVredestein Sportrac 5
The lowest fuel useMichelin Energy Saver Plus
The lowest wearMichelin Energy Saver Plus
The quietest tyreInfinity Ecosis
1st: Vredestein Sportrac 5
Total: 37.6 / Dry: 8.4 / Wet: 8 / Rolling Resistance: 7.8 / Noise: 5.4 / Wear: 8
Positive: Very balanced summer tyre with top marks on wet roads, very good in the dry
Negative: None mentioned
2nd: Continental Premium Contact 5
Total: 37.4 / Dry: 8.8 / Wet: 7.4 / Rolling Resistance: 8 / Noise: 5.2 / Wear: 8
Positive: Very balanced tyre with top marks in the dry
3rd: Dunlop Sport BluResponse
Total: 37.2 / Dry: 8.6 / Wet: 7.4 / Rolling Resistance: 8.4 / Noise: 4.8 / Wear: 8
Positive: Very balanced tyre, particularly good on dry roads, also strong in the wet and low fuel consumption
4th: Goodyear EfficientGrip Performance
Total: 35.8 / Dry: 8 / Wet: 7.8 / Rolling Resistance: 7.8 / Noise: 4.2 / Wear: 8
Positive: Very balanced tyre, strong in the wet and dry
5th: Hankook K425 Kinergy Eco
Total: 37 / Dry: 8.6 / Wet: 7.6 / Rolling Resistance: 8 / Noise: 5.8 / Wear: 7
Positive: Very balanced, particularly good in the dry
6th: Nokian Line
Total: 36.2 / Dry: 8.6 / Wet: 7.4 / Rolling Resistance: 8.4 / Noise: 4.8 / Wear: 7
Positive: Very balanced, particularly good in the dry, low fuel consumption
7th: Kumho Ecowing ES01 KH27
Total: 35.8 / Dry: 8.2 / Wet: 7.2 / Rolling Resistance: 7.8 / Noise: 5.6 / Wear: 7
Positive: Very balanced summer tyre, strong in the dry
8th: Sava intensa hp
Total: 34 / Dry: 6.6 / Wet: 7.6 / Rolling Resistance: 7.6 / Noise: 4.2 / Wear: 8
Positive: Strong in the wet
Negative: A slight weakness in the dry
9th: Infinity Ecosis
Total: 34.6 / Dry: 6.8 / Wet: 6.4 / Rolling Resistance: 7.4 / Noise: 7 / Wear: 7
Positive: low noise
Negative: A slight weakness in the wet and dry
10th: Michelin Energy Saver Plus
Total: 38 / Dry: 7.8 / Wet: 6.4 / Rolling Resistance: 8.8 / Noise: 5 / Wear: 10
Positive: Top marks for fuel consumption and wear, good in the dry
11th: Barum Brillantis 2
Total: 35.2 / Dry: 7 / Wet: 6 / Rolling Resistance: 7.6 / Noise: 5.6 / Wear: 9
Positive: Low wear
Negative: Weak in the wet
12th: Bridgestone Turanza T001
Total: 38 / Dry: 8.8 / Wet: 6 / Rolling Resistance: 8.6 / Noise: 5.6 / Wear: 9
Positive: Top marks in the dry, low fuel consumption
13th: Nexen N Blue HD Plus
Total: 35.2 / Dry: 8.8 / Wet: 5.8 / Rolling Resistance: 8.2 / Noise: 4.4 / Wear: 8
14th: Semperit Comfort Life 2
Total: 34.4 / Dry: 7.8 / Wet: 5.6 / Rolling Resistance: 7.8 / Noise: 4.2 / Wear: 9
Positive: Low wear
15th: Nankang Green Sport Eco 2
Total: 32.2 / Dry: 7.2 / Wet: 4.4 / Rolling Resistance: 7.2 / Noise: 5.4 / Wear: 8
Positive: None mentioned
Negative: Weak in the wet, high fuel consumption
16th: GT Radial Champiro VP1
Total: 28.6 / Dry: 5.6 / Wet: 1 / Rolling Resistance: 7.6 / Noise: 5.4 / Wear: 9
Positive: Low wear
Negative: Very weak in the wet and dry
[TD="colspan: 2"] Test Summary [/TD]
Overall: Exemplary
A questão dos hp era pq são conhecidos pela duração mas acho que vou experimentar os k125 e também fico com termo de comparação.
Há varios testes onde entram os Nexen e ate se pode ver ainda a review dos users consoante a medida do pneu como a titulo de exemplo:
http://www.tyrereviews.co.uk/Tyre-Size/16-Inch-Tyres/205-45-16-Tyres.htm
Mais um teste onde entram os Nexen N Blue hd plus (12th) com melhor resultado que os Ggrip (18th):
http://www.tyrereviews.co.uk/Article/2016-Summer-Tyre-Market-Overview-Braking.htm
Portanto conclui-se que para pneus de 2ª linha nada melhor que Nexen N Blue hd plus :)
Para um peugeot 308 1.6T com a medida 225 45 r17 que pneus aconselham ?
Para essa medida tens estes testes para escolheres os pneus de acordo como teu orçamento:
http://www.tyrereviews.co.uk/Article/2016-ADAC-Tyre-Test-225-45-R17.htm
http://www.tyrereviews.co.uk/Article/2016-GTU-Performance-Summer-Tyre-Test.htm
Melhor opçao:
1st: Continental Sport Contact 5
Total: 264 / Dry: 86 / Wet: 146 / Comfort: 8 / Rolling Resistance: 14 / Noise: 10
Cost: 390 euros
Overall: Highly Recommended
Opções ecomnomicas:
5th: Falken Azenis FK510
Total: 230 / Dry: 82 / Wet: 114 / Comfort: 8 / Rolling Resistance: 16 / Noise: 10
Cost: 300 euros
13th: Linglong Green Max
Total: 170 / Dry: 59 / Wet: 73 / Comfort: 8 / Rolling Resistance: 20 / Noise: 10
Cost: 220 euros
Por experiencia propria tenho 4 pneus linglong greenmax num opel corsa 1.3 cdti que cumprem bem a sua missao e tambem ja tive 2 pneus linglong greenmax no eixo dianteiro duma space star 1.9 di-d 2004 que fizeram perto de 57000km em dois anos sem razoes de queixa.
Nada melhor... salvo seja. [;)]
É uma opção a ter em conta, como é claro.
Melhor opçao:
Cost: 390 euros
Opções ecomnomicas:
Cost: 300 euros
Cost: 220 euros
Obrigado.
Vou optar pelos Continental
Boas
Comprei o carro com pneus 205/50 mas eles já estão a dar o berro e não são nada de jeito.
O livrete permite me usar também as medidas 195/50 e 185/55 e numa breve pesquisa reparei que a medida 195/50 era a que apresentava resultados mais baratos.
O que me recomendam nesta medida com uma boa qualidade-preço, tendo em conta que provavelmente comprarei online ?
Boas
Qual é o tamanha da jante?
Pessoalmente uso na medida 195/55/r15 os Nexen Nfera SU4 no eixo dianteiro com 9000km rodados e sem quaisquer problemas conforme fotos que ja aqui coloquei e voltava a compralos outra vez.
Se procura por 195/50/R16 tem este comparativo de pneus com base na opiniao dos utilizadores http://www.tyrereviews.co.uk/Tyre-Size/16-Inch-Tyres/195-50-16-Tyres.htm sendo os Nexen N Blue HD Plus a melhor escolha em termos de custo/beneficio.
Se preferir o melhor que há no mercado para proximo da medida que indica tem este teste:
Overall: Exemplary
Boas
Essas medidas é tudo no mesmo tamanho de jante?
P.S: Já vi que vim tarde
Sim, esqueci me desse "pormaior".
É tudo em jante 15.
Vou dar uma vista de olhos nesses Nexen.
Obrigado, estou aberto a mais sugestões.
Edit: Não encontro esse Nexen em 195/50
É tudo em jante 15.
Essa medida em jante 15 é tão banal que ia sempre para os continental premium contact 5, hankook k125, Goodyear efficientgrip performance, etc. A diferença para uns nexen são prai 10€ cada, e compensam o preço pelas prestações.
PS: não sei se há nessa medida, mas se houverem os Falken sincera então devem ser a melhor escolha.
Caso sejas de Lisboa a pneubeato e xarepa safam-te. Se fores do norte o e'leclerc tem dos melhores preços.
Se fores para os online, poe os que forem melhores em molhado de marcas conceituadas que nunca falhas. Eu punha os k125
Enviado do meu Z200 através de Tapatalk
Obrigado pelas dicas.
Sou da zona de Coimbra, por aqui há Feuvert e Norauto, penso que não haja E'leclerc.
Os Goodyear Effiec grip já usei noutro carro e gostei bastante.
Neste site para a medida que pretendes tens este comparativo de preços:
https://www.pneuslider.pt/comparati...10131&elem[]=363043&elem[]=50105&elem[]=67057
Em termos de classificação europeia os Goodyear efficient grip performance são os melhores mas também os mais caros.
Os pneus Landsail LS388 teem recebido boas reviews por parte de quem os compra alem de terem boas caracteristicas para o preço que sao vendidos http://www.tyrereviews.co.uk/Tyre/Landsail/LS388-AS.htm
http://landsailtires.com/tires/ls388/
