Tópico dos aviões
Pesquisa rapida no google, deve esclarecer as duvidas dos ultimos posts:
Painting versus Polishing of Airplane Exterior Surfaces
[FONT=arial, geneva, sans-serif][SIZE=+1]Painting versus Polishing of Airplane Exterior Surfaces
The decision to paint or polish the metal surfaces of airplanes is based on marketing, economic, and environmental considerations. Although the net operating cost of polished airplanes is slightly more than that of painted airplanes, no compelling reason generally exists to choose one type of livery over the other. The result is a world fleet made up of airplanes with surfaces that are mostly painted, mostly polished, or both painted and polished.
[/SIZE][/FONT][FONT=arial, geneva, sans-serif]Operators of commercial airplanes base their decisions to paint or polish exterior airplane surfaces on several considerations. Short- and long-term business requirements, as well as the availability of financial, labor, and material resources, must be evaluated when considering the following factors:[/FONT]
[FONT=arial, geneva, sans-serif][/FONT]
  1. [FONT=arial, geneva, sans-serif]
  2. Marketing.
  3. Cost.
  4. Environmental impact.[/FONT]
[FONT=arial, geneva, sans-serif]Marketing
Because the colors, patterns, and symbols on the exterior of airplanes convey an image to the public, marketing considerations hold substantial weight in the decision to paint or polish. While some operators believe that their image is best presented with a decorative paint scheme, others believe that a polished surface works best. Once established, the markings become the most visible identifier of an operator at any airport, and they are often retained for many years.
Cost
Operators must consider all the factors that contribute to total cost when deciding between painting or polishing their airplanes:
  • Airplane purchase price.
  • Maintenance.
  • Corrosion protection.
[SIZE=-1]AIRPLANE PURCHASE PRICE[/SIZE]
Decorative painting is included in the base price of an airplane. However, full-fuselage painting, unusual markings, and late revisions may cost more.
All exterior airplane paint can be classified either as decorative, which includes an operator's markings, or as protective, which is light gray in color. Protective paint is used in certain areas to prevent corrosion, and it is used on all composites to prevent erosion and moisture ingress. These composite areas include wing fairings, control surfaces, radomes, tail cones, engine nacelles, and large portions of the empennage. For this reason, even polished airplanes use a considerable amount of protective paint.
Decorative paint schemes generally use a minimum of 3 or 4 colors and a maximum of 14 or 15 colors applied to the upper half of the fuselage and to the vertical stabilizer and rudder. These schemes are also applied to the horizontal stabilizer and elevator on Douglas-designed airplanes. A base color is applied first, followed by stripes, lettering, and logos. Polished airplanes forgo the base color, restricting the use of decorative paint to stripes, the operator's name and registry number, and logos.
[SIZE=-1]MAINTENANCE[/SIZE]
Beyond the need for washing, the comparative cost of maintaining painted and polished surfaces is significantly affected by the policies of individual operators. Most repaint their airplanes every four years, often during a scheduled C- or D-check, but do not completely strip the paint during each cycle. Instead, they alternate between complete stripping and merely scuff-sanding the existing paint layer and applying a new topcoat. Painting costs include labor, stripper, paint, primer, masking materials, and proper disposal of consumables.
Airplanes should never carry more than two layers of paint. With more than two layers, operating efficiency drops, inspections become more difficult, and corrosion can start in chips that remain under a fresh topcoat. Excessive paint buildup is a particular concern on aging airplanes, as the buildup may cause difficulty during inspection of the rows of rivets and lap splices that connect fuselage panels.
Maintaining the appearance of a polished airplane requires repolishing up to three times a year with a special compound applied with mechanical buffers, as well as regular washing to clean oxidation buildup from unpainted surfaces. Both activities require a considerable investment in buffing equipment and personnel. Periodic maintenance can be performed while a polished airplane is being repolished, but not while a painted airplane is being stripped and repainted.
While the lighter weight of a polished airplane saves fuel costs, as shown in (table 1), this savings is more than offset by the higher cost of washing, polishing, and painting a polished fuselage throughout its service life (table 2). The net operating cost of polished airplanes, calculated as a percentage of the total operating cost, is between 0.06 percent and 0.30 percent more than the total operating cost of fully painted airplanes.
[SIZE=-1]CORROSION PROTECTION[/SIZE]
Polished and painted airplanes both need to be washed regularly to preserve their exterior surfaces. However, for the sake of appearance and image, it is not uncommon for polished airplanes to be washed twice as often as fully painted airplanes. Regular washing protects against corrosion by removing contaminants. It also gives maintenance personnel the opportunity to assess the surface condition of an airplane, which permits operators to predict the date and extent of future maintenance required for corrosion and erosion. A mild alkaline detergent and pure warm water should be used. It is particularly important to wash new airplanes, because the protective oxide film that naturally forms and grows on aluminum with age is relatively thin and provides little protection. Both painted and polished surfaces can be adequately protected from corrosion. Fuselage skins are made from Alclad aluminum that consists of a high-strength core alloy bonded to a thin layer of pure aluminum or aluminum alloy. Wing skins are made of bare aluminum and are protected by an impact-resistant paint system. Polished surfaces are protected from corrosion by regular buffing after washing. Painting protects against oxidation, salts, and jet fuel spills. However, unrepaired chips and cracks in paint collect dirt and moisture and so may become corrosion sites. Painted surfaces are also susceptible to filiform corrosion, or worm corrosion, which begins between metallic surfaces and paint and erodes both. It creates hydrogen and lifts up the paint layer as it travels across the surface.
Environmental Impact
The choice between painting and polishing must be made after considering any laws that regulate toxic emissions. Painting has the potential to release volatile organic compounds (VOC) and known carcinogenic toxins such as chromium, present in both paint and primer, and cadmium, present only in primer. Since many areas of the world, particularly Europe and the United States, have laws forbidding the emission of these substances, facilities must be equipped to prevent or entrap such emission.
Polishing an airplane does not involve the potential for chromium and cadmium emission, but it requires the use of solvents. Some solvents do not adversely affect the environment, but others that contain ozone-depleting substances or VOCs are illegal in many parts of the world. Most first-world countries have agreed to the Montreal Protocol that forbids the manufacture of all ozone-depleting substances.
[/FONT][FONT=arial, geneva, sans-serif]Summary
Though the weight of paint adds to fuel consumption, the fuel-cost savings offered by polished surfaces is outweighed by the cost of maintaining the polished surfaces. However, because this difference is a very small percentage of operating cost, many operators decide to paint or polish their airplanes based on marketing and environmental impact considerations. Some believe that a distinctive image can best be achieved with a full paint scheme, while others believe the image can be projected best by mostly polished surfaces. The availability of safe solvents and facilities that comply with environmental laws can also play a role in the choice between painting and polishing.
Table 1: Decorative Paint Scheme Weights, Lb (Kg)
[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]717-200[/FONT][FONT=arial, geneva, helvetica, sans-serif]MD-80/-90[/FONT][FONT=arial, geneva, helvetica, sans-serif]MD-11[/FONT][FONT=arial, geneva, helvetica, sans-serif]737-700[/FONT][FONT=arial, geneva, helvetica, sans-serif]757-200[/FONT][FONT=arial, geneva, helvetica, sans-serif]767-300[/FONT][FONT=arial, geneva, helvetica, sans-serif]777-200[/FONT][FONT=arial, geneva, helvetica, sans-serif]747-400[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]Upper and lower half of fuselage and tail painted plus customer markings[/FONT][FONT=arial, geneva, helvetica, sans-serif]119
(54.0)[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]155
(70.3)[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]427
(193.7)[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]179
(81.2)[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]239
(108.4)[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]299
(135.6)[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]475
(215.5)[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]555
(251.7)[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]Upper half of fuselage and tail painted plus customer markings[/FONT][FONT=arial, geneva, helvetica, sans-serif]94
(42.6)[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]120
(54.4)[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]312
(141.5)[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]130
(59.0)[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]157
(71.2)[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]202
(91.6)[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]330
(149.7)[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]368
(166.9)[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]Polished skin and customer markings[/FONT][FONT=arial, geneva, helvetica, sans-serif]23
(10.4)[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]25
(11.3)[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]45
(20.4)[/FONT]
(11.3)[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]30
(13.6)[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]40
(91.6)[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]50
(22.7)[/FONT]
(24.9)[/FONT]
[TD="colspan: 9"][FONT=arial, geneva, helvetica, sans-serif]Less paint reduces takeoff weight and fuel consumption considerably. The weight of paint for a typical decorative paint scheme varies among Boeing airplanes. Note that the paint weights given are representative of a typical paint scheme with a 4-mil* (0.1016-mm) paint thickness. Paint thickness varies between 3.5 to 5.5 mil (0.0889 to 0.1397 mm).[/FONT][FONT=arial, geneva, helvetica, sans-serif]*mil=0.001 in[/FONT]
[/TD]
Table 2: Annual Operating Cost Differences Related To Paint Scheme (1998 U.S. Dollars)
[FONT=arial, geneva, helvetica, sans-serif]Short-range,
single-aisle[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]Long-range,
double-aisle[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]Upper and lower half of fuselage and tail painted plus customer markings[/FONT][FONT=arial, geneva, helvetica, sans-serif]Base[/FONT][FONT=arial, geneva, helvetica, sans-serif]Base[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]Upper and lower half of fuselage and tail painted plus customer markings[/FONT][FONT=arial, geneva, helvetica, sans-serif]32,000[/FONT][FONT=arial, geneva, helvetica, sans-serif]50,000[/FONT]
[FONT=arial, geneva, helvetica, sans-serif]Polished skin and customer markings[/FONT][FONT=arial, geneva, helvetica, sans-serif]92,000[/FONT][FONT=arial, geneva, helvetica, sans-serif]132,000[/FONT]
[TD="colspan: 9"][FONT=arial, geneva, helvetica, sans-serif]Relative operating costs can be estimated only within a large tolerance to accommodate wide variation in the complexity of paint schemes and intervals between washings, polishings, and paintings. The cost savings shown for short-range, single-aisle airplanes and long-range, double-aisle airplanes are based on the activity level of an operator that strenuously maintains the appearance of its fleet. Another operator could easily experience half of the cost savings shown.[/FONT][/TD]
[/FONT][FONT=arial, geneva, sans-serif][SIZE=-1]Dan Hansen
Principal Engineer
Scientist
Airframe Design
Boeing Long Beach
Division[/SIZE]
[/FONT]
[FONT=arial, geneva, sans-serif]return to top | AERO text-only contents | Boeing Home | Commercial
Copyright © The Boeing Company. All rights reserved.
[/FONT]
Era sim senhor. Os dois 747 fizeram backtrack sendo que o da Pan Am estava a virar para uma das saídas da pista para libertá-la e o KLM descolar.
mas foi com esse acidente que se deixou de usar a palavra take off quando se estava pronto para descolar, agora é ready for departure
Se eles usassem umas cores metalizadas o peso era o mesmo e acho que o custo seria insignificante em relação ao preço de uma aeronave. Pode haver algum detalhe técnico que me esteja a escapar mas acho que daria outra vida à imagem da marca.
ok, mas será que em aparelhos que custam 50 ou 100 milhões de euros, essa diferença é decisiva? Podem dizer que é uma paneleirice, mas a imagem da marca é bastante importante para as vendas. Coincidência ou não, é raro ver cores metalizadas em aviões.
o problema não é o custo mas o peso, alias muitas companhias não metem sequer nada nos winglets
o "aviaçãoportugal.net" foi à vida????
Tinham posto um anuncio de venda do site em rodapé, entretanto nem 24 horas depois disso foi encerrado mesmo na hora em que deixava uma posta e nunca mais ressuscitou....:sh)
É uma falta de respeito fazerem isso sem mais nem menos, num tópico criado para discutir a venda estavam a cascar em alguns dos moderadores e Admin, e aquilo foi abaixo!!!
Já o fórum que antecedeu o aviação Portugal, encerrou devido a comentários destinados aos moderadores e voltou a acontecer o mesmo. Logo agora que já tinham tapatalk :-(.
pessoalmente acho que havia mais participação, e melhores, que no portugalspotters.
Este ultimo até pode ser bom, mas tem pouca participação comparado ao AP. A MEU VER o aviação Portugal era melhor.
Foi uma pena o aviacao portugal ter encerrado... Agora qual o sucessor ?
Também tenho pena. Já acompanhava desde o LdF. Apesar de não estar ligado à aviação, sempre fui um grande entusiasta (simulação). Aprendi bastante lá. Se alguém souber de algum site que venha substituir, por favor avise aqui.
Anexos
    28,8KB · Visualizações: 0
Aproveitando o tópico.
Comprando um bilhete na TAP, só é possível metê-lo no Passbook depois de feito o check-in online?
