BMW535i
Banido
The Family 0 is a family of inline piston engines that was developed by Opel, at the time a subsidiary of General Motors, as a low-displacement engine for use on entry-level subcompact cars from Opel/Vauxhall.
These engines feature a light-weight cast-iron semi-closed deck engine block with an aluminum cylinder head. The valvetrain consists of chain-driven hollowcast dual overhead camshafts (DOHC) that actuate 4-valves per cylinder via roller finger followers with hydraulic tappets. These engines also feature a 78 mm (3.1 in) bore spacing and fracture-split connecting rods.
Later versions also incorporate a variable length intake manifold (VLIM) and variable valve timing (VVT).
Originally debuting as either a 1.0 L (973 cc) straight-3 or 1.2 L (1,199 cc) straight-4; a 1.4 L (1,364 cc) I4 variant was added with the introduction of the second generation, replacing the 1.4 L Family 1 engine. Currently, the Family 0 engines are produced by Opel Wien in Vienna/Aspern (Austria), by GM in Bupyeong (Korea) and Flint (Michigan, USA).
