Mazda 2 (2015)
Mazda 2 1.5 115 Sport Nav - Autocar
New Mazda supermini is a fine all-rounder, and engaging to drive with range-topping petrol power
What is it?:
Early drives in the all-new Mazda 2 have revealed it to be a very fine supermini indeed, but not quite a class-leading one - the seemingly unstoppable Ford Fiesta entering a seventh year as leader of the class.
Ahead of the new 2’s imminent UK launch, we’ve now had a chance to sample another, more potent flavour of it, those earlier drives having been limited to the mid-range 89bhp 1.5-litre petrol version.
That normally aspirated engine is also offered with an entry-level output of 74bhp or the range-topping 113bhp tested here, the more powerful one promising to give the 2 the extra bit of fun factor needed to topple the Fiesta. A 1.5-litre Skyactiv diesel is also offered, but we haven't yet tried it.
What's it like?:
The range-topping engine goads you to rev it to access the performance, making it entertaining if you can keep the momentum going. The engine is mated to one of the slickest manual gearboxes in the class, the six-speed unit encouraging positive shifts. Drive it at lower revs and it’s altogether much smoother and more relaxing.
The 2 is therefore a car that feels good to drive, not only because of its positive powertrain, but also because its steering is well weighted and allows the car to be accurately placed on the road. Turn-in is sharp and the ride comfortable; it gets the basics right, in other words, which is not something that can be said for all rivals.
The drivetrain suffers the same problems as the lower-powered versions, mind, namely little low-end torque and overly long gearing, which makes getting anywhere in a hurry a real effort. The flipside to that willingness to be pushed is that the engine can be surprisingly vocal, while at faster motorway speeds engine noise never settles into the background.
Mazda is keen to emphasise its strategy of "rightsizing the engine rather than downsizing", which has its benefits, with real-world economy in the early 50s, for example. However, you can’t help but miss that extra zest, charm and better low-end shove Ford's three-cylinder turbo Ecoboost provides. Stick one of these in the 2 and I’ve a sneaky suspicion the 2 would shift from good to drive to fun to drive, and really give the Fiesta something to worry about.
The 2's interior is a huge improvement over the old car’s in design and perceived quality and has an infotainment screen that is controlled by a rotary knob next to the handbrake.
The sat-nav provides some of the clearest mapping out there and clear spoken instructions that won’t leave you reaching for the mute button. More evidence of the basics being done well.
Should I buy one?:
This range-topping Mazda 2 has plenty going for it, then. It’s a true all-rounder in the class and is likely to be a fine car to own, albeit pricey in this guise next to its equivalent key rivals.
The Fiesta remains the best car to drive in the class, but the 2 deserves to be at the top of your supermini shopping list.
Mazda 2 1.5 115ps Sport Nav
Price £15,995; Engine 4 cyls, 1496cc, petrol; Power 113bhp at 6000rpm; Torque 109lb ft at 4000rpm; Gearbox 5-spd manual; Kerb weight 1055kg; Top speed 124mph; 0-62mph 8.7sec; Economy56.5mpg (combined); CO2/tax band 117g/km, 16%
Esta uma máquina fantástica.
A Mazda está com umas linhas muito bonitas e está a aumentar a qualidade dos seus interiores.
Curiosidade em vê-lo ao vivo.
Ora bom, como sabem recebi um convite por parte de um concessionário da zona de Lisboa para a apresentação do novo Mazda2 que vai estar a partir de dia 21 deste mês nos stands.
Às 10 horas lá estava eu à espera de ver o novo Mazda2, pouco depois da hora marcada chega um senhor da Mazda Motor de Portugal com o exemplar em questão, era a versão de topo (a versão essence se a memória não me falha, a mais equipada que vai estar no nosso mercado), vinha equipado com o motor 1.5 skyactive G de 115 cavalos.
Estava extremamente curioso em relação ao motor e ao carro (nunca consegui fazer test drive ao novo mazda3 porque nunca encontrava nenhum nos concessionários, eram sempre vendidos) e confesso que não me desiludiu.
As medidas até são generosas para um segmento B, ainda há dias tinha estado a ver o novo corsa e a nível de interiores nada tinha a ver com este mazda2.
Esta versão estava equipada com GPS, xénon, sistema keyless, botão start, faróis diurnos em LED, bancos aquecidos e com presponto vermelho, AC automático, avisador de saída de faixa de rodagem, cruise control, travagem automática de segurança, sensor de luz, chuva, estacionamento e 4 vidros eléctricos sendo que apenas o do condutor é automático (como é normal nos japunas).
Primeiro contacto com o carro:
Muito bom, posição de condução excelente (nem tive de alterar o banco do condutor para fazer o teste), também não é preciso mexer muito para se encontrar uma excelente posição de condução.
O 'tablet' montado no tablier é bastante intuitivo e o sistema tipo audi MMI é bastante fácil, simples e prático de usar e não requer muita atenção, podemos usar sem tirar de todo os olhos da estrada. Sendo também fácil a passagem para o GPS.
Motor extremamente silencioso e suave, mesmo suave, caixa precisa e algo longa para os consumos, pontos de embraiagem super suaves, parecia quase um diesel, contudo nota-se perfeitamente ali a falta de um turbo, nas recuperações é muito lento e obriga bastante a usar a caixa para nos mantermos acima das 2 rpm que é quando o carro começa a ganhar 'alma', consegue mesmo um som que causa um sorriso bem rasgado.
O interior estava muito bem montado (penso que aguentará bem o passar dos anos e parece-me estar bem 'preparado' contra ruídos parasitas que possam vir a ocorrer.
Nunca tinha conduzido ou entrado na versão anterior do Mazda2 mas usando o 3 mk2 há uma clara melhoria de qualidade a nível de interiores, bem montado e acima de tudo bem ergonómico com tudo o que se necessita à mão sem grande esforço. E tem-se uma percepção muito boa de qualidade.
O rolamento do carro é bastante suave e silencioso, estável e agarra muito bem nas curvas, tem grande dinâmica, fiz uns kms em nacional pelas serras de Loures e impressionou-me bastante o 'handling' do carro, apesar de apertar um pouco com ele não dei pelas ajudas do controlo de tracção/estabilidade nem chiar dos pneus, sempre seguro e firme a curvar, a direcção é precisa e temos sempre a noção do contacto com a estrada, não a achei demasiado artificial, aquele chassis com um motor à estilo abarth e era a cereja no topo do bolo.
Agora os pontos menos bons:
O espaço atrás não é muito famoso apesar da mala até apresentar uma capacidade razoável, o quadrante apesar de bonito e bem conseguido está um pouco confuso de ler, na minha opinião o quadrante devia ter ao centro o conta rotações (como as versões 2.0 a gasolina do novo Mazda3), é que ao centro tem o velocímetro e do lado esquerdo do mesmo tem um display com as rotações e aquelas ajudas de mudança de caixa para os consumos e torna a leitura das rotações algo confuso e complicado, algo que requer habituação.
O facto dos japoneses não terem luzes no plafoundier (penso que seja assim) das luzes nem nos botões dos vidros electricos e as portas podiam estar melhor forradas, no fundo são bastante espartanos em interiores (e ainda são piores no Japão!).
Resumindo: Gostei bastante, está um carro muito bom e bem capaz de se bater com a concorrência, vamos é ver como vai ser a nível de motores mas para mim aquele 1.5 de 115 cavalos chegava e sobrava!
Foi uma excelente manhã e com pessoal impecável, em especial o vendedor que foi comigo no teste drive e ao gestor de área da Mazda Motor de Portugal que foram 5 estrelas e passámos um bom bocado à conversa. Se lerem isto, obrigado pela manhã! valeu bem os 100 km que fiz.
E uma novidade, há um CX-3 em Portugal para gravar um anúncio internacional para a apresentação do mesmo, a cor dele é vermelho, um must!
Agora fotos:
