SpeedKills
Membro participativo
Fonte? Eu tinha a ideia que só o 1.6 Turbo é que tinhaInforma-te bem antes pq o 1.4i psa/bmw é de injecção directa.
Há alturas que não ando muito informado, esta é uma delas! De certeza que o 1.4 da psa foi feito em conjunto pela bmw?
ok[Foi feito em parceria. Estamos a falar do 1.4i de 95cv, até agora usado apenas e só no 207 e 308. É o mesmo do Mini One.
Que arrogância :sh)!
Só as versões turbo (1.6 150 e 1.6 175) é que são.
The 1.6 L engine is used in the second-generation MINI and various Peugeot 207 models. It has a 85.8 mm (3.4 in) stroke for a total of 1598 cc of displacement.
[edit] Naturally-aspirated
The naturally-aspirated variant (EP6) has conventional fuel injection and lost-foam cast heads. Its high 11:1 compression ratio creates an output of 120 PS (118 hp/88 kW) at 6000 rpm with a redline of 6500 rpm. Torque is 118 ft·lbf (160 N·m) at 4250 rpm.[2]
Applications:
[edit] Turbocharged
- 2006–present Peugeot 207 Sport
- 2007–present MINI Cooper
The turbocharged 1.6 L unit adds gasoline direct injection and has special low-pressure die-cast heads.
At this stage, there are two versions on offer - the THP150 and THP175, also known as the EP6DT and EP6DTS respectively within Peugeot.
For the THP150 maximum torque is 177 ft·lbf (240 N·m) at 1400 rpm, remaining flat to 5000 rpm. Power output is 150 PS (148 hp/110 kW) at 5500 rpm.
Applications:
For the THP175 maximum torque is 178 ft·lbf (247 N·m) at 1600 rpm, remaining flat to 5000 rpm. Power output is 175 PS (173 hp/128 kW) at 5500 rpm. An overboost function is available which temporarily increases torque to 192 ft·lbf (260 N·m) between 1700 rpm and 4500 rpm.
- 2006–present Peugeot 207 CC/GT
- 2007–present Peugeot 308
Applications:
- 2006–present Peugeot 207 RC
- 2007–present MINI Cooper S
A questao mais importante é, sera que em termos praticos a injecçao directa a gasolina tem vantagens?
Os primeiros a lançar modelos ID na europa foram a PSA e a Renault com os 2.0 HPI e 2.0 IDE respectivamente mas rapidamente chegaram a conclusao que a gasolina distribuida n era compativel com esse sistema e que acabavam por ser piores em consumo pelo menos que as versoes sem ID.
Essa frase está um pouco dúbia. Foram talvez os primeiros construtores europeus a relançar essa tecnologia (já que ela já tinha sido utilizada nos anos 50) mas o primeiro construtor a lançar um motor de injecção directa a gasolina moderno, incluindo na Europa, foi a Mitsubishi, através do Carisma 1.8 GDI! []
Só os 1.6 Turbo é que têm injecção directa:
Ficha tecnica do 207 16 THP 150 - http://www.autoweb-france.com/fiches-techniques/Peugeot/fiche_6028_Peugeot_207_1.6_THP_150.php
É possível ler "Alimentation :Injection directe d essence"
Já nos 1.6 120 e 1.4 95 aparece: "Alimentation :Gestion intégrale"
http://www.autoweb-france.com/fiches-techniques/Peugeot/fiche_6027_Peugeot_207_1.6_VTi_16v.php
http://www.autoweb-france.com/fiches-techniques/Peugeot/fiche_6025_Peugeot_207_1.4_VTi_16v.php
Agora no site km77.com
http://www.km77.com/eli/motor/fichacompleta.asp?id=18636
Aqui lê-se: Alimentación iny. indirecta. --
No 1.6 120 idem
http://www.km77.com/eli/motor/fichacompleta.asp?id=18638
No 1.6 THP 150 ou 175 lê-se: Alimentación iny. directa. --Turbo compresor. Intercooler.
http://www.km77.com/eli/motor/fichacompleta.asp?id=18641
Se fores procurar as fichas técnicas do Mini é igual. []
Agora na Wikipedia
DEpois deste topico começei a ficar com duvidas.....
Só te posso dar a razão. Pensei mesmo que o 1.4i 95cv era de injecção directa.........
E não sou arrogante..... Tu é que és![]()
E um pouco antes, num certo Gudbrod Superior, de que ninguém fala! []
