creio que os 4*2 têm vantagens ao nivel de peso, restritor de admissão e sistemas de enchimento dos pneus
O carro não parece talhado para percursos rápidos, é muito curto e alto !
Obrigado !
Engraçado voltarem a 2 wd, o excesso de regulamentação não tem sido benéfico para o Dakar [s)]
| Type Cubic capacity Number of valves Position Number of cylinders Maximum power Torque Maximum revs Top speed Lubricant | V6 bi-turbo diesel 2,993cc 24 Mid-rear V6 (‘vee’ angle = 60°) 340hp 800 Nm 5,000rpm 200kph TOTAL QUARTZ 10 W 50 |
| Type Gearbox Lubricant | Two-wheel drive Longitudinally mounted six-speed manual sequential gearbox TOTAL 755 HPX 80 W 140 |
| Type Bodywork | Tubular steel Carbon |
| Suspension Springs Dampers Travel Anti-roll bars Steering and brakes Discs Rims Tyres | Double wishbones Coil springs (two per wheel) Adjustable (two per wheel) 460mm Front and rear Hydraulic power steering Hydraulic dual circuit, one-piece light alloy four-piston callipers Front and rear vented discs front and rear Front discs (diameter): 355mm Rear discs (diameter): 355mm Aluminium two-piece wheels (17 x 8.5) Michelin 37/12,5x17 |
| Length Width Height Front overhang Rear overhang Wheelbase Fuel tank capacity | 4,099mm 2,033mm 1,912mm 641mm 658mm 2,800mm 400 litres |
