Confirmado: "M5d"
Como disse só experimentando. Por exemplo, e num carro que testei, dci90 v. dci110, embora o de 110 tenha mais binário, a disponibilidade do de 90 a baixos regimes é incomparavelmente superior, e secalhar, para uma utilização urbana, ou que não contenha muita AE será uma melhor escolha. Como é óbvio os numeros serão importantes, mas nunca se pode tirar ilações sem realmente testar, experimentar. Por vezes surgem surpresas engraçadas.
O mesmo se passa no 1.6 TDI de 90CV e o de 105CV.
V10 Engine Era Ends for BMW M5
For some automakers, gaining fuel efficiency is as easy as reducing power, but when you’re BMW, less power is never the answer. BMW will be retiring the V10 engine that powered the previous-generation BMW M5 super sport sedan, but fans shouldn’t fret. Taking its place will be a twin-turbocharged V8 with even more power and torque, as well as improved fuel efficiency.
Slated to take a bow in mid-September at the Frankfurt Motor Show before making its debut at BMW dealerships next year, the fifth-generation BMW M5 will make major strides in fuel efficiency without sacrificing the power that has made it one of the world’s most-desired performance cars. According to BMW, engine output from the new V8 is about 10 percent greater than output from the outgoing V10, while fuel economy will improve by up to 30 percent.
“As much as people love the M5, gas prices stuck above $3.50 a gallon do make buyers think about fuel economy,” said Michael Trontz, general manager of Spring Valley, New York BMW dealership Wide World BMW. “The new M5 uses today’s best technology to preserve its heritage as a super-powered sedan, while also delivering the improved fuel efficiency that customers want and that federal regulations will soon demand.”
While the previous M5 sported a 5.0-liter V10 engine producing 500 horsepower, BMW has dropped a pair of cylinders and reduced displacement to 4.4 liters for the next generation. Generally, fewer cylinders and less displacement mean less power, but the addition of two turbochargers allows the new M5 to deliver 560 horsepower and 500 pound-feet of torque. At the new M5’s launch, a seven-speed dual-clutch gearbox channel will send that power to the rear wheels. BMW has hinted that an all-wheel-drive version is also in the works.
According to a report from TheDetroitBureau.com, the M5 will also get a diesel variant that will launch in the spring of 2012. Tentatively named the BMW 550dXM, this model will feature a modified version of the 3.0-liter six-cylinder diesel found in the BMW 335d, with a new cylinder head design and a third turbocharger to virtually eliminate turbo lag. Engine output is projected to be between 500 and 550 horsepower, and an all-wheel-drive system may be the only configuration capable of handling the torque of the 550dXM, which could potentially exceed 650 pound-feet.
BMW has turned to turbocharging technology in several models to meet stricter fuel economy standards without sacrificing power. One example is the new turbocharged four-cylinder engine in the 2012 BMW 528i, coming to U.S. BMW dealers this fall. With just 2.0 liters of displacement, the four-cylinder 528i will produce the same 240 horsepower as its 3.0-liter, six-cylinder predecessor, generate 30 percent more torque and increase fuel efficiency.
“BMW has a history of success with turbocharged powerplants that goes back to the BMW 2002 of the 1970s,” Trontz noted. “That success is only going to increase with the engines in these new cars, which are on a different level. They combine power and fuel efficiency in ways that we have never seen before.”
Infelizmente a indústria automóvel está domada pelas emissões de CO2 que obrigam a consumos baixos.
Como o CO2 é medido com base nos litros de combustível queimados, mais consumo significa mais CO2 e não conseguem cumprir as metas. Contudo na Europa está para muito breve (2013) a alteração deste cálculo, porque vai basear-se também no tipo de combustível. Assim levam na cabeça os combustíveis que produzem mais CO2, sendo: gasóleo - gasolina - GPL - Gás Natural. Isto do mais prejudicado para o mais favorecido, o que pode levar a uma mudança nos combustíveis a utilizar e mudar o panorama europeu.
UE quer nova taxa sobre o gasóleo - Bolsa - DN
Como o Clarkson disse há uns tempos os motores V8, V10 e V12 podem bem deixar de existir para darem lugar a tri-cilindricos e 4 cilindros turbo ou no máximo IL6 ou V6 (turbo ou não).
Formas cada vez mais dispendiosas na concepção e caríssimas de reparar em caso de eventuais problemas. Por exemplo o 3º turbo do chamado M5d é eléctrico...não deve ser barato e requer muita precisão para funcionar sem falhas. Em vez de se obter potência da forma mais fácil e barata (mais cilindros e mais cilindrada) recorre-se à sobrealimentação.
Até hoje taxava-se os carros com base na cilindrada, contudo cada vez mais deixa de fazer sentido tal modalidade.
Isto não é um caminho para melhor, é um caminho para cumprir imposições. É o futuro (por obrigação) mas não é o futuro que desejava para a indústria automóvel.
Qualquer dia ainda vamos pagar uma taxa por respirarmos já que ao fazê-lo emitimos CO2, não se fala de outra coisa senão esta treta das emissões.
Não tem comparação. O Tdi de 105 tem uma preparação para regimes baixos que o dCi de 110 não tem.
É obvio que para andar em cidade o Tdi de 90 é melhor, mas o 105 não compromete, pelo menos os que conheço.
Verdade. Ando regularmente com um 1.6TDI de 105, mas só tava mesmo a referir a reprize o de 90 conseguiu algo melhor, mas o 105 mal perdia nisso e dava muito mais la em cima, como tal a escolha na compra foi o 105. E sim é bem mais "refinado" que o DCI 110.
Volto a dizer que até ver,não acredito em nada acima dos 400 cv´s num 3L diesel de produção.
Mas a confirmar-se,tenham a noção que este motor será um portento,e um feito tecnológico,que fará a BMW estar inalcançável em know-how em relação á concorrência,no que a diesel diz respeito.
Qq dia ainda sai a GPL...
Não vejo problema nenhum nisso, se for um bom sistema de GPL (injecção liquida) até poderá superar a 98 em potencia, custo por quilómetro e poluição ambiental com uma sonoridade parecida ou até melhor. Até acho que o pessoal anti-diesel não iria ficar tão chateado como ficaram com este Md!
Agora vou-te pregar uma rasteira...
E se o que tiver maior potência tiver menos disponibilidade em baixas/médias e consequentemente piores recuperações?
Ainda te lembras das HORAS que perdi a tentar explicar neste fórum, a ti e a outros, certos conceitos de mecânica de motores como binário, rotações, potência, disponibilidade etc.? Ou nem chegaste a ler e falei para o boneco?
Se calhar então até sabes porque é que um 535d reprogramado pode andar perto do M5 507cv mesmo tendo cerca de 130cv menos!?!?
Isto é um M5 E39 com várias modificações mecânicas e reprogramação, pode muito bem superar os 550cv contra um 35d apenas ECU e mesmo assim não se viu um andamento muito superior, sinceramente não sei o que queres provar
O E39 tem 400cv... Este tem assim por alto, colectores, catalizadores R e escape, com a consequente repro...
Se tiver mais que 430cv é muito!
E o 535d chipado não o consegue acompanhar, como seria de esperar... São 130cv!
É muita força para contrariar!
Caramba... acho que ainda não se percebeu o que está em causa. Vou tentar exemplificar:
Peguem neste excelente relato do rca33 sobre o MB S420CDI:
Hoje tive a oportunidade de andar num S420 CDI dos novos, que se não é o que se pode chamar de full-extras, não sei o que é.
Devo dizer que já andei em diversos S dos antigos antes (S320, S400) e nos série 7 actuais (745i e 745d), por isso não sou própriamente novato neste tipo de carros.
A primeira impressão ao entrar neste carro, é que todos os outros são carros muito simples com acabamentos modestos. Não, não é exagero.
Desde os 'banais' lcd's nas traseiras dos bancos, aos 'habituais' bancos traseiros com inúmeros ajustes electrónicos, a jantes AMG 19 polegadas, enfim é uma perfeita loucura.
O topo do painel de instrumentos é forrado a pele, porque nem os excelentes acabamentos em plásticos aborrachados eram suficientes...:sh)
Pondo o carro a trabalhar, nota-se que há um ligeiro barulho vindo não se percebe de onde, mas menos vibrações só mesmo estando dentro de um bunker. De facto falar nos defeitos de um motor diesel nesta gama é absurdo, no mínimo.
Em andamento, é curioso ver os 730nm de binário a saltar cá para fora. Não é que se oiça o motor (nem às 4500 rpm), mas ficamos a pensar porque raio nos sentimos tão leves dentro de um carro. De repente parece que estamos num carro levezinho e as coisas passam por nós muito depressa, mas o ritmo cardíaco só aumenta pelo factor visual, dado que tudo o resto é seneridade.
Entramos numa zona de empedrado, mas apesar das jantes de 19 polegadas temos de olhar novamente para nos certificarmos que de facto o alcatrão não é liso, pois o ruído ou vibrações existentes envergonham a maior parte dos carros em piso lisinho. Fantástico.
Antes de se pensar que este carro tem uma suspensão muito macia ou bamboleante, convem referir que é bem seco se passarmos por uma daquelas lombas metálicas (em que os pneus de baixo perfil devem ajudar muito).
Numa curva mais apertada à direita (sem abusos) sente-se logo o apoio lateral esquerdo das costas a avançar para nos segurar no banco.
Não sei se há mais carros com isto, mas é fantástico. De repente, a poltrona de massagens tranforma-se num banco desportivo dinâmico, ajustando o apoio em função do lado da curva, de um modo bastante óbvio. Bem pensado, Mercedes.
Não é fácil descrever o que se sente num automóvel destes, só mesmo experimentando para se acreditar.
A Excelência deste Automóvel é algo que ultrapassa os limites do imaginável, e perdoem-me os fãs da BMW, mas esta ainda tem muito que aprender.
Por fim perguntei ao dono "gasolinas estão fora de questão, não ?".
A resposta foi "enquanto continuar assim sim ! Os diesel têm mais binário e a desvalorização não tem nada a ver !"
Antes de pensarem que é alguém pouco informado, digo que os dois últimos motores a gasolina que teve foram um 645i e um 745i, passando uns meses por um Z4 a que achou pouca piada.
Confesso que se me saísse o euromilhões preferia um CLS a este, apenas porque acho que o S não era carro para a minha idade. Mas coitadinho do CLS ao pé deste (que tb já tive oportunidade de experimentar).
Agora peguem neste igualmente fantástico relato do Cobra sobre o M3 E46:
Ontem fui dar umas voltinhas para a zona do Cabo da Roca [;)]
Saindo da A5 pela EN que vai pela Aldeia do Juso, começo a aumentar o ritmo, nisto dou conta de um par de faróis inconfundíveis… Porsche 997!
Mas não sei qual a versão! Mas para descobrir não ia rebolar tipo morto [;)][:D]
Aumento mais um pouco a toada, sem ele me largar, nesta fase não dá para ultrapassar…
Uma rectinha com cerca de 500mts 4ª/3ª para o meter acima das 5000rpm, e de um fôlego ultrapasso dois carros com uma velocidade estonteante, daquelas que eles nem sabem de onde eu vim…
Logo a seguir aos dois carros, encosto bem à direita e continuo a puxar, e sem ter noção de que lá vinha o 997, lá tive um reality check []
Era um 997 turbo e a diferença de andamento é de tal ordem que ainda tenho a cabeça a abanar [:D][:D]
Tem um urro pujante e afirmativo, mas algo abafado demais, bem se calhar ia ao ralentim [:D]
E nunca mais o vi tal foi o trauma [:D]
Mental note a ideia de um carro de 5p continua a ganhar força…
Das duas uma ou passo a usar a S2 com alguma carga para o dia a dia e paro o ///M para as ocasiões especias, ou então uma RS4 b5(!?)
Outra ideia é “parar” um aninho com as maluqueiras e avançar para o 964 turbo, arranjando um daily
mais pocket friendly…
É aguardar pelas cenas dos próximos capítulos!
Já está?
Agora troquem os motores nos carros e vejam se os relatos fazem sentido, ou se seriam iguais...
IMHO não. [;)]
Ganhou 30cv com essas modificações todas!!!! LOL!! Não brinques comigo... Visto que falaste em M3 se calhar o que tu querias mostrar era isto:
Nota: sincroniza aos 3 seg ambos a 140km/h
Vídeo interessante! Achei curioroso o pormenor da potência do 535d estar anuciada... e a do M5 E39 não, só menciona as alterações. :)
Haviam por aí tópicos que falavam (não eras tu Cobra, eu sei) em aumentos idiotas só com repro em motores a gasolina atmosféricos... mas afinal um E39 já com algumas alterações, mais repro tem um ganho de 30cv.
De qualquer forma, e embora concorde que não se consiga retirar muito sumo deste motor só com repro, também acho os 30cv, neste caso, um pouco pessimistas. [;)]
Depois... estão-se a comparar duas gerações diferentes, que só a diferença de peso (pois...) tem uma importância que não pode ser esquecida.
rca33...tenho a dizer que andei num s320 dos antigos e num cls 320 dos antigo (ambos AMG) e, nos lugares da frente, não há qualquer diferença em termos de conforto. Nos lugares de tras, no cls parece que estamos metidos num pequeno buraco, mas nao deixa de ser incrivelmente silencioso e confortável. (é um pouco há semelhança do C30 e do Scirocco...parece que estamos num carro de competição mas confortável).
O dono do, então cls320, trocou agora por um 535d....veremos se não notará diferenças...nessa aidna não andei!
