How Lift is Created
[SIZE=+1]
Pressure Variations Caused By Turning a Moving Fluid[/SIZE]
Lift is a force on a wing (or any other solid object) immersed in a moving fluid, and it acts perpendicular to the flow of the fluid. (Drag is the same thing, but acts parallel to the direction of the fluid flow). The net force is created by pressure differences brought about by variations in speed of the air at all points around the wing. These velocity variations are caused by the disruption and turning of the air flowing past the wing. The measured pressure distribution on a typical wing looks like the following diagram:
- A. Air approaching the top surface of the wing is compressed into the air above it as it moves upward. Then, as the top surface curves downward and away from the airstream, a low-pressure area is developed and the air above is pulled downward toward the back of the wing. B. Air approaching the bottom surface of the wing is slowed, compressed and redirected in a downward path. As the air nears the rear of the wing, its speed and pressure gradually match that of the air coming over the top. The overall pressure effects encountered on the bottom of the wing are generally less pronounced than those on the top of the wing.
C. Lift component
D. Net force
E. Drag component
When you sum up all the pressures acting on the wing (all the way around), you end up with a net force on the wing. A portion of this lift goes into lifting the wing (
lift component), and the rest goes into slowing the wing down (
drag component). As the amount of airflow turned by a given wing is increased, the speed and pressure differences between the top and bottom surfaces become more pronounced, and this increases the lift. There are many ways to increase the lift of a wing, such as increasing the angle of attack or increasing the speed of the airflow. These methods and others are discussed in more detail later in this article.
