BLADERUNNER
Para já apenas se sabe o seguinte:
Comprimento: 4,55m
Altura: 1,96m
Largura: 1,90m
Capacidade para 800kg de carga num volume de 4,6 metros cúbicos.
A motorização é elétrica.
VW Imagines the Future of Delivery Vans with e-Co-Motion Concept - Carscoops
The e-Co-Motion Concept is Volkswagen's vision of a zero-emissions, compact delivery van of the not-so-distance future, and it was unveiled in the flesh today during a media-presentation held ahead of its public premiere at the Geneva International Auto Salon on Tuesday, March 5.Smaller than a Transporter at 4.55 meters (179 inches) long, the e-Co-Motion features an electric powertrain comprising an electric motor mounted on the rear-axle together with a single-speed planetary gearbox, and a battery package.
VW said it chose this layout to achieve large wheel turning angles at the front axle and thereby, improve maneuverability, something necessary for a vehicle of this type. Thanks to this design, the e-Co-Motion has a turning circle of 8.95 meters.
The electric motor has a continuous power output of 50 kW (67hp or 68 PS) and a maximum output of 85 kW (114hp or 115PS), together with a constant peak torque of 270Nm (199 lb-ft). While it was primarily designed for city use, VW says the speed limited doesn't kick in until 120 km/h (75mph).
The e-Co-Motion was created to be fitted with three different battery packages. A 20kWh unit provides a driving range of around 100km (62miles), while a larger 30kWh enables 150 km (93miles), and finally, a battery with 40 kWh storage capacity offers a top driving range of 200 km (124 miles).
In its current form, the e-Co-Motion concept has a maximum cargo capacity of 4.6 m3 and a payload of 800 kg (1,763 pounds), but VW said the platform can serve as a basis for as many derivatives as possible "for a wide variety of body concepts and customer solutions".
Volkswagen e-Co-Motion - Genebra 2013
La respuesta eléctrica a la e-NV200 de Nissan, de la mano de Volkswagen, llega con el nombre de e-Co-Motion, y de momento es un concepto, aunque muy bien acabado, y con un aspecto más que interesante, aunque habría que ver si esas chapas que conforman la carrocería con una línea de estilo en forma de nervio tan marcado serían viables en el modelo de producción. más cuando en las furgonetas de reparto hay que pensar en carrocerías que sean baratas y fáciles de reparar.
113 caballos eléctricos son los que tiene, gracias a un motor trasero. La "cama de carga" es completamente plana. El concepto de Volkwagen incluiría ofrecer versiones de 20, 30 y 40 kW de capacidad de batería. Con estas medidas podríamos cubrir entre 100 y 200 kilómetros entre recargas. 200 kilómetros es una cifra que, para trayectos de reparto urbano, es más que suficiente.
¿Llegará al concesionario? Apuesto por ello.
