Tópico dos Pneus
Eu prefiro pneus sempre bons nos 2 eixos... [;)]
Isso dos pneus "novos" atrás tem muito que se lhe diga....
Sim como eu, aliás no caso da marca Volvo, eles enviaram um boletim informativo para toda a rede Volvo:
From Volvo Service Manager Bulletin
Tire Rotation
As suspensions and drive trains evolve, so do vehicle manufacturer recommendations for tire rotation.
Volvo's recommendations have always had a technical basis, while leaving some latitude for customer
preference.Presently, for current models, Volvo has no recommended tire rotation. Because this represents an evolutionary policy, customers may need the guidance of a Volvo service advisor to help them understand the performance and handling tradeoffs that come with tire rotation.
Benefit of Tire Rotation
On a front-wheel drive car, the demands placed on the front wheels during acceleration and cornering
can mean a dramatic difference between front and rear tire tread wear. Without periodic tire rotation
front-to-rear, the front tires will typically require replacement sooner. The primary perceived benefit of tire rotation is that front and rear tires will wear down at about the same average rate. In absolute
terms, four tires will not last any longer this way. It becomes a customer choice between replacing two tires sooner and replacing all four tires later. However, with all current Volvo models, Volvo believes that numerous technical, performance, and handling benefits outweigh any perceived benefit of tire rotation. Following are some of those benefits.
Benefits of Not Rotating Tires
Braking Stability Performance
During hard braking, braking on a slippery road, or braking in a curve, good rear tire tread may help you avoid oversteer. Oversteer is when a turning vehicle wants to keep turning because of momentum and dynamic forces on the vehicle suspension. Volvo stability systems are all designed toward reducing or helping a driver avoid oversteer. Still, all things being equal, having more rear tire tread can contribute to reduced oversteer. Without rotation, the rear tires will naturally wear more slowly and have more tread.
Tread Set
As tires age, the tread adopts an angular set, based on its angle to the road surface. For vehicle
handling reasons, front and rear tread angle is not the same. If tires are rotated, the tread will
eventually set at an angle somewhere between what is optimal for a front or rear tire
. Although vehicle ride, handling, and road noise may still be acceptable, they may not be optimal. Additionally, an infrequently or irregularly rotated tire may result in tire noise, faster tire wear, and unpleasant changes in steering feel and vehicle handling.
Driving Performance
A tire that can fully adapt to its position will generally provide better steering feel, lower tire noise, and better fuel economy.
Suspension Wear Diagnostics
Every vehicle's suspension needs periodic inspection and maintenance. A tire's tread wear pattern
can be an aid in detecting and diagnosing a suspension problem. Each tire, if left in place, tells a story
about its place in the suspension. Tire rotation, on the other hand, can mask a developing problem.
Early detection is very important, because suspension problem can worsen tire wear, and reduce
vehicle performance, handling, stability, and fuel economy.
Boa tarde pessoal,
Estou a precisar de trocar os pneus do meu Fiat Punto mk2 (medidas 185/60 R14) e andei a pesquisar por aqui. Vi que falam muito bem dos Goodyear EfficientGrip Performance e aqui numa oficina perto de minha casa consigo-os novos a 45€ (mais taxa ecovalor que julgo que seja 1.20€ né?) o que é um preço excelente, nem online estão a esse preço!
Mas li também que estes são uns pneus que duram pouco, li relatos de pessoas a dizer que duraram 5000km e isso para mim é muito muito pouco!
Neste momento não tenho condições monetárias para meter 4 pneus novos ao carro, irei meter 2 novos atrás e 2 semi-novos à frente (ou se for suficiente passar os de trás que estão com menos desgaste, para a frente.. e mudar os de trás). Procuro um pneu que dê para todas as estações e que tenha uma boa relação entre durabilidade, segurança, consumo e ruído. Essencialmente a durabilidade e o consumo :)
O que mais me podem aconselhar dentro destes preços? Acham esses Goodyear uma boa aposta? Apesar de serem pneus de verão, irei dar-me bem no inverno? (Sou de Braga..)
Obrigado desde já por qualquer ajuda!
Um abraço e todos.
Os Goodyear Efficient Grip Performance são uma referência na gama em que se incluem. É uma compra segura e de muita qualidade.
A durabilidade é sempre relativa, e tu, melhor do que ninguém, tens noção dos trajectos que fazes, e da condução que fazes.
E uma das desvantagens de não rodar pneus (isso de por os novos atrás mais não é do que rodar os pneus de trás nos FWD) é que os de trás duram uma eternidade, não é invulgar ver pneus (especialmente os eco) com 6,7, 8 anos atrás, com muito piso e completamente ressequidos...
Para não haverem muitos problemas, é comprar só RWD, costumam gastar os 2 eixos sensivelmente ao mesmo tempo... [;)]
É preciso também ter muito cuidado com os 4wd da moda, há deles que andar com pneus de desgaste muito diferente nos 2 eixos dá direito a mandar o diferencial para o galheiro...
Muito obrigado amigo!
Podem-se, também, considerar pneus de baixo consumo e ruído? Venho de uns firestone, portanto acredito que deva notar muita diferença :)
São silenciosos (67db), "C" na resistência ao rolamento e "A" em piso molhado.
Penso que nesta medida dificilmente consegues melhores valores.
Boas pessoal, o carro (fiesta 99) da Maria está a precisar de pneus à frente.
A medida é 185/55/R14. Digam aí uns pneus baratos e fiáveis :)
Boas.
Eu na vinha viatura (Toyota Verso - monovolume), tenho actualmente uns pneus Pirelli 215 55 R16 97W (ainda são os de origem), sendo que estão a precisar de ser trocados e gostaria de saber a vossa opinião sobre que pneus aconselham.
Destes nunca gostei muito, visto que com o piso molhado não demonstram muita confiança, é a minha opinião.
Agradeço os vossos comentários.
Obrigado.
Obrigado amigo!
E podem ser considerados pneus para todas as estações? Em alguns sites dizia que eram pneus de verão. Darao-se bem no inverno?
Sim, os pneus que usamos são pneus de verão, mas lidam muito bem com piso molhado. Aliás, esses estão classificados com letra A, nesse campo.
Pneus de inverno, são para outras andanças. Desde que não circules por estradas com neve, esses pneus são bons.
Perfeito! Muito obrigado por toda a ajuda :)
O que dizem dos Michelin CrossClimate? Será que compensam para zonas do interior onde costuma chover com frequência e vai havendo gelo no inverno, e neve de vez em quando?
Se cumprirem tudo o que prometem, penso que serão uma excelente alternativa a ter que trocar para pneus de inverno, nessa altura do ano.
Mas eu não costumo trocar, é sempre de pneus de Verão... digamos que só há anos quase que nem neva (região Vila Real)... por isso não justificava trocar... agora com estes não sei... mas possivelmente irei optar por eles no eixo de tracção... Comprei correntes de neve e ainda nunca as cheguei a usar...
Pessoal, uma dúvida rápida.
Carro tinha pneu reforçado de origem(focus 2008).
Recentemente levou dois pneus novos à frente normais.
Até agora (passado uns bons meses) não se notou nada de diferente em condução ou conforto.
Agora, a pedir orçamentos para trocar os outros 2 pneus (os que faltavam de origem) o senhor da midas diz que foi um grande erro e bla bla bla stress na suspensão e não sei que por ter dois pneus não reforçados e só quer dar orçamento de pneus reforçados (xl ou lá o que é)
A dúvida é: faz assim tanto problema ter pneu normal no lugar de um reforçado?
Eu fiquei um pouco com a impressão que o senhor da midas simplesmente queria ter um lucro maior.
Ps: medida 205/50r17 pelo que a parede é baixa o suficiente para nem sequer fazer barriga.
Cumps, jA
Cumps, jA
Para que não fiquem dúvidas sobre o índice de carga mínimo a usar, vês o peso máximo por eixo e a partir daí é só fazer as contas.
A informação do peso máximo por eixo está no DUA, e o índice de carga, está nos pneus. Divides o valor do peso máximo do eixo por dois, e voilá, tens que respeitar esse valor, no índice de carga a usar.
Nessa medida os normais são 89 (580kg) e os reforçados são 93 (650kg).
Se os pneus tiverem índice de carga 89, o peso total do eixo não pode ultrapassar os 1160kg, e se forem 93, 1300kg.
Por vezes, os construtores, optam por comprar apenas o índice de carga superior, para não terem pneus "diferentes", consoante as motorizações e, há também fabricantes de pneus que optam por ter apenas por ter, também, apenas os de índice superior, para não terem que fabricar dois pneus "diferentes".
Cumps, jA
Vê o índice de carga no livrete, ou o peso máximo por eixo. Se o índice dos pneus normais for superior ao que está no livrete, manda o gajo dos pneus dar uma volta, geralmente os pneus reforçados são mais caros.
Isso da suspensão é tanga.
Há no entanto medidas que tendem a só ter oferta "XL", aposto em 205/50R17...
Portanto, não há rigorosamente stress nenhum DESDE que o índice de carga seja superior em compensação do reforço e desde que respeite o que o dua exige?
Estou aqui a ver o dua e o máximo (frente) é 1010 pelo que índice mínimo será 85.
Portanto desde que respeite este 85 na compra do pneu não há qualquer problema, legalmente.
A nível de dia à dia suponho que realmente não faça muita diferença já que já passaram bastos meses com pneus não reforçados à frente sem notar diferença apreciável.
Obrigado!
Cumps, jA
A medida é essa, sim.
Pois parece que há medidas em que o pneu é um pouco estreito para o carro.
O homem pôs-se a dar o exemplo dos runflat.
Foi nessa altura que eu comecei a desconfiar que o gajo do quer é vender.
Obrigado a todos novamente.
Cumps, jA
Sim, runflat, reforçados, é quase a mesma coisa... :) já me faz lembrar a conversa de uma oficina da BMW, que foi lá um cliente que meteu pneus normais com a luz de pressão dos pneus acesa (ninguém calibrou o sensor no computador de bordo depois de ter mudado de pneus...) e disseram que estava a dar erro porque o carro não podia levar pneus normais, só runflat...
