citação:The tools I have found to be the most economical are web based. Some have free versions to download while others may cost you a pretty penny. The best approach would be to identify what your needs are and then do a search for PM tools that meet your needs. You may find the perfect match and it may be shareware!
TIP: Due to MS Project's popularity, try to find a web based program that allows import and export of MS Project files.
www.eproject.com
www.project.net
www.iteamwork.com
citação:You can learn more about Project Insight at http://www.projectinsight.net/
It is a web based project management system and very reasonable in costs. Web based, it is easy for a diverse team to share project information.
Não conheço nenhum dos anteriores, e só usei uma ou outra vez o MS Project...citação:http://www.openworkbench.org/
Barato, baratinho só mesmo o MS Project, emprestado de um amigo...citação:Originalmente colocada por neoxic
Tiranto o M$ Project que custa 800 €, que alternativas há até 400 € no máximo?
citação:Originalmente colocada por worldtiki
