desprogramada?? não tens outra?
Seat Key Fob Programming
Remote Control Programming (1997 ON)
Procedure
1. Switch Ignition ON with new key and leave the key in the ignition.
2. Mechanically lock the vehicle using the Drivers door using a second key.
3. Using the remote control press the Unlock button once, and the horn will sound once.
4. Wait 6 seconds and press the unlock button once to activate the coding procedure. The remote control will now be programmed.
NOTE: When performing programming on additional remotes the procedure is the
same, except
you press the unlock button 2, 3 or 4 times for the different remote.
For example : If programming 2 remotes press the unlock button twice with a 1 second interval between each press, repeat for 3 and 4 remotes.
5. Switch Ignition OFF.
6. Remove key from ignition and check for operation.
7. The coding procedure can be repeated up to 4 times for additional remotes.
8. The ignition must be switched OFF between programming each remote control.
Remote Control Erasing (1997 ON)
Procedure
1. Switch Ignition ON and leave the key in the ignition.
3. Press the remote control unlock button 5 times in 1 second intervals. A short horn will sound.
4. Wait 6 seconds and press the unlock button once to activate memory erase.
5. Switch ignition OFF, all remotes are now tuned in. __________________
ou
- car is locked
- unlock with normal key manually at drivers doorlock
- IGN ON with normal key ... leave it there
- use NEW remote key to lock the car manually at drivers doorlock
- remove remote key from doorlock
- press "lock" at the NEW key, indicator lights will flash
- then hold the "unlock" für ~3 sec. and indicators will flash long and the doors should unlock
- coding procedure should be successfully finished.
Described in our board and confirmed several times ..
