O Templo do Tuning Decente
[br:)]
Anexos
    66,8KB · Visualizações: 0
    66,6KB · Visualizações: 0
Specs ele:
Engine:
- Top Secret prepped block (oil/water galley etc.)
- HKS Step III 2.8 L kit (87 mm x 77.7 mm)
- Nismo N1 bearings and seals
- HKS IN/EX metal gaskets
- Trust extended oil pan and pick up
- Trust oil pan baffle plating
- HKS Metal Flow air filters (x2) & polished speed density conversion
- HKS GT-2835R A/R 0.73 turbine kit (x2)
- ARC Pro Class twin entry intercooler
- Nismo GT surge tank
- Top Secret/NAPREC custom port matched
- Custom NAPREC ø49 mm oversized throttles
- HKS exhaust manifolds
- HKS GT wastegate (x2)
- Top Secret Drag front pipes ø 80 mm
- HKS Metal Sports ø 75 mm sports catalyser
- Trust Ti-R titanium exhaust system 90 mm
- Bosh Motorsport 550 fuel pumps (x2) & Nismo in-tank fuel pump
- Top Secret fuel collector
- Earls custom braided fuel lines & fittings
- Sard fuel pressure regulator
- Trust Grex fuel rail
- Top Secret/Sard 1000 cc/min injectors
- Top Secret SPL ported & polished head
- HKS 1.2 mm metal head gasket
- Tomei head bolts
- HKS 272º & 10.5 mm lift (IN/EX)
- HKS Limited Edition Valcon V-Cam Pro 16/30
- Tomei valve springs (double)
- Tomei titanium valve retainers
- Tomei valve seats
- Top Secret slide cam pulleys
- Top Secret Super timing belt
- Blitz Racing 8 spark plugs
- Nismo N1 engine mounts
- Trust oil pump
- Nismo N1 water pump
- Yashio Super Race radiator
- Sard Type-D thermo
- Sard water filler cap
- Billion polished power steering fluid tank
- Top Secret oil catch tank custom rerouted into intake
- HRD 130A High Power alternator
- M-spec Nur high power battery and upgraded lines
- HKS 15-row oil coole
- Trust oil filter relocation & HKS billet filler cap
- Top Secret oil bypass collector tank & Earls lines
- Tabata RR Race radiator & HKS cap
- Garage Defend carbon radiator shroud
- Samco silicone radiator hoses
- Robson carbon fan shroud
- Robson carbon fuse box cover
- Robson carbon spark cover
- Top Secret chromed engine covers
- HKS F-Con V Pro fueling computer
Transmission:
- ATS twin plate carbon clutch with 1350 kg pressure plate
- ATS lightened & balanced flywheel
- Nismo Spec III racing clutch operating cylinder
- Top Secret Super Release shift fork
- Nismo large diameter input shaft
- Cusco Type RS rear LSD
Suspension & Brakes:
- Nitron Pro NTCNIO12R 3-way adjustable racing suspension kit
- Cusco adjustable rear upper arms
- Top Secret HICAS remover kit
- Ikeya Formula front pillow adjuster links
- Ikeya Formula front upper links
- Ikeya Formula roll center adjuster lower arms kit
- Ikeya Formula tie rod ends
- Ikeya Formula multi-link spacers
- Ikeya Formula adjuster rear lower arms
- Ikeya Formula rear camber adjuster bar arms
- Ikeya Formula traction adjuster rods
- Ikeya Formula rear knuckle pillow bushes
- Cusco carbon Pro front strut bar
- Brembo 8-pot calipers with 380 mm 2-piee slotted rotors (front)
- Brembo 4-pot calipers with 355 mm 2-piece slotted rotors (rear)
- Endless CC-R brake pads
- Top Secret braided brake lines
Wheels & Tires:
- Spark Silver Volk Racing TE37 19×9.5 +12 (front & rear)
- Bridgestone Potenza RE-11 275/30/19 (front & rear)
Exterior:
- Top Secret custom dark grey blue pearl paint with glass coating
- Nismo Z-tune front bumper
- Top Secret carbon front diffuser
- Nismo Z-tune front fenders
- Nismo R-tune carbon vented hood
- Top Secret carbon hood dampers
- Do-Luck side skirts
- Top Secret rear carbon diffuser
- Top Secret rear carbon vortex generators
- Ganador Super Mirror
- Nismo dry carbon rear wing blade
- Custom Top Secret carbon wing mounts
- Shaved 3rd brake light and lock from trunk lid
- Top Secret smoked LED fog lights/reverse lights
- Sunline Racing v2 LED lights with LED blinkers
- Nismo front & side smoked indicators
- Nismo carbon pillar garnish
- R35 GT-R front grille emblem
- PIAA carbon type wipers
Interior:
- Top Secret custom spot welded chassis
- Top Secret/Personal steering wheel with Robson Leather alcantara & blue stitching
- RBH boss
- Ronson Leather custom carbon/alcantara upholstering
- Robson Leather carbon center console & various inserts
- Robson Leather alcantara headliner
- Nismo Combination Meter
- XaNavi Birdview navigation system
- Blitz Type-R Dual SBC
- Nismo MFD Ver. 2
- HKS Type 1 turbo timer
- HKS Variable fan controller
- HKS V-Cam controller
- NEKO Corporation AF700 A/F meter
- Pioneer DEH P919 head unit
- Top Secret gear knob
- V-spec II pedal set
Para mim tuning decente é exterior de origem, e motor turbinado ou modificado :) Quando era miudo adorava tuning, cheguei a querer ter um [:D]
Somos da mesma opinião[;)], fica uma foto de um dos melhores projectos que existem em portugal"para mim" [:cool:]
Pelo que li o motor deste carro anda agora a rolar noutro carro, e este esta a espera de um novo pulmão.[:cool:]
Para mim o melhor carro do LOW, manda uma postura do caraças.
Anexos
    65,6KB · Visualizações: 0
    89,1KB · Visualizações: 0
    86,3KB · Visualizações: 0
    77,4KB · Visualizações: 0
