o diesel é toxico?
Afcivic
Membro histórico
"What Is The Difference Between Diesel And Gasoline?
Diesel and gasoline are both made up of many different hydrocarbons, which are compounds consisting of hydrogen and carbon elements. However, diesel carbon atoms are in longer chains than gasoline. Diesel chains have 14 carbon atoms whereas gasoline chains have 9. The chemical abreviations are: C14H30 and C9H20 respectively. Diesel fuel is consequently heavier and oilier and requires less refining than gasoline.
The main differences between diesel and gasoline engines are as follows:
a) A diesel engine takes air into the cylinder and compresses it. Fuel is then injected directly into the cylinder. The heat of the compression lights the fuel spontaneously. A gasoline engine takes in a mixture of gas and air. The fuel and air are mixed outside of the cylinder, once they are both injected they require a spark to ignite.
b) A diesel engine uses a much higher compression ratio than a gasoline engine. The heat created in a diesel engine by this higher compression is therefore, much greater than the heat created in a gasoline engine.
Cause For Concern?
Diesel fuel not only contains a higher portion of dangerous substances compared to gasoline (as a result of less refining), but also the high-heat combustion in diesel engines allows a larger portion of these substances to form and be released. The high heat in diesel engines creates NOx. NOx reacts with sunlight and Volatile Organic Compounds (VOCs) to form smog, which triggers asthma. The Clean Air Network estimated that in 1997, smog triggered 370,000 asthma attacks, and 9,600 emergency room visits in Pennsylvania. Fourteen Americans die every day from asthma. SO2 contributes to particulate matter (soot) and when inhaled, particles of soot get lodged deep in the lungs causing infection, and potentially cancer and premature death. CO deprives the heart, brain, lungs, and other tissues of oxygen.
Diesel exhaust contains more than 40 toxic substances, many more than are found in gasoline. The U.S. EPA stated that diesel exhaust is a ‘likely human carcinogen’, or cancer-causing agent. Studies in California suggest that over 70% of all cancers attributed to air pollution are caused by diesel exhaust.
Carcinogens in diesel exhaust include arsenic and benzene. Other toxics include formaldehyde, cyanide, dioxin, ammonia, and 1-3 butadiene which, can cause longterm health problems such as lung, kidney, and nervous system damage, and shortterm effects such as skin and eye irritation, and aggravated respiratory problems.
Diesel exhaust contains thousands of chemicals, over 40 have been identified by the U.S. EPA as toxic, and many labeled as “likely human carcinogens.”
How Bad Is The Problem?
People are exposed to the dangers of inhaling diesel emissions every day. The threat is especially serious for people with respiratory and cardiovascular problems. Asthma sufferers are particularly affected by diesel particulates as the tiny particles disrupt their already disabled breathing.
The elderly are also highly affected as their immune systems are compromised or weaker. High diesel exposure areas include, walking on the sidewalk along diesel bus routes, cycling near polluting diesel buses and trucks, being in a car behind a diesel bus or truck, and alarmingly, being a passenger in a diesel bus or truck.
The most recent discovery, and perhaps the most alarming, was the January, 2001 announcement by the California Air Resources Board, that a child riding inside a diesel school bus may be exposed to four times more toxic diesel exhaust than someone standing or riding beside it.Under federal law these exposures are 23 to 46 times higher than the exposure rate considered to be a ‘significant cancer risk’.The danger to children is that exposures are not only higher inside diesel school buses, but children’s respiratory systems work at four times the rate of an adult, which makes them especially susceptible to the effects of diesel exhaust.
How Can Diesel Emissions Be Reduced?
In December 2000, a new EPA regulation for emissions standards on heavy-duty diesel engines and low sulfur fuel was announced. To meet the new standards emission after-treatment technologies will have to be installed. Unlike cars which have catalytic converters, most heavy duty vehicles do not have such devices. The devices are not tolerant to sulfur, so the diesel rule establishes a new maximum sulfur level in fuel.
Currently the maximum sulfur level is 500 parts per million/ppm (by weight). The new regulation sets a cap on sulfur at 15 ppm. The rule applies to all new model year 2007 heavy-duty diesel vehicles. The introduction of ultra low sulfur fuel will be phased in, and by 2006, eighty percent of all highway fuel must meet
the new standard. It must be available nationwide by 2010.
This development will play a large part in reducing diesel pollution. Unfortunately, oil refiners say the technology necessary to produce the low-sulfur fuel is cost prohibitive. As of August 2001 the U.S. EPA convened a panel to review the rule. However, there are other non-petroleum based fuels available on the market today that represent a more permanent solution. Several fleets across the U.S. have already commited to using vehicles fueled by alternatives to diesel and gasoline. Pennsylvania has it’s own success stories. Lower Merion School District in Ardmore began its move to CNG buses in 1995, when the local community raised concerns about noise and pollution from the district’s diesel school buses. The school district now has 63 CNG buses—more than half its fleet—and plans to become the first Pennsylvania school district whose fleet runs entirely on alternative fuels. Lower Merion displaces over 800 gallons of diesel fuel every day by using CNG. (Compressed Natural Gas)
Seven PA transit agencies currently operate 95 CNG buses in twelve counties across the state; Erie, McKean, Cameron, Clearfield, Jefferson, Allegheny, Indiana, Centre, York, and Berks counties. Central Area Transit Authority has the largest CNG transit fleet in the state operating 44 CNG buses. In total, the 95
buses reduce emissions of NOx, CO, and VOCs by 151.82 tons each year, which is equivalent to taking 1600 cars off the road.
What Can You Do?
- Report buses emitting visible black smoke to your local transit authority immediately. Report trucks emitting black smoke to their fleet operators immediately.
- Contact your member of Congress encouraging them to support the implementation of clean transit fleets, other public fleets (trash trucks, airport vehicles etc.), and school bus fleets. To find your representatives contact information go to http://www.congress.org/congressorg/dbq/officials.
- Contact your state Senator to encourage them to support the implementation of and funding for clean fueled fleets. To find your representative go to http://www.senate.gov.
- Advise fleet managers to contact the Greater Philadelphia Clean Cities Coalition (215-567-4004 x273) & the Pittsburg Region Clean Cities Coalition 412-391-5590 x310) to find out about funding opportunities for alternative fuel vehicle purchases and conversions.
- Write a letter to the editor of your newspaper, in favor of alternative fuels and a clean fueled fleets program.
- Enlist other concerned parents, your PTA, and members of the school board to advocate for, and pass a resolution calling for clean school buses
in: http://www.cleanair.org/
http://www.cleanair.org/Air/diesel_fact ... danger.pdf
uma tradução By google
"Qual é a diferença entre os motores diesel e gasolina?
Motores diesel ea gasolina são ambos compostos de diversos hidrocarbonetos, que são compostos constituídos por elementos carbono e hidrogênio. No entanto, diesel átomos de carbono estão em cadeias mais longo do que a gasolina. Diesel cadeias têm 14 átomos de carbono que têm gasolina cadeias 9. A química abreviations são: C14H30 ea C9H20 respectivamente. O combustível para motores diesel seja, consequentemente, mais pesada e oilier refinação e requer menos do que a gasolina.
As principais diferenças entre motores diesel e gasolina são as seguintes:
a) Um motor diesel tem ar no cilindro e comprime-o. O combustível é injetado diretamente em seguida, o cilindro. O calor das luzes da compressão do combustível espontaneamente. Um motor a gasolina leva em uma mistura de gás e do ar. O combustível eo ar são misturados fora do cilindro, uma vez que ambos são injetados eles exigem uma faísca para inflamar.
b) Um motor diesel utiliza um rácio compressão muito mais elevada do que motores a gasolina. O calor criado em um motor diesel por esta compressão é superior, pois, muito maior do que o calor criado em motores a gasolina.
Motivo de preocupação?
O combustível para motores diesel não só contém uma porção maior de substâncias perigosas, em comparação com a gasolina (como resultado de menos de refinação), mas também os de alta caloríficos superiores em motores a diesel permite um maior parte destas substâncias e de forma a ser libertados. O elevado calor em motores a diesel cria NOx. NOx reage com a luz solar e compostos orgânicos voláteis (COV) para a constituição de smog, que desencadeia a asma. A Clean Air Rede estima que em 1997, desencadeou smog 370000 asma, sala de emergência e de 9600 visitas na Pensilvânia. Catorze americanos morrem todos os dias a partir de asma. SO2 contribui para as partículas em suspensão (fuligem) e quando inaladas, partículas de fuligem obter apresentado profundos causando infecção nos pulmões, e, potencialmente, cancro e morte prematura. CO priva o coração, cérebro, pulmões e outros tecidos de oxigênio.
Diesel escape contém mais de 40 substâncias tóxicas, muitas mais que são encontradas na gasolina. Os E.U. APE afirmou que escape diesel é um dos prováveis carcinogéneo humano ', ou agente causador de câncer. Estudos na Califórnia sugerem que mais de 70% de todos os cancros são atribuídas à poluição do ar causada pelos motores diesel escape.
Cancerígenos no diesel escape incluem arsênico e benzeno. Outros toxics incluem formaldeído, cianeto, dioxinas, amônia e 1-3 butadieno, que, a longo prazo pode causar problemas de saúde tais como pulmão, rim, sistema nervoso e danos, efeitos e curto prazo, tais como irritação cutânea e ocular, e agrava os problemas respiratórios.
Diesel escape contém milhares de substâncias químicas, mais de 40 foram identificadas pela EPA como os E.U. tóxicos, e muitos rotulados como "prováveis carcinogéneos humanos."
Como é mau o problema?
As pessoas são expostas aos perigos das emissões diesel inalar todos os dias. A ameaça é especialmente grave para as pessoas com problemas respiratórios e cardiovasculares. Doentes asmáticos são particularmente afectados pelas partículas diesel como minúsculas partículas perturbar a sua respiração já desativada.
Os idosos também são altamente afectados como os seus sistemas imunitários estão comprometidos ou mais fraco. Alto diesel exposição áreas incluem, andando na calçada, ao longo diesel rotas ônibus, bicicleta próximo poluente diesel autocarros e camiões, sendo em um carro atrás de um ônibus ou caminhão diesel, e de forma alarmante, sendo um passageiro em um ônibus ou caminhão diesel.
A mais recente descoberta, e talvez o mais alarmante, foi o de janeiro, 2001 anúncio da California Air Resources Board, que pilotando uma criança dentro de um ônibus escolar diesel poderá ser exposto a quatro vezes mais gases tóxicos diesel do que alguém em pé ou andando lado dele . Ao abrigo da lei federal estas exposições são 23 a 46 vezes mais elevada do que a taxa de exposição a ser considerados um "risco significativo câncer". O perigo é que as crianças a riscos mais elevados não são apenas os autocarros escolares diesel interior, mas as crianças do trabalho em sistemas respiratório quatro vezes a tarifa de um adulto, o que os torna especialmente suscetíveis aos efeitos do diesel escape.
Como podem ser reduzidas as emissões diesel?
Em dezembro de 2000, uma nova regulamentação para a APE normas sobre as emissões dos motores diesel pesados, e de baixo enxofre combustível foi anunciado. Para satisfazer as novas normas de emissões pós-tratamento tecnologias terão de ser instalado. Ao contrário carros que já conversores catalíticos, a maioria dos veículos pesados não têm tais dispositivos. Os dispositivos não são tolerantes ao enxofre, de modo a diesel regra estabelece um novo nível máximo de enxofre no combustível.
Atualmente o nível máximo de enxofre é de 500 partes por milhão / ppm (em massa). O novo regulamento estabelece um limite máximo em enxofre de 15 ppm. A regra se aplica a todos os novos modelos ano de 2007 pesados, veículos com motor diesel. A introdução de ultra baixo enxofre no combustível será faseada, e em 2006, oitenta por cento de todos os combustíveis devem preencher rodovia
a nova norma. Ela deve estar disponível a nível nacional até 2010.
Este desenvolvimento pode jogar um papel importante na redução da poluição diesel. Infelizmente, refinarias de petróleo dizem que a tecnologia necessária para produzir o combustível com baixo teor em enxofre é o custo proibitivo. A partir de Agosto de 2001 os E.U. APE convocou um painel de revisão do Estado. No entanto, existem outros não-petrolífero com base em combustíveis disponíveis no mercado hoje que representam uma solução mais definitiva. Vários frotas em todo os E.U. já empenhados em utilizar veículos alimentado por alternativas ao combustível para motores diesel e gasolina. Pensilvânia tem suas próprias histórias de sucesso. Lower Merion Distrito Escolar de Ardmore começou a sua mudança para GNC ônibus, em 1995, quando a comunidade local, levantou preocupações sobre o ruído e poluição do diesel a partir do distrito escolar ônibus. O distrito escolar tem agora 63 GNC ônibus-mais de metade da sua frota-e os planos de se tornar o primeiro Pensilvânia distrito escolar cuja frota é executado inteiramente sobre os combustíveis alternativos. Lower Merion desloca a mais de 800 galões de combustível para motores diesel todos os dias através de GNC. (Gás natural comprimido)
Sete PA trânsito agências funcionam atualmente 95 GNC ônibus em doze municípios em todo o estado; Erie, McKean, Cameron, Clearfield, Jefferson, Allegheny, Indiana, Centro, York, Berks e municípios. Área Central Transit Authority tem a maior frota GNC trânsito no estado de funcionamento 44 GNC ônibus. No total, a 95
autocarros redução das emissões de NOx, CO, COV e em 151,82 mil toneladas por ano, o que equivale a 1600 tendo carros fora da estrada.
O que você pode fazer?
-- Relatório ônibus emitem fumo negro visível para o seu local de trânsito competente imediatamente. Relatório caminhões que emitem fumaça preta para a sua frota operadores imediatamente.
-- Entre em contato com o membro do Congresso incentivá-los a apoiar a implementação das frotas limpo trânsito, de outras frotas públicas (trash caminhões, veículos aeroporto etc), ea escola frotas de ônibus. Para encontrar o seu contacto representantes informações vá para http://www.congress.org/congressorg/dbq/officials.
-- Entre em contato com o senador estadual para incentivá-los a apoiar a implementação do financiamento para a limpeza e alimentado frotas. Para encontrar o seu representante para ir http://www.senate.gov.
-- Aconselhar os gestores de frota, para entrar em contato com o Grande Filadélfia Clean Cities Coalition (215-567-4004 x273) & Pittsburg a Região Clean Cities Coalition 412-391-5590 x310) para saber sobre as oportunidades de financiamento para o combustível alternativo veículo compras e conversões.
-- Escreve uma carta ao editor do seu jornal, em favor dos combustíveis alternativos e de um programa limpo alimentado frotas.
-- Mobilizar outros interessados pais, seus PTA, e os membros do conselho de advogar para a escola, e aprovamos uma resolução apelando para limpar os autocarros escolares
em: http://www.cleanair.org/
E então em LA, em que a larga maioria dos veículos é movido a DIESEL.
Logo, afirmar que é reponsável por 70% dos cancros provocados pelas emissões dos carrinhos ... [:D] [:p]
Um estudo feito por americanos, que são completamente adversos ao diesel, vem dizer que o mesmo é tóxico e nocivo para a saúde e que a gasolina é que é boa? Deixem-me rir.
nonsense, porquê?
Porque o diesel é criminizado porque emite tóxicos E partículas.
O otto também emite tóxicos, mas são menos "visiveis".
Nonsense porque:
1) os norte-americanos são os últimos da lista a poder falar em redução de emissões;
2) seria interessante observar os consumos dos veículos pesados se estes deixassem os motores diesel e passassem a otto.
Secavam as reservas de petróleo em 3 dias...[:)]
3) quer-me parecer que o tópico vai descambar em elogios à Honda pelo Hybrid e pelo ClarityFCX. [:p]
Nonsense porque:
então se o estudo for espanhol já tem mais interesse? é que já coloquei por aqui um estudo em que se coloca em causa a proibição de veiculos diesel em cidades espanholas (como alicante, madrid,...)
são menos visiveis e em menos quantidade, ou achas que não?
Por acaso não acho o assunto assim tão nonsense.
Penso que o que se passa é que o Gasoleo nos EUA tem muito pior qualidade que o nosso na Europa. Os tais tratamentos que lá têm um custo proibitivo penso que já serão feitos por cá.
Inclusivamente nos EUA esta nova geração de veiculos diesel de altas performances não é vendida porque o gasoleo deles não tem qualidade suficiente e iria provocar avarias nos sistemas de injecção etc.
Contudo os veículos diesel continuam a provocar poluição preocupante, nomeadamente oxidos de azoto e particulas.
Tenho reparado nos escapes de BMW com o motor 3.0 equipados com FAP e aquilo parece quase um escape de um OTTO, (relativamente) limpo.
Moulinex...a solução
Pergunta:
- A Moulinex é que é a solução ???
Resposta:
- Claro que sim...
nem sequer me passou outra coisa pela cabeça, mais um tópico in GALVANIZE mode...
Quem foi que te disse isto?
A California é o estado dos EUA com maiores exigencias em termos de poluição automóvel. A maior parte dos veículos têm versões expecificas mais exigentes para poderem ser vendidos nesse estado.
Edit: LA = Los Angeles ?
A MB está a vender Diesel e sente-se bem. Tal como a VW e um pouco a BMW.
Na maioria dos Estados, o Diesel comercializado tem as mesmas particularidades em termos de partículas que na Europa. Há a acrescentar que as preocupações ambientais em alguns Estados, ultrapassam na prática as da Europa.
O problema das vendas de Diesel nos USA é mesmo o hábito e a alteração que terá (e está) de ser feita na maioria das bombas de combustível de modo que o Diesel esteja presente na área de abastecimento dos ligeiros, em vez de estar na zona dos pesados.
Por acaso o que li era precisamente o inverso.
1- Praticamente não se vendem carros DIESEL nos EUA. Já se venderam ate aos anos 90 mas depois desapareceram.
2- Os diesel common rail precisam de diesel de boa qualidade e dessuslfurado que era dificil de encontrar e raro, o diesel à venda nos EUA era quase FUEL para motores pesados. Só recentemente é que começaram a vender automóveis diesel porque entretanto ja começa a estar disponivel o gasóleo de boa qualidade.
Posso-te dizer que o gasoleo americano é muito superior ao nosso, nomeadamente no que toca a qualidade de refinação e em teor de enxofre.
Só para teres uma ideia, enquanto existe gasoleo que é rejeitado no controle de qualidade em instalações americanas em Portugal, o mesmo é vendido nas bombas sem qualquer problema. E mais, o meu antigo Skoda Octavia 2.0 TDi, com gasoleo dentro das normas americanas, gastava menos 1,5 a 2,0 l/100 km, o motor parecia outro a nível de rendimento e deponibilidade, e fazia muito menos fumo (dava por isso de manhã quando punha o carro a trabalhar na garagem).
Os autocarros escolares nos EUA, em muitos estados gastam é GPL e não CNG.
Já é o segundo artigo que vejo, em que falam em CNG quando na realidade é GPL-Auto, poxa q o lobby é forte.
Não sei. Vendo essa notícia acima e olhando para a nossa regulamentação
http://dre.pt/pdf1sdip/2004/12/293A00/71527157.PDF fico com a ideia contrária.
O nosso gasóleo desde 2005 que tem um limite de enxofre de 50 ppm e não 500 como nos EUA. Desde essa data deve estar disponivel gasoleo com 10 ppm, menos que os 15 previstos para os EUA. A partir do fim deste ano todos os gasoleos têm de estar nos 10 ppm. Os tais 500 ppm nos EUA eram incompativeis com os diesel modernos como os conhecemos na Europa. Não foi por mero acaso que a tecnologia se desenvolveu por cá e não nos EUA...
O único gasoleo que tens em Portugal que obedece a estas regras é o chamado gasoleo especial (os tais que são mais caros).
Só que em Portugal não se liga aos outros contaminantes que existem nos combustíveis (especialmente misturas com outros tipos de caburantes, água e produtos de limpeza de tanques) ao contrário dos americanos (um carro a diesel com um motor moderno, têm uma muito maior exigência e menor tolerância a esse tipo de contaminantes).
E não preciso de ir para carros a gasoleo, basta falar do meu TFSI ou compara-lo com outros iguais aí no continente, aonde os consumos são inferiores e o rendimento superior (é uma questão de qualidade de gasolinas).
