citação:Originalmente colocada por Suarez
São os que têm a mala alongada
2 portas[?]citação:Originalmente colocada por Lino Marques
E considera-se que um sedan tem 2 ou 4 portas, nunca 3 ou 5![]()
citação:Originalmente colocada por _EL _VT_MB_
Os sedan são sempre 4 portas…
Os que têm a forma dum sedan ou liftback (já que o vidro pode incluir ou não a porta da mala) e possuem 2 portas são considerados coupes!
Cumps.
citação: Sedan car, American English terminology (saloon in British English), is one of the most common body styles of the modern automobile. At its most basic, the sedan is a passenger car with a separate hood (bonnet in British English), covering the engine in the front, and a separate trunk (boot in British English), for luggage at the rear—the archetypical "3-box" car.
Historically, the usage of the term sedan has changed over time. Several versions of the body style exist, including four-door, two-door and fastback models.
Contents [hide]
1 Description
2 Types of sedan
2.1 Two-door sedan
2.2 Hardtop and fastback sedans
2.3 Hatchback sedan
3 Small sedans
4 Terminology
4.1 Origin
4.2 International terminology
[edit]
Description
A sedan seats four or more and has a fixed roof that is full-height up to the rear window. Most commonly it is a four-door; two-door is rarer but they do occur (more so historically). In the U.S., this term has been used to denote a car with fixed window frames, as opposed to the hardtop style where the sash, if any, winds down with the glass. As hardtops have become rarer, this distinction is no longer so important.
[edit]
Types of sedan
[edit]
Two-door sedan
A two-door sedan is defined by the SAE as any two-door model with rear accommodation greater than or equal to 33 cubic feet (0.934 m³) in volume (a calculation made by multiplying the legroom, shoulder room, and headroom). By this standard, the Chevrolet Monte Carlo, Ferrari 612 Scaglietti, and Mercedes-Benz CL-Class coupes are all two-door sedans. Only a few sources, however (including the magazine Car and Driver), use the two-door sedan label in this manner.
In the popular vernacular, a two-door sedan is defined by appearance and not by volume—vehicles with a so-called formal roofline are called two-door sedans, while those with the more common sloping backlight are called coupes. This has led to the so-called four-door coupe, which is a sedan with classic coupe-like proportions. The designation was first applied by Rover to a variant of its P5 from 1962 until 1973. It has more recently been adopted by DaimlerChrysler for the Mercedes-Benz CLS-Class, which the Mercedes marketing department has erroneously called the first four-door coupe. Other companies are leaping into the segment as well, but the term four-door coupe is entirely aesthetical, and not the product of any formal definition. To make matters even more clouded, the Mazda RX-8 meets the volume requirement to be called a sedan, but it has vestigial rear-hinged rear doors, making it a 2+2-door sedan.
