Fórmula 1 2023
Estado
Desde a volta 25 que o Leclerc estava com problemas, mas o Max é um sobredotado que o apanhou nas voltas finais... 😬🤣
https://x.com/leclercsletters/status...919980370?s=20
Não sei porque perco tempo, mas cá vai...
O Max nem ganhou grande tempo ao Lec, ganhou a todos..
À volta 60 o Max estava a 30 secs do Lec e o Lec a 18.6 secs do Hamilton, no fim da corrida o Max estava a a 0.26 do Lec e o Lec a 19.90 do Hamilton.
Portanto o Max até nem ganhou assim tanto tempo ao Lec, ganhou foi aos 3 da frente..
E até nem acho que fez grande corrida.. agora sempre a bater no gajo cansa, deves ter pesadelos com o rapaz...
Why new flexi-floor suspicions have kicked off in Formula 1
The introduction of a new flexi-wing technical directive at the Singapore Grand Prix was always going to trigger interest if there was any shuffling of Formula 1’s pecking order.
So, it was little wonder that Red Bull team boss Christian Horner, whose team has been dominant in F1 2023 up until now, found himself having to repeatedly dismiss any suggestions that his squad’s struggles were related to new FIA stipulations over the wings.
Backing up his argument is the fact that, with a flexi-wing estimated to be only worth about one-tenth of a second around Singapore, the scale of Red Bull’s pace drop pointed to other factors being at play as the RB19 proved itself difficult to get into the right set-up window around the Marina Bay circuit.
Plus, according to consensus in the paddock, the focus of the FIA push on flexi-wings was not in fact Red Bull, as it was others who had been perhaps pushing the boundaries in this area far more. While it was easy to link a potential shuffling of the order in Singapore - some teams looked better than normal, others had drifted back - with the timing of the much-talked about flexi-wing technical directive (TD), it was actually another FIA document that had gone under the radar in recent weeks which served to fuel bigger intrigue for engineers.
Plank games
At the same time the FIA issued its TD on flexi-wings (TD18) in late August, Motorsport.com has learned it had also sent out a revision to the famous TD39 that was introduced at the 2022 Canadian Grand Prix, which had originally been aimed at bringing an end to porpoising.
One of the factors to trigger car porpoising was suspected to be teams playing around with flexible floors, which is why from last year fresh stipulations came in about the stiffness of floors and the measurements of planks.
The wildest theories at the time pointed to teams running moveable skid block designs, that disappeared into the plank area so did not get worn when the car ran close to the ground and therefore did not wear down beyond the allowed tolerances.
This was possible to do because, at the time, only a small section of the skid block was measured to check on compliance post-race.
However, to stamp out the practice, the FIA declared that measurements would be taken around 75% of the skid block radius - effectively preventing small areas getting protected.
The matter seemed to have gone away, but during 2023 it has emerged that teams have still been playing around in this area and continue to push the limits with floor flexibility because it is such a key performance differentiator.
The focus of this latest push appears to suggest that teams have shifted their focus away from the skid block moving, to it now being the plank that is the moveable component as teams exploit a tolerance within the rules that allows the plank to slightly deflect.
Article 3.15.8 of F1’s Technical Regulations states that: “Bodywork within RV-PLANK may deflect no more than 2mm at the two holes in the plank at XF=1080 and no more than 2mm at the rearmost hole, when the car, without driver, is supported at these positions [for testing].”
It is suggested that this 2mm tolerance has been viewed not as a limitation by some teams but an opportunity to get away with some extra flexibility to help drive performance gains.
One theory that emerged in Singapore was that this could help allow the plank and floor to get sucked down at high speed thanks to this flexibility, delivering a nice downforce boost, while the skid blocks remained static and out of the way so were at no risk of being worn.
The skid blocks were in effect disappearing just like they were in 2022. But while back then they were being moved, this time it was plank around it that was flexible.
If a team was manipulating the floor like this, it would mean the plank could in theory be worn away by running super close to the ground without the risk of damaging the skid blocks for their post-race FIA checks. Stopping the flexing
This potential exploitation of flexibility in the floor is the focus of the latest TD39 revisions, with the FIA stating in its updated documents that: “We have become aware of design details in the region of the skids…that aim to take maximum advantage of the permitted stiffness in these regions.
“Whilst these designs may comply with the deflection requirements of 3.15.6 and 3.15.8, we would like to remind teams that designs must still comply with the relevant bodywork dimensional constraints.”
The theories about moveable planks drew further credence with the FIA reminding teams that there had to be a continuous surface on the reference plane.
It also added: “Designs must not utilise breaks in this surface to facilitate differences in vertical stiffness across the break or to facilitate differential motion across the break that lead to discontinuities in the surface.”
To ensure teams stopped playing around with any tricks, the FIA said that certain designs were to be outlawed along the ‘reference plane’ – which is in effect the plank. These were:
1. Gaps, cuts or butted joints in the reference plane in the vicinity of the designated holes and/or skids.
2. Frequent or systematic damage, cracks or breakages of the surface of the reference plane or bodywork in the vicinity of the designated holes and/or skids.
3. Elastomeric or very compliant materials on the reference plane.
4. Folded surfaces or bellows type joints, whether elastomeric or not.
Just as had happened with the latest FIA flexi wing affair, from the Singapore Grand Prix teams had to submit their CAD designs and FE analysis for the front skid block, plus drawings of any flexibility around the hole. Shaking up the grid
Any team that suddenly had to change approach with its floor to fully comply with the new stipulations would face an obvious performance drop, and probably also have to relearn a lot about ride heights and where to position their floor in relation to the track.
But while Red Bull endured a weekend where it seemed a bit lost with set-up, rivals were not yet ready to believe that this was anything more than a quirk of the unique Singapore track. And Horner was crystal clear about how much his team had changed on its car in relation to the TDs. “Zero,” he said.
McLaren boss Andrea Stella was sceptical about the TDs being a factor in what happened to Red Bull, as he said its pace drop was in excess of anything linked to the flexi wing and floor demands.
“I don't know whether Red Bull had been affected or not by the TD,” he said. “But I would say that even if there was an effect, this effect wouldn't be as large as the deficit of performance that meant they were out of Q3. So I would exclude that that's the sole reason: if it's a reason at all.”
For Mercedes, whose own squad back in 2015 endured a massive performance drop with a dominant car in Singapore, the reality is that the Marina Bay circuit can be a bit of an outlier to throw up surprises.
Speaking after qualifying about whether he felt Red Bull had been hurt by the TDs, Mercedes boss Toto Wolff said: “We've been in Singapore with a dominant car and were not able to perform.
“But it's so difficult. We have one set of data now [the Singapore GP] and then we're going to a totally different track where that plays a role. So let's wait.”
Teams are now waiting with anticipation to see what happens in Japan this weekend, with the Suzuka circuit the perfect place to better see the true impact of the TDs on car form up and down the grid.
A return to the status quo we’ve seen for much of the season would serve to draw a firm line under talk that any teams had been operating in a grey area with their wings and floors to gain an unfair advantage.
But if the F1 form book remains as shuffled up as it was in Singapore, then expect the intrigue to step up a gear.
https://www.motorsport.com/f1/news/f1-flexi-floor-suspicions-explained/10522243/
Rivals call for FIA ‘consistency’ after Max Verstappen reprimand confusion
Aston Martin have called for “consistency” in FIA punishments after Max Verstappen appeared to get off lightly during qualifying for the Singapore Grand Prix.​
Depois dizem que o menino não é suportado pela fia.....faz 3 numa tarde e só leva: " o menino porta-se bem para a próxima, tá bem.....".....eh pah......é por demais evidente !!!!!!
Isso já é antigo.
Esse carro foi alugado no Japão e ele fez essas figuras! O dono da empresa processou-o depois (quando o vídeo ficou viral) por conduzir dessa forma um carro que não era dele.
Hamilton é o verdadeiro Chico do Boné. [:D]
FAMÍLIA!
F1: Brundle ficou surpreso com falta de penalidade para Verstappen
A Red Bull já vinha afirmando anteriormente, que o GP de Singapura de Fórmula 1seria o mais difícil para a equipe em 2023. E isso se provou verdadeiro. Max Verstappen registrou seu pior resultado na atual temporada, com um quinto lugar.
Na própria Red Bull, eles culpam as características da pista, mas também circularam vários rumores imediatos de que o ritmo pouco impressionante de Verstappen e Sergio Perez, se devia à nova diretriz técnica da FIA, em vigor a partir da corrida em Singapura, e que estabeleceu regras mais duras em relação à flexibilidade das asas. O chefe da equipe, Christian Horner negou veementemente essa possibilidade, mas coincidência ou não, o desempenho da equipe caiu.
Martin Brundle, ex-piloto de F1 e atual comentarista, afirmou: “O carro que havia grudado na pista como um lagarto em cola supergrip, durante toda esta temporada, de repente parecia quase inguiável em Singapura. A equipe tentou encontrar uma configuração de carro para lidar com as ondulações e os desafios específicos do circuito em termos de rigidez vertical e altura do chassi, mas parece que tudo deu errado”, disse ele em sua coluna para a Sky Sports.
O problema da Red Bull no Circuito de Marina Bay Street, foi principalmente na configuração. O equilíbrio não estava lá, e Verstappen teve uma difícil sessão de classificação na qual foi investigado várias vezes pela direção de prova. Na saída dos boxes, ele ficou parado por muito tempo e na pista pode ter atrapalhado alguém duas vezes.
Especialmente no caso de Yuki Tsunoda, o próprio Verstappen admitiu ser culpado por ter atraplhado o piloto japonês. No entanto, o holandês não recebeu nenhuma penalideade de grid, como era esperado por todos. Brundle se surpreendeu com isso. “Quando se consideram as outras penalizações aplicadas nesta temporada, foi uma grande surpresa para muitos no paddock, o que inclui, com confiança, a equipe e o piloto em questão. O fato de a equipe AlphaTauri de Tsunoda não ter enviado um representante à audiência, embora seja a equipe júnior da Red Bull, foi uma decepção esportiva para mim.”
Normalmente, os comissários convocam dois representantes das equipes, os do ‘infrator’ e do ‘ofendido’. No sábado em Singapura, excepcionalmente, isso não aconteceu. A ausência da AlphaTauri provavelmente teve a ver com a não recepção de uma conovocação da FIA para comparecer à audiência com os comissários. Mas de qualquer forma, chamou a atenção de todos a maneira no mínimo curiosa como Verstappen não foi penalizado pelas infrações que cometeu.
Eu não sei porque é que o Brundle ainda se surpreende, desde que o holandês se estreou na F1 que as penalizações lhe passam ao lado, e quando ele leva uma penalização significa que deveria era ser banido com uma corrida de suspensão...
Estado
