carro do serie de tv..
Versao de 1982:
http://www.carfolio.com/specifications/models/car/?car=99220&Pontiac
Bore/Stroke ratio 1.07
Displacement 5013 cc
(305.912 cu in)
Unitary capacity 626.63 cc/cylinder
Compression ratio 8.60:1
Fuel system 1 Ro E4MC carb
Aspiration Normal
Compressor type N/A
Intercooler None
Catalytic Converter Y
Max. output
(SAEnet) 152.1 PS (150.0 bhp) (111.9 kW)
@4200 rpm
Max. torque
(SAEnet) 324.0 Nm (239 lbft) (33 kgm)
@2200 rpm
Maximum rpm 4500 rpm
citação:Originalmente colocada por Fraga
citação:Originalmente colocada por carlos pinto
specs,alguem sabe?
depende... o gajo tinha lá um botão verde que "xunava" o carro todo e aquilo ficava tipo saxo cup na VDG [8)]
Este botão verde, maravilha.
specs,alguem sabe?
Do KITT da série televisiva? Aqui estão elas::D
* Power System - KITT is powered by the Knight Industries Turbojet with modified afterburners and a computer controlled 8-speed turbodrive transmission.
Specifications 0 to 60 mph in 2 seconds, Standing to quarter mile 4.286 seconds. Electromagnetic hyper-vacuum disc brakes: 14 foot braking distance (70 - 0 mph)
Some of KITT's features include the following:
(Lembrem-se o carro falava:D)
* Computer AI - KITT was essentially an advanced supercomputer on wheels. The "brain" of KITT was the Knight 2000 Microprocessor which is the center of a "self-aware" cybernetic logic module that allowed KITT to think, learn, communicate and interact with humans. Although KITT wasn't programmed to have feelings, he always had an ego that was easy to bruise and displayed a very sensitive personality. The system was programmed to drive the car better than a human operator could. He also has an in-dash entertainment system that can play music and video, and run various computer programs including arcade games which Michael sometimes indulged in whenever KITT was driving. The belief that KITT was truly sentient was never discussed in the show, however KITT was fully aware of himself and programmed to obey all orders given to him by his human creators, so long as they didn't violate his prime directive of protecting human life (especially Michael's) to the best of his abilities. KITT has, however been referred to as being "alive" in at least one episode. According to the episode Dead of Knight, KITT's reaction time is one nanosecond and his "memory" capacity is 1000 megabits. For the latter, it is uncertain whether or not active RAM or Hard Drive space was being discussed.
* Alpha Circuit - KITT's "Alpha Circuit" is mentioned quite a bit throughout the series, however its function was never clearly explained. It is most likely part of KITT's main control system which allows the CPU to drive the car. All that is really known is that the system is vulnerible to damage, (having been damaged when KITT towed a small hatchback in episode #3 "Deadly Maneuvers"), which hinders KITT's performance in several ways. When KARR was encountered a second time, the time he spent submerged in water damaged his Alpha Circuit which required KARR to have an operator to contol his Turbo Boost function. KARR crashed into the Knight Transport vehicle, in an attempt to find new "Alpha Capacitors" to fix the problem, but his driver stole KITT's experimental defensive laser system instead; a prize KARR felt was better than fixing his control systems.
* Molecular Bonded Shell - KITT is armored with "Tri-Helical Plasteel 1000 MBS" (Molecular Bonded Shell) plating which protects him from almost all forms of conventional firearms and explosive devices. He could only be harmed by heavy artillery and rockets, and even then, the blast usually left most of his shell intact and only damaged internal components. The shell protected every part of the car including the tires. KITT could even act as a shield for explosives by driving over bombs and suppressing the blast. The shell also protected him from fire and electricity, however it was vulnerable to some potent acids and at least one formula was made to completely neutralize the shell. It is also shown that long exposure to seawater can weaken the shell as in the case of KARR. The shell is actually a combination of three secret substances referred together as the "Knight Compound", developed by Wilton Knight who entrusted parts of the formula to three separate people. These individuals only know two pieces of the formula, ensuring that any two of them could make more of the Knight Compound in an emergency situation and that no one person would be able to make it. The shell provided a frame tolerance of 223,000 lb (111.5 tons) and a front and rear axle suspension load of 57,000 lb (28.5 tons).
* Pyroclastic Lamination - KITT is protected by a thermal-resistant coating that can withstand sustained temperatures of up to 800 degrees. First used in episode #32 Ring of Fire.
* Power System - KITT is powered by the Knight Industries Turbojet with modified afterburners and a computer controlled 8-speed turbodrive transmission. Specifications 0 to 60 mph in 2 seconds, Standing to quarter mile 4.286 seconds. Electromagnetic hyper-vacuum disc brakes: 14 foot braking distance (70 - 0 mph).
* Turbo Boost - Used at least once in every episode, a series of rear mounted undercarriage rocket motors allows KITT to accelerate to incredible speeds in excess of 200 mph. When activated in combination with the Trajectory Guidance System and a pair of rocket motors mounted just behind the front tires that lifted the front of the car, KITT could jump 40 feet into the air and pass over obstacles in the road. The system also allowed KITT added power whenever he had to maneuver heavy objects such as pushing a heavy boulder off a cliff, or pulling a large vehicle out of danger. The boosters could fire forward or backward.
* Voice Synthesizer - KITT's Voice Synthesizer allowed his logic module to speak and communicate. With it, KITT could also simulate other sounds, such as a police raid to fool criminals or a wild animal's growl, useful for scaring away a too-friendly animals intending to pee on his tires. KITT's primary spoken language was English, however by accessing his language module, he could speak fluently in Spanish and French. The module can be adjusted giving KITT different "accents" such as the fourth season episode "Out of the Woods", where KITT gets a "New York City" accent and called Michael, "Micky". During the first season, KITT's "mouth" in the interior of the vehicle was a flashing red square. In later seasons, this was changed to three sectioned vertical bars, as this design proved popular with fans as part of KARR.
* Anamorphic Equalizer - KITT's most apparent feature was his front scan bar called the Anamorphic Equalizer. The device is a fiber-optic array electronic eyes. The scanner could see in all visual wavelengths as well as X-Ray and infrared. When KITT's surveillance mode was active, the bar would light up and make an ominous swooping sound as it panned left and right. Occasionally, the bar could pulse in different patterns and sweep rapidly or very slowly. The scan bar is also KITT's most vulnerable area. In an attempt to stop KARR, Bonnie rigged a laser that could penetrate KARR's sensor and disable his electronics.
* Etymotic Equalizer - This system allowed KITT to hear sound. An array of audio sensors were threaded throughout his interior and exterior.
[:0]* Olfactory Sensor - KITT could "smell" via an atmospheric sampling device mounted in his front bumper.
* Microscanners - Microscanners are tiny audio and visual sensors embedded into the grooves of KITT's body. They allow for visual tracking and display of anything around the car.
* Cruise Modes - These are KITT's three drive modes:
o Normal Cruise - On "Normal", Michael had control of the car. In an emergency, KITT could still take over and activate Auto Cruise mode. In order to prevent this, one has to use the Manual Override. In the show's fourth season, the word "Cruise" was dropped and indicated simply by the word "Normal".
o Auto Cruise - In "Auto", KITT could drive himself utilizing an advanced Auto Collision Avoidance system.
o Pursuit - "Pursuit" is used during high-speed driving and is a combination of manual and computer assisted operation. KITT could respond to road conditions faster than Michael's reflexes could however Michael was technically in control of the vehicle and KITT helped guide certain maneuvers.
* Computer Override - KITT has a hidden switch and setting dial under the dash that either completely shuts down his AI module or deactivates certain systems should the need arise. First used in episode #17 "Chariot of Gold".
* Manual Override - KITT has a function which can be activated in order to completely lock the AI from all the vehicle controls. Unlike the Computer Override, Manual Override simply keeps KITT from activating Auto Cruse or preventing anyone inside the car from doing something that would probably hurt them. KITT's AI is still able to protest such actions vocally. First used in episode #8 "Trust Doesn't Rust".
* Police Lights/Siren - KITT's headlights can flash red and blue as police lights, and he has a siren. First used in episode #38 "Race for Life".
* Silent Mode - KITT could run silently. The feature dampened his engine noise and allow him to sneak around. First used in episode #37 "White-Line Warriors".
* Grappling Hook and Winch - KITT has a hidden winch and grappling hook system, one mounted under his front bumper, and another in a compartment behind his tail light plate. Most often the hook is connected by a strong cable, but a metal arm has also been seen. The grappling hook is first used in episode #6 "Not a Drop to Drink", the winch is first used in episode #13 "Forget Me Not".
* Parachute - KITT is equipped with a parachute. First used in episode #23 "Goliath Returns (Pt. 1)".
* Oil Jets/Smoke Screen - KITT could spray an oil slick and a plume of smoke from under the rear bumper. First used in episode #1 "Knight of the Phoenix".
* Flame Thrower - KITT has flame throwers mounted under his bumpers. First used in episode #2 "Deadly Maneuvers".
* Tear Gas Launcher - KITT can dispense a cloud of tear gas along with his smoke screen. First used in episode #13 "Hearts of Stone".
* Ultramagnesium Charges - KITT can launch magnesium flares, which can also be used to divert heat-seeking missiles fired at him. First used in episode #26 "Merchants of Death".
* High Traction Drop Downs - When activated the HTDD system hydraulically raises KITT's chassis for better traction when driving off-road. First used in episode #39 "Speed Demons".
* Traction Spikes - When activated KITT's tires would have spikes coming out in order for KITT to drive up steep off-road hills. First used in episode #86 "Hills of Fire".
* Telephone Comlink - Michael could contact home base and communicate with Devon over KITT's video display.
* Microwave Jammer - KITT has an electronic jamming system that played havoc on electrical systems. The three main components are the Electromagnetic Field Generator, Electronic Field Disrupter and Microwave Ignition Sensor. The system could take control of electronic machines, allowing things like cheating at slot machines, breaking electronic locks, fouling security cameras, and withdrawing money from ATMs. The most common usage was to knock out the electronics systems of a fleeing vehicle where he could disable the engine and activate the brakes. In some episodes, KITT is even capable of using it to magnetize and manipulate non-electronic objects such as a mechanical combination lock and create "poltergeist" activity, moving random objects to frighten people. First used in episode #9 "Inside Out".
* Surveillance Mode - Surveillance Mode did several things; KITT could detect people and vehicles and track their movements and discern proximity. He could gather structural schematics of buildings, vehicles, or other devices and help Michael avoid potential danger when he was snooping around. KITT could also use it to monitor radio transmissions and telephone communications within a location and trace those calls. He could tap into computer systems to monitor, or upload and download information as long as he could break the access codes.
* Infrared Tracking Scope - KITT could monitor the position of specific vehicles in the area within 10 miles. For instance, if Michael wanted to know the location of every police vehicle within 5 miles, KITT could display a schematic on his monitors of all police vehicles relative to his position.
* Laser Powerpack - KITT can fire a high powered ultra-frequency modulated laser capable of burning through steel plating. Like most of KITT's components, the schematics for the laser device are classified. First used in episode #24 "Goliath (Pt.2)".
* Bomb Sniffer - KITT is equipped with a bomb sniffer module that can detect explosives within a few yards of the vehicle. First used in episode #25 "Brother's Keeper".
* ECG - KITT has an electrocardiographic medical scanner that could monitor and display the vital signs of individuals on his monitors. It could indicate such conditions as if they were injured, poisoned, undergoing stress or other emotional behavior. KITT could even monitor Michael's physical activity through sensors inside the driver seat. First used in episode #2 "Knight of the Phoenix (Pt.2)".
* Deflatable Tires - KITT could deflate and reinflate his tires. First used in episode #4 "Slammin' Sammy's Stunt Show Spectacular".
* Fuel Processor - KITT was powered by a turbine engine primarily fueled by hydrogen gas, however, his complex fuel processor allows him to run on any combustible liquid, even regular gasoline. KITT's actual fuel requirements and efficiency ratings were classified, however in one episode, KITT mentioned his fuel economy was at least 100 miles per gallon. However, when operating on fuels other than liquid hydrogen, KITT's fuel efficiency and power output may be lowered.
* Self-Tinting Windows - KITT's windows could darken to opacity for various situations. First used in episode #14 "Give Me Liberty... or Give Me Death".
* Voice Stress Analyzer - KITT can process spoken voices and determine if someone may be lying. First used in episode #26 "Merchants of Death".
* Auto Doors, Sunroof, and Trunklid - KITT could automatically open and close his doors. He could also lock his doors to prevent unauthorized entry into his driver compartment. He could also open his hood automatically.
* Rotating License Plate - KITT can rotate his KNIGHT licence plate to reveal a fictitious one reading "KNI 667". Michael used this to evade police when an APB was placed on him. First used in episode #25 "Brother's Keeper".
* Seat Ejection System - KITT had two front ejection seats, mostly used when Michael needed a boost to fire escapes or building roof tops. First used in episode #1 "Knight of the Phoenix (Pt. 1)".
* Passive Laser Restraint System - Added to KITT in later seasons, the restraint system helped protect Michael and any passengers from the shock of sudden impacts and hard stopping, especially after Super-Pursuit Mode. It is speculated that this is a primitive form of inertial dampening device. First used in episode #47 "Knight of the Drones".
* Video Display Monitors - KITT had two CRT video display monitors on his dash for various readouts. They are controlled by two systems, the Graphic Translator (which sketches likenesses from verbal input) and the Anamorphic Equalizer (which gathered visual information from KITT's front scan bar) and microscanners. KITT only had one when his dash was redesigned for third season.
* Computer Print Out - KITT could print hard copies of data on a dashboard mounted printer. First used in episode #15 "The Topaz Connection".
* Ultraphonic Chemical Analyzer - KITT has a retractable tray with an electron scanner that could analyze the chemical properties of various materials. It could even scan finger prints and read ballistic information off bullets and compare these with a police database. Aside from the scanning tray, the system could also analyze chemical information gathered from KITT exterior sensors. First used in episode #17 "Chariot of Gold".
* Fire Extinguisher - KITT could put out small fires from a CO2 sprayer in his bumpers.
* Interior Oxygenator - KITT could release oxygen into his driver compartment and provide air to passengers if he was ever submerged in water or buried in earth. This is also used to overcome the effects of certain drugs. First used in episode #4 "Slammin' Sammy's Stunt Show Spectacular"
* Two-Wheel Ski Drive - The Ski Mode setting allowed KITT to "ski" (driving up on two wheels). First used in episode #1 "Knight of the Phoenix".
* Aquatic Synthesizer - With this system, KITT can hydroplane and drive on water, using his wheels and turbo system for propulsion. First used in episode #28 "Return to Cadiz".
* Sub Zero - KITT could release cryogenic gases and "flash freeze" the driver compartment. This was used once when a baby tiger managed to get inside to gnaw on his steering wheel and KITT wanted him out. First used in episode #66 "Knight in Retreat".
* Sleep Gas - KITT could spray a gas into the driver compartment that could knock an unwanted occupant out cold.
* Vacuum - KITT could expend all breathable air from the driver compartment, however, only KARR ever used it to harm someone. KITT used this to rid the compartment of smoke after bombs were disposed of in his trunk.
* Super-Pursuit Mode - KITT's Super-Pursuit mode was added fourth season. The system was a redesign of his rocket motors that allowed him incredible speeds of up to 300 mph (500 km/h) and boost speed by 40%. Fins extended from his body for better aerodynamics. First used in episode #70 "Knight of the Juggernaut".
* Emergency Braking System - The EBS slowed KITT down from Super-Pursuit speeds. It consisted of a forward breaking booster and air panels that popped out to create air friction. First used in episode #70 "Knight of the Juggernaut".
* Convertible Roof - Added fourth season, by pressing the "C" button on KITT's dash, Michael could bring the top down and KITT became a convertible. First used in episode #70 "Knight of the Juggernaut".
* Comlink - KITT is in constant contact with Michael via a two-way Casio communication wrist watch Michael wore. The watch also had a micro camera and scanner that KITT could access to gather information.
* Homing Device - In dire emergency, Michael can activate a secret homing beacon hidden inside a gold pendant he wears around his neck. The beacon sends a priority signal that can remotely activate KITT and override his programming so that he rushes to Michael's aid. First used episode #42 A Good Knight's Work.
* Knight Industries Mobile Unit - KITT has access to a mobile "garage", sometimes referred outside the show as "The Rook", which was a semi tractor and trailer owned by the Foundation. The mobile unit usually roamed somewhere near Michael's location. The trailer has an extendible ramp that dropped down and allows KITT to drive inside even with the truck is in motion. The trailer was loaded with spare parts and equipment for KITT. It also had a computer lab where either Bonnie or April would work and conduct repairs and maintenance. At the front of the trailer is a small office area. During early episodes, the trailer was plain white. In later episodes, it was painted black with a gold stripe and a gold Knight chess piece emblem.
* Total production cost: $11,400,000 estimated in 1982. (This was KITT's total construction cost as he was first built in 1982. The cost of subsequent equipment improvements and the installation of additional features since his activation have not been factored.)
O carro quando andava sózinho, via-se logo que estava alguem por detrás do banco(alterado) do conductor, o mesmo era mais largo nestas cenas, para além de que por vezes via.se o braço da pessoa que estava escondida com a mão no volante. :D
citação:Originalmente colocada por WH
specs,alguem sabe?
Isso é o que chamo FULL-EXTRAS...
citação:Originalmente colocada por _robie_
E o volante era redondo! :D
Isso era o carro k simulada uma pessoa. Não sei se sabem mas é o KIT:D
Hummm, nem sempre!
Naquele tempo o David Hassholf...qualquer coisa n aparecia bebado e mijado no aeroporto....
Essa série era o deleite de qualquer um na altura!!!
Podem confirmar isso em video aqui
citação:Originalmente colocada por Stormskaer
LOOOOOOOOOOOOOOOL! Eu quero já um daqueles.[}:)][}:)]
