Pois é: 272Hp, 518Nm às 1500RPM...
These made their debut in the Lancer Evolution MIEV announced in August. This new version of the motor uses a hollow doughnut construction that locates the rotor outside the stator as opposed to a common electric motor where the rotor turns inside the stator [see graphic a bit below]. The Lancer used four motors, one in each wheel, to deliver 4WD capability. Each motor, manufactured by Toyo Denki Seizo K.K., produces a maximum output of 50 kW with 518 Nm of torque. A 355V lithium-ion battery system comprising 24 modules fits under the floor between the front and rear wheels to provide power. The Lancer Evolution MIEV has a top speed of 180 km/h (112 mph) and a cruising range of 250 km (155 miles) [Note the improvement over the Colt released just a few months earlier].
