Bolsa - Acções da Pirelli
111
Para os entendidos nesta matéria, alguém me pode explicar como é possível a acção da Pirelli valer até há alguns dias atrás cerca de €0.50, valor que mantinha desde sensivelmente 2003, e no espaço de 2/3 dias passar a valer cerca de €5,40 com valorizações na ordem dos 1000%-1200%?
Deu-se algum acontecimento que gerasse esta valorização ou estarei eu a interpretar mal os dados?
Cours PIRELLI & C. | Action PIRELLI & C. | PC | Boursorama
deve ter a ver com isto
As of 26 July 2010, subject to the prior cancellation of 1 ordinary share and 8 savings shares held by Pirelli & C. S.p.A. (Pirelli & C). to fully balance the transaction, with a corresponding reduction of the share capital from Euro 1,556,692,865.28 to Euro 1,556,692,862.67, the following transactions will be carried out:
(i) reverse stock split of n. 5,233,142,002 ordinary shares, with no par value, in a ratio of 1 new ordinary share, with no par value, regular entitlement, coupon n. 1 (ISIN code IT0004623051) for every 11 ordinary shares, with no par value, coupon n. 15 (ISIN code IT0000072725) held;
(ii) reverse stock split of n. 134,764,421 outstanding savings shares, with no par value, in accordance with the following ratios: (a) n. 1 new bearer savings share, with no par value, regular entitlement, n. 1 coupon (ISIN code IT0004623333) for every 11 bearer savings shares, with no par value, coupon n. 15 (ISIN code IT0000072733) held; and (b) n. 1 new registered savings share, with no par value, regular entitlement, coupon n. 1 (ISIN code IT0004623341) for every 11 registered savings shares, with no par value, coupon n. 15 (ISIN code IT0000072741) held.
Accordingly, the share capital of Pirelli & C. will be equal to Euro 1,556,692,862.67, divided into n. 487,991,493 shares with no par value, of which n. 475,740,182 (Euro 1,517,611,180.58) ordinary shares and n. 12,251,311 (Euro 39,081,682.09) savings shares, as evidenced by the filing with the Companies’ Register dated as of 21 July 2010."
Pirelli Reverse Stock Split to Start July 26
Pirelli & C. SpA announced a reverse stock split whereby 11 shares will be consolidated into one new share
Fonte
Consolidaram 11 acções em 1, ou seja, se tinhas 11 acções a 0,50 € passas a ficar apenas com 1 acção a 5,50 € (11 x 0,50 €). [;)]
