Qual a melhor marca de LCD's ?
  • Total de eleitores
    56
  • Sondagem encerrada .
LCD SONY sem duvida os melhores, em termos da construçao de materiais de qualidade, beleza e tecnologia sempre mais á frente das outras marcas...
Samsung to show off thinnest full HD 40-inch LCD TV around in Yokohama this week
Thin is certainly in when it comes to HDTV sets and computer displays. What is typically considered thin for a LCD or plasma HDTV is somewhere in the area of 5-inches to 6-inches thick currently. Some HDTVs are even thicker than that.
Samsung announced that it will have a new thin-film-transistor (TFT), LCD on display at FPD International 2007 in Yokohama, Japan this week. The new LCD panel has the thinnest profile ever for a full-size HDTV. The 40-inch diagonal Full HD LCD TV panel is a mere 10mm thick.
That is about the thickness of a typical 10-inch to 20-inch computer LCD display, which is significantly thinner than normal HDTV sets. The bezel of the panel has also been reduced from 30mm to 14.6mm. The screen is backlit using LEDs and can reproduce 92% of the NTSC standard for color saturation. Power consumption is reported to be 90 watts or less.
With a profile of only 10mm, Samsung can give the svelte dimensions of the recently announced Sony XEL-1 OLED TV a run for its money. The majority of home theater lovers would be willing to add 7mm to the 3mm profile of the Sony XEL-1 to gain nearly 30-inches in screen size.
http://www.dailytech.com/article.aspx?newsid=9357
uma teoria minha e que nos andamos a 20 anos a habituar a vista aos crts a cores , como o plasma e mais aproximado em termos de imagem ao crt , "preferimos" o plasma !!!
temos +e de ter noçao que eventualmente em certos pormenores o lcd ( nem todos) poderam ser melhores que os plasmas ( media center , contornos , brancos , etc )
mt dificilmente comparando gamas iguais irei trocar o lcd pelo plasma
e so a minha opiniao
a tua e a de muita gente.
eu também tenho um LCD.
mas não deixam de ser resultados muito interessantes os do estudo.
às 'cegas' grande parte preferiu os plasmas:)
é engraçado porque vai contra o censo comum.
ld
Não li todos os post até chegar aqui, mas...
...e que tal esqueceres a ideia do LCD e pensares num plasma ?
LCD para imagens estáticas (tipo PC) é excelente, mas para imagem em movimento ainda está muito atrás do plasma (embora tenham sido feitos grandes melhoramentos ao longo do tempo).
O LCD numa loja chama mais atenção porque tem mais brilho (diferente de contraste), mas em qualidade absoluta...
Se insistires no LCD, tens a Samsung com barato, bonito mas com pouca qualidade.
Tens a LG que não é melhor...
Tens a Sony que já teve os seus tempos na imagem, mas hoje coitados...
Tens porreiros os Panasonic (que são concebidos e fabricados pela própria panasonic)
Tens os Philips, também muito bons.
Tens os Hitachi, que são interessantes mas que acabam por estar fora de preço.
Em plasma não mudaria muito estas opiniões, com excepção de acrescentar aqueles que talvez sejam os melhores plasmas do mercado - Pioneer.
Não sei onde estão vendo os da Samsung com baixa qualidade, bota as especificações do modelo em questão. Geralmente é o contrário, pelo preço oferece muito mais
Sou apaixonado pela Samsung desde o Syncmaster3 [:)]Esse tinha um defeito nuns lotes, mas o meu durou quase 10 anos com uso constante, sendo que a média de vida dos monitores era algo como 5 ou 6 anos
Não sei se estás a brincar ou a falar a sério. Mas as CRT Worten são mesmo modelos Philips. Isto é verdade. A única coida da Worten é o logotipo.
Isso acontece apenas em alguns modelos!
Mas, lá por ter o CRT Philips, não quer dizer nada............. afinal a Philips é o maior fabricante mundial..........
Normalmente essas tv's (Worten, AG, etc), são Vestel (Turquia)!
Já reparei muitos tv's Worten e nunca vi nenhum que fosse Philips!
Ai é?!:sh)
Ainda gostava de sabe em quê?!
A 1º serie das Bravia, foi uma vergonha! Estas mais recentes até escapam.......
Quanto à tecnologia, é (como practicamente para todos os outros fabricantes), fornecida pela Philips!
Não vejo nada à frente da concorrencia, antes pelo contrario............
das marcas mais comercializadas a ordem que estabeleceria para LCD's de baixo e medio custo seria (por ordem crescente de qualidade):
- Grundig e Sanyo
- Samsung
- LG
- Philips
- Sony
- Sharp e Toshiba
- Panasonic
a samsung até à bem pco tempo fabricava alguns lcd's para a sony. lol
A philips tem uns modelos muito bons, sem duvida... mas preço por preço, penso que na maioria dos casos a samsung consegue oferecer melhores características.
Eu dava uma vista de olhos na nova gama da Grundig. O meu pai trabalha directamente com todas estas marcas e diz que há uns modelos da Grundig que são excelentes.
Sim, a Samsung fabrica alguns LCD's para a Sony (e para outras marcas); afinal só há prai meia-duzia de fabricantes de LCD's!
Mas isso não significa nada; a tv não é so ecrã!
Basta ver que, os 1º Bravia eram um nojo e tinham LCD's Samsung e os LCD's Samsung ganhavam premios com esse mesmos LCD's......
A Philips, tem "fases": tanto tem produtos à frente da concorrencia, como fica para trás! Isto explica-se pelo facto da Philips "viver" do desenvolvimento e venda de tecnologia às outras marcas, pelo que às vezes deixa a sua propria marca para trás......... Uma coisa é certa: todos os LCD's que ganham algum premio (EISA, etc), tem lá dentro algo da Philips!!!
A Grundig não é do mesmo campeonato!
Aliás, nem são realmente Grundig, uma vez que a Grundig faliu em 2003!
O nome (marca) "Grundig" foi comprado pela Beko (Turquia) e é esta que fabrica esses LCD's com a marca Grundig!
Estão longe do topo!
Já agora (visto que alguns falaram das Grundig antigas), fiquem a saber que a Grundig NUNCA fez CRT's; usava CRT's Philips ou VidioColor (Italia)![;)]
a antiga grundig, depois de adquirida acho q passou a chamar-se LG ;)
como tinha referido anteriormente....relaçao preço/qualidade sem duvidas a samsung....
tb gosto muitooo dos sharp's....mas sao normalemnte mais caros~
ve aqui os preços
www.pixmania.com
www.rebelio.pt
cumps
Eh lá!!!:sh)
Donde é que veio essa "estória"?!
A LG é "descendente" da antiga Goldstar!
LG - Lucky Goldstar!!!
A Grundig não existe!
O que aconteceu foi que a Beko comprou a marca Grundig e agora fabrica tv's, LCD's, etc com a marca Grundig!!!
Eh lá!!!:sh)
Eu já tinha dito isso; só um pequeno reparo, a Grundig foi comprada por uma joint-venture entre os ingleses da Alba e os turcos da Beko, em 2004.
Para além destas duas empresas, que fabrica os artigos que disseste; a Thomson ficou com a parte dos equipamentos de satélite; a Delphi, fabrica auto-rádios usando o nome Grundig; a Vitelcom de Espanha fabrica telemóveis com a marca Grundig; e uma empresa americana, cujo nome não me recorda, fabrica vários productos sob o nome Grundig, para comercialização no EUA.
Preço/qualidade, sem duvida Samsung ou Philips!
Só LCD's; dos plasmas quero distancia![;)]
A Sharp, Toshiba, Hitachi, etc, são daquelas marcas, que aparecem com um bom modelo, mas depois estagnam e não fazem nada de novo durante anos!
E tem um grande problema: assistência!
Para a Samsung ou Philips, arranjo peças na boa, agora para essas, nem ve-las.....
São marcas que eu NUNCA compraria!
Como referi, actualmente só compraria duas marcas: Samsung ou Philips!
