Imprimir email - erro
Omega
Membro histórico
O meu computador ultimamente anda um bocado passado da cabeça .....
Agora, sempre que tento impimir um mail aparece-me isto:
An error has occurred in the script on this page.
Line: 2021
Char: 1
Error: Unspecified error
Code: 0
URL: res://ieframe.dll/preview.dlg
Do you want to continue running this script?
YES/ NO
[8b]
O que é que faço ?!?
Fecha o Internet Explorer.
-> Iniciar / Start -> Executar / Run
E escreve: regsvr32 ole32.dll na caixa.
-> OK
E tenta imprimir.
Vê se não tens mais do que uma Firewall activada, por ex a do Windows e uma que tenhas instalado entretanto.
Edit: já está resolvido, ainda bem ;)
Que versão estás a utilizar do IE? Supostamente esse problema não deveria acontecer estando tudo actualizado.
Help -> About IE -> Version 7.0.????
Já agora, outro problema: Windows média player está sem som.
Ficou assim despois de eu instalar a versão 11 que entretanto já desinstalei....
Dá a seguinte mensagem:
Windows Media Player cannot play the file because there is a problem with your sound device. There may not be a sound device installed on your computer, it may be in use by another program, or it may not be functioning properly.
Errors 80040256/00040258 (No audio hardware is available, or the hardware is not responding) and C00D11BA (Cannot play the file because there is a problem with your sound device) along with most sound card related problems can be fixed just reinstalling the drivers for the sound card.
Windows Media Player uses DirectSound to interface with the sound card, so sound very well might work in other applications and just not Windows Media Player.
First Steps – Sound Card Problems.
* Reinstall your sound card drivers.
* Reinstall DirectX.
* Turn down Hardware Acceleration. To do this go to your Control Panel | Multimedia | Audio | Advanced Properties or Control Panel | Sound and Multimedia or Sound and Audio Devices | Audio | Sound Playback | Advanced. Move the slider down a bit.
* Make sure the correct output device is selected under Tools | Options | Devices | Speakers. Also try selecting a different output device if an additional itme is listed.
Note: It’s a good idea to reboot after most of these changes before you think they are not working.
Locating Drivers
If you need help locating where to get the latest drivers for your sound card try the following. Your Device Manager in Windows should supply the information assuming the sound card has been detected. To access the Device Manager right click on My Computer and select the Device Manager tab. In Windows XP go to the Hardware Tab and select Device Manager.
Que raio é isto agora ?!?
The message could not be sent because the server rejected the sender's e-mail address. The sender's e-mail address was '****@**.**. Subject '', Account: 'CarlosGmail', Server: 'smtp.gmail.com', Protocol: SMTP, Server Response: '530 5.5.1 Authentication Required 9sm3110395wrl', Port: 465, Secure(SSL): Yes, Server Error: 530, Error Number: 0x800CCC78
