Toda a gente já teve um PSA 1.4 D
citação:Originalmente colocada por REDLINER_
Se não me engano, o Serie K é 100% Rover...Muito embora, e verdade seja dita, recebou inspiração de engenharia Honda!
Não recebeu inspiração nenhuma da Honda e se não fosse a associação com a Austin-Rover provavelmente ainda hoje a Honda não saberia fazer suspensões decentes:
"Rover used the opportunity to also make some further reaching changes to the suspension set-up: Honda managers had originally stated flatly that this was their system and Rover did not need to tamper with it, but they had not figured on its sheer incompetence in its initial form.
What Rover found was not so much a problem with the ride quality – that was always going to be compromised by the fact that the suspension had limited travel, but what they – and road testers – found was, disconcertingly, the car would suffer from excessive pitching under acceleration and corkscrewing when cornering.
This basic flaw obviously resulted in inconsistent handling and the company did not want such a compromise present on their car – Honda derived or not. So, the chassis engineers went about trying to solve the problem, which they did fairly quickly.
It was found that there was a seventeen per cent difference in spring rate between the left and right rear wheels, which once eliminated by Austin Rover, left the Rover 200 with consistent and class-average ride and handling. Significantly, Honda also took up these modifications in their Ballade model – and not just those built Longbridge."
http://www.austin-rover.co.uk/index.htm?sd3storyf.htm
citação:paulinhuu Posted - 22/07/2006 : 01:39:04
Não sei se já repararam mas aqui no fórum, toda a minha gente já teve um AX 1.4D.. ou um 106 1.4D...
Nunca tive nenhum, nunca andei em nenhum, a minha família directa também não e sinceramente pelo que andei a averiguar verifico que também nenhum dos meus amigos mais próximos teve um automóvel com esse motor.
Posto isto não faço comentários. E penso que muitas pessoas (isto não é para ninguém em especial) também deveriam abster-se de fazer comentários baseados no "ouvir dizer".
citação:Originalmente colocada por silversurfer
Exactamente, e foi por isso é que criei o tópico.. é pena que nem todas as pessoas percebam isso..
citação:Originalmente colocada por CL
As vezes é com cada exagero[}:)][}:)][}:)]
"Se não fosse a Rover, a Honda não sabia fazer suspensões"[}:)]
Está bem abelha[}:)][}:)]
Teoria da conspiração[8)]
PS:Ainda por cima, o site fonte, é cá de uma isenção...
citação:Originalmente colocada por JCR
O dono nem está a pensar vender o carro, ninguém lhe dá nada por ele, vai para abate mais dia menos dia.
Eu fico com ele...
Antes um AX que um enfandonho Toyota... Eu ainda gosto do sentido de aventura e sempre posso dar uso ao meu cartão do ACP...
citação:Originalmente colocada por DêCêIi
Mas será que se resume tudo logo a ataques?[xx(] Fica lá com o prémio, ganhaste[8)]
Este forum vai de mal a pior mesmo...
Mas qual ataque [?]
Para mim Toyota é sinal de carro aborrecido e depois [?] Não dá problemas mas a mim dificilmente daria alegrias...
O Toyota aborrecido..............lol!!!!!!!!
pelo teu avatar...um Renault não aborrece!!!lol!!!!!
Venha dai um Twingo , a fonte de felicidade!!!!!!!!!
Abaixo o Corolla, aborrece só de o Ver!!!!!!!!!!!!
Cada um com a sua teoria!!!!!
Como digo: gostos não se discutem!!!
Isto agora até a Rover (essa marca cheia de euros para gastar em I&D) até ensina a Honda (aqueles pobres coitados que não percebem nada) como fazer suspensões.
Toyota até pode ser o melhor do mundo ((((:D)))) mas para mim são carros tristes, sem originalidade e sem personalidade estética, tanto de exterior como de interior. Quero lá saber dos híbridos..
Vá, venha lá comandantes japunas a fazer um quote ao JE e a dizer :
" Ah e tal mas e o C1 já tem personalidade estética" ?... vá venham lá contra-argumentar a dizer que os Citro's é que são feios....
tal como o Acura(avatar) disse : Gostos não se discutem...
Carros tristes:
MR2
AE86 (só para apreciadores não para apaixonados!)
Supra
Celica
Versoes T-Sport do Corolla e Yaris
O melhor Diesel preço/produto O Corolla 1.4 D4D
Hyace (grande carroço com tração traseira)
Hilux...
E já agora dá um salto aos sites japunas e ve lá os Toyotas "aborrecidos" que não poe aqui os pés...
