WorldTracker SMS: The next Generation of Live GPS Tracking Devices
Reliable, Accurate, and Affordable.
WorldTracker SMS is a completely self-contained GPS Tracking device small enough to fit in the palm of your hand. When placed with vehicles, packages or people, the WorldTracker SMS provides a whole new level of security and peace of mind. By utilizing the global GSM/SMS text messaging network, the Tri-Band WorldTracker SMS provides global real-time tracking capabilities.
The First GPS Tracking Solution to offer Unlimited Service.
With TrackingTheWorld.com's unlimited service plan ($59.95 per month) you can use your WorldTracker SMS 24/7 and never worry about service charges. Unlimited service allows your WorldTracker SMS to report as frequently as possible, providing you with the highest quality and most accurate tracking data.
Extended Life "Hibernator" Battery Case
Up to one full month of unattended automatic, historical, and "on demand" GPS real time tracking now possible with our waterproof, motion activated, magnetic mount "hibernator" case. At only 6 1/2 x 4 x 1 3/4 inches, the unit operates on 8 "AA" standard alkaline batteries. Battery life can be maximized by using lithium batteries. After 5 minutes of inactivity, case automatically shuts down, saving battery power and cellular costs until the vehicle begins moving again.
Featuring the SiRF Star III GPS Chipset.
What is the SiRF Star III, and why is it so important? Well, the SiRF Star III chipset is a pretty big innovation in the GPS world, as it has dramatically better performance obtaining a GPS satellite lock and getting you a location, fast. The WorldTracker SMS with SiRF Star III technology provides faster fix times, better sensitivity, and longer battery life than any other GPS Tracking System.
Faster Fix Times, Pinpoint Accuracy
When turned on, the WorldTracker SMS needs to figure out where it is by connecting the GPS satellites and triangulating an exact location to within 3 meters.
WorldTracker SMS Acquisition Times:
- Hot Typically < 6sec Time To First Fix (TTFF)
- Warm Typically < 35sec TTFF
- Cold Typically < 45sec TTFF
High Sensitivity, Unmatched Dependability
The SiRF star III chipset is better at holding a signal in low signal areas such as traveling in a downtown area where there are a lot of sky scrapers or under dense tree cover. The chipset can track signals down to -159 dBm, and has 200,000 correlators, and most other chipsets have only a few thousand.
Longer Battery Life
The SiRF star III chipset is also very efficient, which means low power draw and longer battery life. Using an external battery case, you can extended the life of the WorldTracker SMS by as much as 30 days.
Industry Leading GPS Tracking and Mapping Software.
Users can view and print out reports containing street addresses, set reporting options, create geo-fences, and much more. Using the latest technology available from Google and Microsoft, our mapping goes down to street level, you can see cars, buses and the exact physical location where your vehicle is. Users can instantly switch to a variety of mapping.
- Microsoft Virtual Earth
- NEW Birds Eye View
- Ariel Satellite View
- Standard Map View
- Google Mapping Technology
- Google Earth featuring 3D animation and driving report playback.
- Standard Map View
- Satellite Photography View
- Hybrid Map/Satellite View
Monitor Your WorldTracker's Location on your Cell Phone.
TrackingTheWorld.com's latest service enables users to monitor their trackers location update using any Mobile Internet enabled Cell Phone. The phone displays a full graphical map with the trackers current location highlighted. These maps are fully zoomable and you can go right down to street level. The phone will also provide the nearest physically address.
- Absolutely no computer required
- No cell phone software installation required
- Compatible with all cellular providers including Cingular, Verizon, T-mobile, Sprint and more.
- Displays the nearest street address and highlights that location on a street level map (Zoomable)
- Real time tracking updates every 60 seconds
For a live demo, simply enter the following address into your phones mobile web browser:
http://www.trackingtheworld.com/demo.pl?id=demo
TrackingTheWorld.com System Architecture
WorldTracker SMS Hardware Features
- Self contained device fits in the palm of your hand. No external antennae needed, just plug-&-play.
- Durable, lightweight, water-resistant housing.
- Geofence feature sends alert if the target moves from pre-defined area.
- Parking and Anti-theft Function, notifies you if vehicle moves from parked location. GPS assist function using GSM network, boosting location sensitivity when GPS signal is temporarily lost.
- Enhanced sensitivity for indoor and outdoor reporting.
- Tri-band GSM 900/1800/1900 MHz for worldwide coverage.
- 12 volt DC adapter connects to vehicle power.
- Can be hooked up to 12 volt DC for permanent hardwire connection.
- Can be accessed and programmed via SMS messages sent from any cell phone.
- Emergency location alerts can be sent to multiple cell phone.
Technical Specifications
- Tri Band GSM module (GSM850/1800/1900 MHz or GSM900/1800/1900 MHz)
- Equipped with 16 parallel channels GPS receiver
- Emergency Alert: Panic Button
- Acquisition time:
- Positioning Accuracy: Less than 15 meters, SEP without SA
- Power Supply:
- 12V DC Cigarette Lighter / 3.6V DC Li-Ion battery
- Internal GSM antenna
- Internal active GPS antenna
- Operation time:
- Battery 24 hours after fully charged in standby mode
- With Backup Battery Package: up to 4 days
- Device Size: 45(W) x 66(L) x 25(H) mm
- Weight: 87g
- Operating Temperature: -30°C to + 70°C
- Storage Temperature: -40°C to + 85°C
- Relative Humidity: 5% to 95%, non-condensing
