911 enxovalha o todo poderoso M5
O problema é que o xantia nem sequer objecto de caracterização de "pseudo" pode ser, pois para poder ser "alguma coisa que não é" tem de ter no minimo pretensões a tal. Eu não vejo nenhuma pretensão desportiva no xantia, mas repito o eu ...vá "se calhar" não sou só eu.
Hydractive Suspension
Citroen's hydractive suspension was first introduced on the XM and is a refinement of Citroen's justly famous oleopneumatic suspension first seen on the Traction Avant as long ago as 1952. It uses a central ECU to control the firmness of the suspension, cutting down roll and sharpening the reactions to the steering, while keeping the ride quality good.
At the heart of the system is a third sphere at each end of the car, in addition to the traditional wheel spheres. This is switched in and out of circuit by the computer as required - Citroen claimed in 0.05 of a second. The effect of switching the extra spheres out of circuit is to firm up the suspension considerably, as the springing is handled by only 2/3 of the gas volume. This gives the system two different modes: normal (soft) and sport (firm). The basic suspension set up can therefore be made quite soft and comfortable for normal driving, with the computer automatically switching to firm mode and back when conditions require, giving owners the best of both worlds: a wonderful ride and superb handling.
The microprocessor based control system has inputs from five different sensors:
1. gives information on the angle and rotational speed of the steering wheel
2. monitors the speed of movement of the accelerator pedal
3. assesses braking effort
4. measures body movement
5. measures vehicle speed
These help the computer to determine the overall sensitivity of the system.
In addition to the height lever present on all hydraulically suspended Citroens, Hydractive cars posess a mode switch. This enables the driver to select the normal mode, or a firmer program - 'Sport'. With the original Hydractive (retrospectively called Hydractive 1), selecting 'sport' simply removed the centre spheres from the hydraulic circuit permanently. This was fine for twisty roads and/or enthusiastic driving, but if there was a problem (and early XMs had more than their fair share of problems), the car defaulted to 'sport' mode which most drivers found too hard for normal driving conditions. However, Hydractive 2 - fitted to later s1 XMs, all s2 XMs, and Xantia VSX and Exclusive specifications - the parameters were changed. Setting the switch to 'sport' keeps the car in normal mode, but makes to the car react and switch to the firmer settings earlier and stay there for a bit longer before softening up again. This can easily be identified within the car, as the switch is labelled 'Sport'/'Norm' rather than the 'Sport'/'Auto' of Hydractive 1.
The Xantia brought a further advance, Activa. Based around Hydractive 2, but with body position sensors detecting the amount of roll, a higher volume hydraulic pump fed fluid to variable length links between each suspension arm and the anti-roll bars. This allowed the Activa to maintain a totally flat attitude, even in very hard cornering. As this ensured the tyres were always flat to the tarmac, the cornering capabilities of the car went up dramatically. However, the Activa's ride suffered badly, and the body position sensors often disagreed, causing the Activa to perform a little 'dance' while stationary at traffic lights...
At the time of writing, prior to the launch of the C6, the current iteration of Hydractive - Hydractive 3 - is fitted to the C5 and brings a new feature - automatically variable ride height. At speed, the car automatically lowers itself to increase stability. However, Hydractive 3 on most C5s does not offer the 'Sport' mode of Hydractive 1 and 2 - this is reserved for Hydractive 3+ on the upper models.
When it is released, the C6 will not feature a rumoured "Hydractive 4", but will initially use the Hydractive 3+ of the top-spec C5. Hydractive 4 will, when it arrives, probably offer "dynamic levelling". Each wheel will have a separate height corrector and a pair of spheres, with each wheel able to be independently switched between a firm and a soft setting. Separate height correctors will help to ensure that body roll is kept to an absolute minimum - in effect, dynamic levelling, preventing pitch, yaw and roll.
Pronto, agora já tem pretensão vá![:D]
Eu gosto muito destes temas onde se invoca a condição máscula para se poder conduzir.
Como aquele que dizia: Homem que é homem não come mel. Mastiga as abelhas. [:D]
Deixem-se disso. Cada vez mais se fazem carros como deve ser. É para isso que serve a inovação tecnológica e o engenho humano.
Faz-me lembrar a malta dos Porsches, que o 993 foi o último verdadeiro Porsche e coisa e tal. Andem num 996 e depois venham cá dizer do resto. Para não falar do 997..., mas esse aí ainda não lhe pus as unhas em cima.
Porque se isso fosse verdade, andava por aí muito pessoal de GT3 na rua.
De 911T e com cx. automática ([:vm)] ...)
[:D] [:D] oh carlos deixa-te de coisas mas é........
já não se fazem muitos carros á homem!
o s2000 , o evo , scooby, CTR ainda se mantêm na linha............mas de resto pouco mais [:D] [:D]
ou então é preciso elevar a fasquia monetária demasiado acima!
Expliquem a um tipo como eu, que não seguiu o tópico todo, como estão já a falar do Xantia Activa?
Impressionante como a malta dispersa.
nem eu sei![:D]
ah já vi, foi o V7 que enviesou e começou a falar do Xantia, a dizer mal e tal! e ele disse " foi tu" e eu "foste tu" ...e por ai fora!
A falar mal do xantia ? eu ?
A seguir ao Porsche Carrera GT e na mesma onda é o meu carro preferido [:)] [:)] [:)]
[:D] [:D] [:D] [:D] .........o porche carrera é o lip da onda!mandas uma paulada....um 360º backflip, e depois atrasas e passas ao xantia (tubo)! cuidado é que o xantia não costuma dar muitas hipoteses a meninos.....o fundo é de coral.....aquilo rasga os mais tenrinhos![:D]
Ou como aquele que com duas facas na mão as espeta na mesa e diz come aqui este ku que é de homem [:D] [:D] [:)] [:)]
não conhecia essa expressão............
pois, mas com aqueles teus amigos que têm os carros á homem, aqueles que me querias dar os números.......lá deves conhecer bem expressões dessas mais underground![:D] [:D] [:D] [:D] [:D]
pmct; reafirmo o que escrevi, porque nao o escrevi de "cor" o Carrera S (modelo 996) que existe na familia, é um carro fabuloso, mas uma "besta" dificil de domar, o 911 T, nao sei, nunca lhe pus as maos em cima, mas tenho ouvido e lido que é brutal...
seclanahr pelo facto do T serem todo AWD andam mais sobre carris.
quando digo que é facil de conduzir quero dizer que a minha mae conduz uma coisas dessas na boa.
evidentemente se quiser domrar os 420 cavalos em curva nos limites, pois , é preciso respeitar os 420 cavalos, da mesma forma que os 507 do M6 são precisas unhas.
agora não e dificil de conduzir, não mais que qualquer outro carro RWD, ate pelo contrario, quem como eu acha que os RWD são mais faceis e naturais de conduzir, vai achar que o 996T anda sobre carris.
Concordo !
passa-se é tudo muito mais depressa. As decisões devem ser rápidas e não deve haver exitações.
