AF147
Bi-Compressor - 656cv!
[br
Specifications
Technical data:
Capacity: 4.308 ccm;
Achievement KW/PS: 482/656 with 8.200 rpm
Torque: 662NM with 6.100 rpm
Acceleration 0-100 km/h: 3.7 seconds.
Maximum speed: 348 km/h (in the case of changed transmission translation)
Engine:
NOVITEC Bi-compressor with two Rotrex compressors with separate oil circulation, water-cooled intercoolers, additional injection, changed ECU´s, achievement-optimized high-grade steel exhaust system with 90mm final pipes, changed transmission translation
Brakes:
NOVITEC Brembo brake assembly with 380mm metal brake disks in front and in the back, 6-Kolben-Bremszangen at the front axle and rear axle
Chassis:
KW high-grade steel - thread chassis sport (two-way adjustable), sport stabilizers,
Complete wheel set NF2 Race, front axle 9,0 x 19 tariff with 255/30R19
Pirelli P-Zero Rosso, rear axle 12,5 x 20 tariff with 345/25R20 with Pirelli P-Zero Rosso
Aerodynamics:
Front apron supersport, tail diffuser, tail wing supersport, Schwellerflügel
Other:
Carbon engine compartment lining, carbon engine compartment exhaust lattice, tail lamp set in black, side turn signals in black
Interior:
Complete leather equipment supersport in two-colored Alcantara with sport seats supersport performance, steering wheel supersport, aluminum pedal set with driver and front seat passenger footrest
Specifications
Technical data:
Engine:
Brakes:
Chassis:
Aerodynamics:
Other:
Interior:
