Something new to the internal combustion engine world is HCCI — Homogeneous Charge Compression Ignition, yet to be seen in any production vehicle by any manufacturer. A few car manufacturers have been experimenting with this, among them Honda who wants to introduce HCCI with it’s IMA Hybrid system.
What exactly is HCCI? Basically. Homogeneous Charge Compression Ignition ignites an air fuel mixture without any flame, plus a large area can be ignited simultaneously, much different from a conventional spark flame burn where the mixture burns first from the area around the initial spark and proceeds to the rest of the combustion chamber. This is somewhat similiar to a diesel engine’s self-ignition. Diesel self-ignition is called SCCI, or Stratified Charge Compression Ignition.
Engineers have predicted a potential 20 to 30% boost in engine efficiency over conventional gasoline combustion engines, and an improved thermal efficiency of about 40% to 50%. Honda calls it’s HCCI technology Activated Radical Combustion, and have been experimenting with two-stroke motorcycle engines. A 4-cylinder HCCI engine for cars is also in development, though currently progress has enabled HCCI on the lower RPM ranges of about 0 to 4,000rpm only. However, during normal non-spirited driving the rev rarely goes above 4,000rpm anyway.
A key problem is how to measure ignition timing accurately. This is not a problem in diesel self-ignition, as hot air is compressed and ignition starts when fuel is injected into the combustion chamber filled with the hot air. In a HCCI gasoline engine, the air-fuel mix is already in the combustion chamber before the piston starts compressing it. According to Lawrence Livermore Laboratory, some ways to ovecome this would be to recirculate exhaust gases into the fuel/air mix to quickly raise its temperature, or to add dimethyl ether to the fuel/air mixture to improve combustion.
Another idea would be to compress the air-fuel mixture to the point where it is just about to ignite, then injecting a second dosage of low octane fuel that combusts easily. That fuel would detonate, increasing temperature and detonating the rest of the air fuel mixture. The ignition timing could start from whenever the engine injects that second dosage of fuel.
Like most auto engines, HCCI engines inject a premixed charge of fuel and air into the cylinder. But combustion is not set off by a spark plug. Instead, the mixture is compressed until it autoignites, much like in a diesel at a much lower temperature. This virtually eliminates NOx emissions and lowers throttling losses, which could lead to a 30% boost in fuel economy. HCCI engines would also use a higher ratio of air to fuel, high compression ratios (on the order of 12:1), and burn a variety of fuels, including methane.
