GJP
...(ou não) preço no fim
5.7-liter DOHC EFI V8, 32-valve aluminum block with aluminum alloy head with Dual VVT-i
381 hp @ 5600 rpm
401 lb.-ft. @ 3600 rpm
Bore and stroke: 3.70 x 4.02
Compression ratio: 10.2:1
Displacement: 5663 cc
Ignition system: DIS (Direct)
Emissions: ULEV II
Recommended fuel: 87 octane or higher
6-speed automatic overdrive (5.7L V8)
4WDemand system with electronically controlled
2-speed transfer case
18-in. steel wheels with P255/70R18 tires
SuspensionFront independent coil-spring high-mounted double-wishbone with stabilizer bar and low-pressure nitrogen gas shocks; rear live axle with trapezoidal multi-leaf rear suspension and staggered low-pressure nitrogen gas shocks
Toyota Tundra - $38 750
381 hp @ 5600 rpm
Emissions: ULEV II
