Motor do novo M3 desvendado oficialmente
Esse era o M3 GTR para homologação no ALMS.
De qualquer maneira, mais uns dados oficiais directamente do site de imprensa da BMW:
•First eight-cylinder for the BMW M3 sports car.
•Supreme performance ensured by 309 kW/420 hp from 4.0 litres.
•Maximum torque of 400 Newton-metres (295 lb-ft) at 3, 900 rpm,
85 per cent of maximum torque over a speed range of 6,500 rpm.
•Unique thrust and muscle ensured by consistent implementation of the M high-speed engine concept, maximum engine speed 8,300 rpm.
•Consistent lightweight construction of engine and ancillary units,
new V8 power unit one of the lightest eight-cylinders in the world,
lighter than the straight-six power unit in the former model.
•Variable camshaft control, low-pressure double-VANOS for an
optimum charge cycle, system offering full power and performance even with normal engine oil pressure.
•Eight individual throttle butterflies for spontaneous engine response.
•Consistent and reliable oil supply with longitudinal and lateral acceleration up to 1.4 g ensured by two oil pumps and wet sump oil lubrication optimised for supreme dynamic behaviour.
•Exhaust system optimising cylinder charge, optimised for weight and function by means of internal high-pressure remoulding, exhaust emissions fulfil EU4 and LEV 2 standards.
•Upgraded MSS60 engine control unit for optimum coordination of all engine functions with the various control systems in the car.
•Ion flow technology recognising and distinguishing engine knocking phenomena as well as misfiring and miscombustion by measurement of ion flow in the combustion chambers.
•Brake Energy Regeneration with intelligent alternator control.
grande motor, um belo concorrente para o RS4, e o carro por fora esta um espanto, mas este motor devia de levar um SuperCharger, dando mais potencia e muito mais rapido
A batalha dos V8 começou:
VS
Ambos com 420 cv's, com uma pequena vantagem do Audi em termos de binário, mas a menor rotação.. Grande batalha entre M3 e RS5 [:cool:]
bem visto!!! apr:) apr:) [:cool:]
É engraçado que, apesar de reconhecer a qualidade desses carros, nunca liguei muito aos M3. Mas agora com este V8, vai lá, vai!
Lá me vai ter de sair o euromilho€s para poder comprar o RS4 e o M3 e depois vos poder dizer por experiência própria qual dos dois é o melhor :)
Mesmo o "antigo" M3 é um verdadeiro lobo em pele de cordeiro. 343Cv, anda mais que 95% dos carros alguma vez feitos e é uma maravilha da técnica.
Este é ainda melhor.
O binario máximo disponivel logo ás 3900 rpm?????? uiiiiiiiiii [br:)]
É provalvemente o antigo motor do anterior M5 modificado.... mas muito mais leve... eles dizem que é o V8 mais leve do mundo
Excelente!
So falta o 159 GTA...
(provavelmente tambem V8)
DE qualquer maneira sinto uma certa nostalgia em ver o I6 desaparecer dos M's :(
Ainda sobra um que anda para aí a derreter pneus com a carapaça do Z4...
Já repararam que os motores da M são quase sempre considerados, por unanimidade, como sendo dos melhores motores do mundo. Acho que este, mais uma vez, não vai fugir à regra. O peso deste V8 4L é qualquer coisa de intriganteapr:)
Mas desta vez terá pela frente um dos melhores motores que existem actualmente.. E isso é um facto comprovado.
Fabuloso carro!
quanto ao motor, o mais importante a destacar é o peso e a disponibilidade de binário logo ao inicio(3900rpm), deve ter recuperações fantásticas!
As acelarações estão garantidas, até pelo peso excepcional conseguido :)
