Prius polui 3x mais do que o Hummer!
Epá, esta apanhou-me de surpresa...
http://clubs.ccsu.edu/recorder/editorial/print_item.asp?NewsID=188
Prius Outdoes Hummer in Environmental Damage
By Chris Demorro
Staff Writer
The Toyota Prius has become the flagship car for those in our society so environmentally conscious that they are willing to spend a premium to show the world how much they care. Unfortunately for them, their ultimate ‘green car’ is the source of some of the worst pollution in North America; it takes more combined energy per Prius to produce than a Hummer.
Before we delve into the seedy underworld of hybrids, you must first understand how a hybrid works. For this, we will use the most popular hybrid on the market, the Toyota Prius.
The Prius is powered by not one, but two engines: a standard 76 horsepower, 1.5-liter gas engine found in most cars today and a battery- powered engine that deals out 67 horsepower and a whooping 295ft/lbs of torque, below 2000 revolutions per minute. Essentially, the Toyota Synergy Drive system, as it is so called, propels the car from a dead stop to up to 30mph. This is where the largest percent of gas is consumed. As any physics major can tell you, it takes more energy to get an object moving than to keep it moving. The battery is recharged through the braking system, as well as when the gasoline engine takes over anywhere north of 30mph. It seems like a great energy efficient and environmentally sound car, right?
You would be right if you went by the old government EPA estimates, which netted the Prius an incredible 60 miles per gallon in the city and 51 miles per gallon on the highway. Unfortunately for Toyota, the government realized how unrealistic their EPA tests were, which consisted of highway speeds limited to 55mph and acceleration of only 3.3 mph per second. The new tests which affect all 2008 models give a much more realistic rating with highway speeds of 80mph and acceleration of 8mph per second. This has dropped the Prius’s EPA down by 25 percent to an average of 45mpg. This now puts the Toyota within spitting distance of cars like the Chevy Aveo, which costs less then half what the Prius costs.
However, if that was the only issue with the Prius, I wouldn’t be writing this article. It gets much worse.
Building a Toyota Prius causes more environmental damage than a Hummer that is on the road for three times longer than a Prius. As already noted, the Prius is partly driven by a battery which contains nickel. The nickel is mined and smelted at a plant in Sudbury, Ontario. This plant has caused so much environmental damage to the surrounding environment that NASA has used the ‘dead zone’ around the plant to test moon rovers. The area around the plant is devoid of any life for miles.
The plant is the source of all the nickel found in a Prius’ battery and Toyota purchases 1,000 tons annually. Dubbed the Superstack, the plague-factory has spread sulfur dioxide across northern Ontario, becoming every environmentalist’s nightmare.
“The acid rain around Sudbury was so bad it destroyed all the plants and the soil slid down off the hillside,” said Canadian Greenpeace energy-coordinator David Martin during an interview with Mail, a British-based newspaper.
All of this would be bad enough in and of itself; however, the journey to make a hybrid doesn’t end there. The nickel produced by this disastrous plant is shipped via massive container ship to the largest nickel refinery in Europe. From there, the nickel hops over to China to produce ‘nickel foam.’ From there, it goes to Japan. Finally, the completed batteries are shipped to the United States, finalizing the around-the-world trip required to produce a single Prius battery. Are these not sounding less and less like environmentally sound cars and more like a farce?
Wait, I haven’t even got to the best part yet.
When you pool together all the combined energy it takes to drive and build a Toyota Prius, the flagship car of energy fanatics, it takes almost 50 percent more energy than a Hummer - the Prius’s arch nemesis.
Through a study by CNW Marketing called “Dust to Dust,” the total combined energy is taken from all the electrical, fuel, transportation, materials (metal, plastic, etc) and hundreds of other factors over the expected lifetime of a vehicle. The Prius costs an average of $3.25 per mile driven over a lifetime of 100,000 miles - the expected lifespan of the Hybrid.
The Hummer, on the other hand, costs a more fiscal $1.95 per mile to put on the road over an expected lifetime of 300,000 miles. That means the Hummer will last three times longer than a Prius and use less combined energy doing it.
So, if you are really an environmentalist - ditch the Prius. Instead, buy one of the most economical cars available - a Toyota Scion xB. The Scion only costs a paltry $0.48 per mile to put on the road. If you are still obsessed over gas mileage - buy a Chevy Aveo and fix that lead foot.
One last fun fact for you: it takes five years to offset the premium price of a Prius. Meaning, you have to wait 60 months to save any money over a non-hybrid car because of lower gas expenses.
Para a malta que quer a resumo em português:
É preciso gastar mais energia a fazer um Prius do que um Hummer. Como?
O Prius tem dois motores, um de 76cv 1.5, e um elétrico de 67cv.
Como se gasta mais energia a acelerar, é onde o motor elétrico trabalha mais. Energia que é reaproveitada enquanto se trava.
Bem, os testes de economia foram baseados em auto-estrada a 55mph. Aumentaram as velocidades e as acelerações, o consumo disparou, é comparável a um Chevrolet Aveo, que é mais barato.
O problema é que o Prius é mais letal ao ambiente do que um Hummer que ante 3 vezes mais tempo, devido Às suas baterias de níquel. O níquel, fabricado em Ontario, já causou tantos problemas que a NASA considera a própria zona "dead zone".
A toyota produz 1000 toneladas / ano. E a Greenpeace anda furiosa com os sulfatos emitidos para a atmosfera,causando chuvas ácidas.
Adicionalmente, para fazer as baterias, esse níquel passa ainda pela Europa, China e Japão!
No final, somadas a energia de produção, combustível, transportes e outras coisas, o Prius custa $3.25 por milha em 100.000 milhas de Prius, enquanto que o Hummer fica-se pelos $1,95.
Mais: para compensar, há que esparar mais de 5 anos. O melhor é comprar um Toyota Scion xB...
E esta heim? É inveja dos Americanos, ou é mesmo vistas curtas de todos?!
Uma coisa é aquilo que nos é imediato enquanto consumidores: quanto sai do bolso, e quantos litros se metem na bomba. Aí o Prius ganha um pouco de vantagem sobre um "gasosas" tradicional.
Outra coisa diferente é o inteiro ciclo de produto (gostei da expressão "dust to dust") desde o fabrico até ao desmantelamento. Ainda assim, os números parecem demasiado pessimistas.
As discussões em torno da energia nuclear costumam andar em volta desta problemática: uma coisa é o custo de PRODUZIR energia e outra coisa é o CICLO COMPLETO contando com a guarda, trasnporte e eliminação/armazenamento dos resíduos...
Se isto for assim parece-me uma granda bronca !
De facto mesmo historicamente os Orientais não costumam ter muitas preocupações ambientais.
Que o digam as inumeras especies nas quais exercem pressão nomeadamente o atum azul tão apreciado para fazer sushi
Será o hidrogénio mais limpo?! Pelo menos, não usa baterias.
Outro factor de preocupação será no abate de híbridos, daqui a alguns anos; será que os centros de abate estão prontos a reciclar as baterias?
1. É verdade que fazer um híbrido polui mais e consome mais energia que fazer um carro normal.
2. Também é verdade que a Ford, GM e Cadillac andam à rasca e pagam o que for preciso para denegrir os rivais.
3. Tanto quanto eu saiba, a tal fábrica de niquel continuaria a trabalhar sem a toyota...
e para verem que os quase 30.000€ que dam pelo Prius e em vao, porque ate um Hummer(o H2 ou H3 porque o H1 era um diesel um V8 6.1) poui menos(esta nao sabia) mas que polui mais que o Mercedes S500 isso polui
cumps ;)
Escrito sem dúvida por um orgulhoso dono e apaixonado dos Hummer...
Assim sendo, porque é que o hummer tem o preço que tem comparado com o prius? A toyota não está no mercado para perder dinheiro, nem com o prius, e já é sabido que está prestes a ultrapassar a GM...
Quantas milhares toneladas de emissões é que o prius não poupa em 5 anos comparado com o hummer? Pelo que li, a toyota requer 1000 toneladas de baterias de nickel por ano. Em 2009 o prius vai ter baterias de lítio. Lá se vai o argumento...
Os americanos nunca produziram um hibrído em condições apesar das tentativas (excluíndo o tesla que ainda se está para ver - custa várias vezes mais do que um prius) e pela conversa espero q não pensem que os europeus vão acreditar nisso, pois não são burrinhos como a maior parte dos americanos...
Sinceramente não me espanta. Se já as vantagens em termos de consumo de um hibrido me pareciam pequenas quando levamos em linha de conta manutenção, consumos reais não tão pequenos quanto isso e maior quantidade de produtos que necessitam de reciclagem na sua produção, não há que admirar.
Hibridos não são, quanto a mim, o futuro.
Eu sou de opinião contrária em certo aspecto. Não é o futuro, mas o futuro próximo passa por aí. A manutençao de um híbrido é extremamente reduzida. O facto de ter 2 motores a puxar o carro, faz com que estes se desgastem menos e sejam menos solicitados. O motor eléctrico não tem manutenção.
Os consumos, dependendo da condução, conseguem ser imbatíveis comparando com um gasolina normal, isto se a condução não for a alta velocidade.
A km77 fez um teste de longa duração do prius, em que aos 100000kms têm uma média de 6.4l/100Km, isto com uma condução normal e não "relaxada".
http://www.km77.com/marcas/toyota/2006/prius/ld/t01.asp
Não é de negligenciar que a toyota tb possui as revisões mais baratas do mercado.
