citação:Originalmente colocada por v7
O Daniel gosta deles grandes[8D]
citação:Originalmente colocada por Daniel Matias
Isto de ter origem africanas tem o seu "Q"
citação:Originalmente colocada por alv2
Então anda cá,, que vou-te apresentar o "mantorrá"... ele diz que quer ver a tua "garagem".... foge![]()
citação:Originalmente colocada por hpventura
citação:Originalmente colocada por PDCouto
Porra, 40mil euros por um série 1, um carro tão diminuto que tem tantos concorrentes mais espaçosos e baratos?!
40.000€ custa um 120D novo...aqui nem sequer se esta a falar de um serie 1 normal, esta-se a falar do 130i, o topo de gama do serie 1 e q custa novo 57.000 € !!!
E a qualidade dos carros nao se mede pelo espaço que têm... por esse principio comprava uma Ford Transit ou outra parecida.
citação:
"This car is taking BMW into dangerous territory"
"The 1-series will be the ruination of the BMW brand. Of that I have no doubt. But at the moment that ruination has not yet got into its stride. For now you can still buy a Beemer with your dignity intact. The question is, should you?"
"The BMW, however, is just plain ugly."
"Well, the petrol version will get you from 0 to 60 in about two hours..."
"So it’s slow and ugly and now things really go downhill because thanks to the prop shaft and all the other rear-wheel-drive gubbins, there is no space in the back. And I don’t mean that legroom is limited. I mean there is absolutely none at all."
"And then there’s the ride, which thanks to the fitment of run-flat tyres is intolerable on anything but a kitchen work surface, and the quality of some trim pieces, which will disappoint those who may have expected granite rather than Plasticine."
"But the worst thing about the 1-series is the prices. In the past BMWs were expensive because they were demonstrably better, and more exciting, than all of their rivals. But the 1-series, as we’ve seen, is demonstrably worse."
"Park one of these on your drive and the neighbours will not think, “Hmm, that’s an expensive car. He must be doing well.” They’ll think, “Hmm, that’s an expensive car. He must be off his rocker.” You can have a Golf GTI for less, and that, in almost every single way, is a better car."
"So if you want a hatchback, buy a Focus. If you want a hatchback with some go, buy the VW. If you just want some action and you don’t care about space in the back, or a hard ride, or the price, buy a sports car. A Honda S2000 would be fine. "
"And it’s why I’m choosing the words for my conclusion with even more care than usual. So here goes. The 1-series is crap."
http://driving.timesonline.co.uk/article/0,,12529-1397786_1,00.html
Quem não gosta do carro, quem não quer comprar ou quem não pode comprar.... simplesmente não compra.... mas que parece estar a bom preço parece...e tem um bom motor, deve vir bem equipado (esse especificamente) e do segmento é uma das melhores propostas do mercado... quanto a mim
PS- Que raio de mentalidade de quem diz que só compra BMW para impressionar os vizinhos.... devem andar aqui muitos comunistas infiltrados... tem de andar tudo de igual , vestido de igual, calçado de igual ...
citação:
Resumindo: Caro, pouco espaçoso, com mau comportamento. Chega?
Oops, esqueci-me de referir o "desconfortável" em piso que não sejam optimos.
Acho um exagero dar isso pelo carro que é, simplesmente isso. Ainda se fosse um série 3, que já é um carro grandito, mas um série 1?!
edit: por exemplo:
http://www.carsurvey.org/model_BMW_1+Series.html
6 comentários, com 3 satisfeitos e 3 "mais ou menos"?! [:0]
citação:Originalmente colocada por Avant
E já pensaste que há quem compre o série 1 porque não quer, não precisa ou não gosta de carros maiores?
Estou a ver que ofendi os BMW´s boys...
haaaaaaa... então era esse o objectivo [}][}
PS- Vai mais uma caixa de fosforos [}][}
Volto a repetir a premissa:
O preço é MT Bom face ao produto, mas ha melhores propostas por esse valor
isto a meu ver.
Ora então diz lá as propostas que tu achas melhor, DENTRO DO SEGMENTO...
Quem sabe até a pessoa que colocou o topico até pode concordar com essas propostas... desde que não tenham mais quilometragem que aquele, não ultrapassem aquele valor e venham mais ou menos com o mesmo nivel de equipamento... já para não falar em questões subjectivas como a eficacia reconhecida do serie 1
Eu gosto muito deste carro.
Excelente motor, boa dinâmica e estética (esta última é a minha opinião)
Também acho que o facto de ter 5 portas e uma dimensão média faz dele um excelente multiusos, desportivo, pequeno familiar, cidade, viagem, estacionar, não lhe vejo grandes limitações.
Mas julgo que a pergunta não tinha a ver com a nossa opinião sobre o carro, mas mais sobre o negócio. Ora um carro cujo preço base é 57.000 Euros (facilmente 60.000 ou mais com alguns extras) por 40.000 Euros com menos de um ano, parece-me mesmo muito bom negócio.
Para isso há opções muito mais interessantes e adequadas, mesmodentro da marca:
http://www.bmw.pt/pt/pt/index_narro...s/z4/coupe/2006/allfacts/design_exterior.html
Mesmo o Z3 seria preferível. [8D]
Mas isto sou eu a opinar...
