JRodrigues
Raging bull loses its head
As the Los Angeles Auto Show opens today, we know which stand we'll be rushing to first.
Lamborghini has chosen the West Coast extravaganza to unveil its Murciélago LP640 Roadster - and it's going to be difficult to miss.
Essentially the chop-top version of Lambo's outrageous LP640 Coupe, the Roadster is as subtle as a bull in dark glasses... and every bit as intimidating.
The 640, of course, refers to the horsepower produced by the Roadster's 6.5-litre V12, while LP stands for 'longitudinale posteriore', which means the engine is mounted lengthways behind the cockpit.
All of which allows the Roadster to spin up to 8,000rpm and develop a meaty 486lb ft of torque - enough to propel it to 62mph in a mere 3.4 seconds and on to a top speed of almost 200mph.
Yes, that's a fraction slower than the coupe version. But without a roof to provide at least a little protection from the deafening growl of the V12, we're betting that the driving experience will be even more intense.
Removing the roof has required Lamborghini to make some serious structural adjustments to stop the LP640 from splitting in half as it hits warp speed.
A newly designed frame structure made of steel and carbon fibre keeps the Roadster rigid, with particular reinforcement given to the engine area. Lambo will even sculpt these reinforcements out of carbon fibre if you ask nicely.
Lamborghini also reluctantly offers a canvas roof, but warns that it is only for temporary use at speeds of under 100mph. Better drive fast enough to beat the rainstorms, then.
Devotees of the raging bull will notice a few other touches unique to the Roadster. The chop-top gets a new rear diffuser, with the exhaust system integrated within a tailpipe, as well as fresh windscreen wipers, a revised rear-light cluster and the option of new Hermera alloy wheels.
Otherwise the Roadster stays true to its Coupe roots. The monster 335/30 rear tyres remain, with Pirelli Corsa tyres an option for those who want to test out the Roadster on the track.
If you're brave or stupid enough to fancy charging the Murciélago on near-slicks, the LP640 Roadster arrives in the UK in spring 2007.
The price tag? Lambo is staying coy, but we reckon it'll cost you at least £200,000 to feel the wind in your hair and 640 horses behind your back.
http://www.topgear.com/content/news/stories/1380/
O carro mais louco que existe [B)][B)][B)]
citação:
O touro Raging perde sua cabeça
Enquanto a auto mostra de Los Angeles abre hoje, nós sabemos que carrinho nós estaremos apressando a primeiramente.
Lamborghini escolheu o extravaganza ocidental da costa unveil seu Murciélago LP640 Roadster - e está indo ser difícil faltar.
Essencialmente a versão do chop-alto de LP640 outrageous Coupe de Lambo, o Roadster é tão subtle quanto um touro em vidros escuros… e em cada bocado como intimidating.
Os 640, naturalmente, consultam aos cavalos-força produzidos pelo litro V12 do Roadster 6.5, quando o LP estiver para do “o posteriore longitudinale”, que significa que o motor é lengthways montados atrás da cabina do piloto.
Qual permite que o Roadster gire até 8,000rpm e desenvolva um 486lb meaty ft do torque - bastante para o propelir a 62mph no meros 3.4 segundos e sobre a uma velocidade superior quase de 200mph.
Sim, aquela é uma fração mais lenta do que a versão do coupe. Mas sem um telhado para fornecer pelo menos pouca proteção do rosnado deafening do V12, nós estamos apostando que a experiência dirigindo será ainda mais intensa.
Remover o telhado requereu Lamborghini fazer alguns ajustes estruturais sérios para parar o LP640 de rachar ao meio enquanto bate a velocidade da urdidura.
Uma estrutura recentemente projetada do frame feita da fibra do aço e do carbono mantem o Roadster rígido, com o reforço particular dado à área de motor. Lambo nivelará o sculpt estes reforços fora da fibra do carbono se você pedir agradàvel.
Lamborghini também oferece relutantemente um telhado da lona, mas adverte que é somente para o uso provisório em velocidades de 100mph inferior. Melhorar a movimentação rapidamente bastante para bater as tempestades, então.
Os devotoes do touro raging observarão alguns outros toques originais ao Roadster. O chop-alto começa um difusor traseiro novo, com o sistema de exaustão integrado dentro de um tailpipe, as well as limpadores de windscreen frescos, de um conjunto revisado da traseiro-luz e da opção das rodas novas da liga de Hermera.
Se não o Roadster permanece verdadeiro a suas raizes de Coupe. Os tyres traseiros do monster 335/30 remanescem, com os tyres de Pirelli Corsa uma opção para aqueles que querem testar para fora o Roadster na trilha.
Se você for bravo ou stupid bastante para gostar de carregar o Murciélago em próximo-slicks, o LP640 Roadster chega no Reino Unido na mola 2007.
O Tag de preço? Lambo está permanecendo coy, mas nós contamo-lo custar-lhe-emos pelo menos £200,000 para sentir o vento em seu cabelo e em 640 cavalos atrás de sua parte traseira.
