Nova Volvo V70 (Fotos Espia Destapada!)
Bolide
Banido
The pictures were taken inside the Volvo factory and shows that there is very little left before it's world debut in Geneva in march next year. The white V70 T5 AWD in the pictures is a pre-production car and clearly shows the similarities between the next V70 and the new Volvo S80, that premiered on this years saloon.
The front will be different while the hood, front fenders and front doors will be the same as on the S80. From the rear doors and backwards is where the changes are made. The rear is dominated by the, to say the least, complex taillight arrangement and it’s design is a combination of the C30, the V50 and the new S80. The upper part of the taillights are vertical (V50), while the bottom parts look like the new S80. At the same time the framing of the rear window and the metal beneath it is shaped like the smaller C30. The hatch is angled somewhat inwards at the top and bottom which gives it a hexagonal shape, here the designer team clearly looked at the old Volvo 145/245 for inspiration. The upper part of the taillights also accompanies the hatch when opened.
The axeldistance grows eight centimetres compared to today’s V70 into a whole 284 centimetres. The rear seat will become a lot bigger in the new V70, which is necessary when you compare it to for example it’s competitor the Audi A6 Avant. According to our sources the rear overhang will shrink, but the luggage compartment will still become somewhat bigger.
The interior will be identical with the S80, which means the same dashboard, door cards and the equipment levels Kinetic, Momentum and Summum. On our spy pictures new seven spoke, 17” wheels can be seen. They will become standard equipment on the T5-modells (will also be available on the S80).
Engine wise the V70 gets the same choices that the new S80 already has, some more additions will probably arrive later though. The ethanol fuelled 2,0F will have a Volvo developed five cylinder, two litre, turbocharged engine putting out around 200hp. Rumour also has it that a cheaper two litre, four cylinder engine (145hp) from Ford will be available in 2008. At least two diesel engines will be available in the new V70, the strongest will be the D5 with 185hp. The top-of-the-line model will not be the planned V70 V8 AWD (though it will be available), but a V70 R with a turbocharged 4,4 litre V8 engine putting out approximately 370hp. The V70 R will make it debut in late 2008, early 2009.
The new V70 is right now going through pre-production at the Torslanda-plant, and the first production vehicles will reach dealers during late spring, early summer.
citação:Originalmente colocada por André
Já estava no tópico Volvo há séculos passo o exagero
Desdas 15 horas....
De qualquer modo um modelo como a V70 tão importante (por enquanto, não prevejo grande futuro...) na gama Volvo merece o destaque de um tópico próprio.
Desdas 15 horas....
Eu também acho ;)
Tu é que já fechaste uma data de tópicos como este da V70 argumentando que tinham posto no tópico da marca [:p]
Outros tempos, recentemente não me lembro, a politica mudou, estamos em retoma, o forte crescimento económico anunciado pelo governo naturalmente vai impulsionar a criação de novos tópicos.
Mais esclarecimentos PM para o comité central aka pé leve
Ta Estranha...
Gostei de ter mantido a sua caracteristica principal, por outro lado, a lanterna traseira esta muito grande...
Eu até gostei.. e não é para ser do contra. Gostava de ver de frente. O pior é em cores tipo Azul e isso, os farois traseiros vão destoar muito! Podiam ter adoptado uma solução tipo os Saab acho eu, meio esbranquiçados.
