[Via MobileMag]citação:Forget biodiesel and fuel cell-powered vehicles, how about a whip that doesn't require any fuel whatsoever? The Venturi Eclectic, touted as an "autonomous energy vehicle," gets its charge from wind gusts and 8.2 square feet of solar cells atop its roof. The four-person ride boasts a 22-horsepower purely electric engine, is powered by liquid-cooled NiMH batteries, and can reach a (yawn-inducing) top-end speed of nearly 32mph. While it's no Wrightspeed X1, the designers had "daily driver" in mind when the Ecletic was crafted, but considering it'll only roll 31 miles on a full charge, you best take the scenic (read: sunny) route to work if you're facing a long commute. The car does sport an option to recharge via AC power, should you face darker (and calmer) than expected conditions, but since it weighs just 772 pounds, a foursome shouldn't have too much trouble using the tried and true "push method" if worse comes to worst. Scheduled for production in June 2007, this oh-so-green automombile will run you #8364;24,000 ($30,511) -- if you can manage to score one of the 200 that'll be built, that is.
[^]citação:Originalmente colocada por Fred Simões
Vou colocar já as 80 fotos...![]()
Então gostaram das fotos?
citação:Originalmente colocada por Unreal
Claro isso nem se pergunta!
Podias ter tirado mais que aqui a malta não se importava
Qual era o carro com mais gente ao pé?O 8c ou o R8?
